Analogue vocoder - compressor?
Post by baward »
I have a 1970's Korg VC-10 vocoder which is great, but I am trying out a new microphone with it. Should I use/do I need a compressor with the mic? Or a limiter? The bespoke MS-01 microphone (the one on the gooseneck) works well, but is a little long in the tooth. Thanks!
baward
Posts: 424 Joined: Tue Feb 04, 2003 12:00 am
Re: Analogue vocoder - compressor?
Post by resistorman »
Nope.
resistorman
Posts: 2959 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
No, you don't *need* a compressor with a vocoder, but it can help enormously.
Posts: 21341 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by baward »
Many thanks for your responses.
baward
The Elf wrote: Thu Jun 30, 2022 7:39 pm No, you don't *need* a compressor with a vocoder, but it can help enormously.
Sure, but this only has mic level inputs, the external 3vpp input is for tone sources. Considering you'd have to use a mic preamp into a compressor then some kind of reamp circuit to match the mic input it seems way too convoluted with a lot of potential for noise and distortion without much (ahem) gained.
resistorman
Since a vocoder only uses the mic input to generate the speech formants used to modulate the synthesised sounds I can't see any advantage in using a different mic unless the original is broken?
Posts: 22692 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Generally speaking, over the decades I've found that the cheaper the mic, the better it works with a vocoder. No need to worry about distortion, or other artifacts.
There's really very little to worry about in terms of the quality of signal arriving at the vocoder - just do what works.
The Elf wrote: Fri Jul 01, 2022 9:16 am There's really very little to worry about in terms of the quality of signal arriving at the vocoder - just do what works.
I'd agree with that - if anything, it's adjusting your vocal delivery that makes the biggest difference in getting a suitable vocoded sound.
Posts: 22438 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by Zukan »
I prefer to leave dynamic processing alone, bar maybe using eq if after a very specific texture, and letting the transients shine though into the vocoder. The transients themselves are an important aspect of vocoding particularly when affecting drum beats or highlighting the formant pops of vocals.
Zukan
1-2-1 Tuition
