Studio monitors makes weird buzz sound
For all other computers and operating systems, including Atari, Linux and mobile apps.
Post by razmab »
Hello, I've had the focusrite scarlett 2i2 and adam audio t5v for about a year and have been very happy with both the monitors and the interface.
My main and only use for the setup is to listen to music on Tidal, Spotify, and Youtube. Recently, I've noticed that my monitors have been buzzing for no apparent reason, and that sometimes the entire song is suddenly squashed, and after closing the music source, song sounds as should.
Is there anything I can do to keep these problems from occurring?
Also, on the focusrite scarlett configurations, what settings should I use? (sample rate, buffer size)
As previously stated, I only use the aforementioned setup for listening to music via Tidal, Spotify, and Youtube.
Here's a link of a youtube reel showcasing what i'm suffering from
https://youtube.com/shorts/GvHPsIChKMo?feature=share
Thank you!
razmab
Posts: 4 Joined: Sat Jul 02, 2022 2:27 pm
Re: Studio monitors makes weird buzz sound
It might be that your buffer rate is set too low. If all you're doing is listening back to music and not recording then you can crank it right up.
Posts: 28843 Joined: Sun Jul 05, 2015 12:00 am Location: York
blinddrew wrote: Sat Jul 02, 2022 6:43 pm It might be that your buffer rate is set too low. If all you're doing is listening back to music and not recording then you can crank it right up.
Pretty much my first call as well.
Might be good to play a CD and see how that goes? After that, look at Task Manager and see if CPU hit is high, I would not expect it to be more than about 10% for internet and running the F'rite. You might have something running in the background.
If all else fails maybe download the 2i2 drivers afresh and re install them.
Posts: 18530 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Post by razmab »
Hi,
Thanks for the replay!
buffer rate equals to buffer size?
if so, my buffer rate is set to the highest at the moment.
attaching a screenshot of my scarlett 2i2 settings.
razmab
Hello razmab, welcome to the forum :wave:
We don't support attaching images here but if you upload one to imgur.com or similar, and then link directly to the image itself (as opposed to the page it's on) using the [img] ... [/img] tags then it should be displayed in-line in the forum.
Edit: I've seen your updated post and added the tags to it to make it display inline :thumbup:
Posts: 9736 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Ok, so it's not your buffer size. As ef37A suggests, might be worth checking your task manager to make sure something else isn't hogging CPU.
Also worth checking you've got the latest drivers for the interface and that you've not got anything funny set in the audio settings of the PC.
Is the buzzing coming from one monitor or both and does it happen with headphones as well?
Post by RichardT »
I have to say that's a very weird set of sounds and not something I've ever heard when my own computer audio drops out.
If the suggestions you've already been given don't work, it's simply a case of replacing each component in the chain one at a time to see if that's the one at fault - so try with different speakers, different audio interface (e.g. the computer's own audio out), different source (phone or tablet for example).
RichardT
Posts: 5331 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Post by razmab »
Hi,
thanks for the replay.
I checked and have the latest audio interface driver.
Issue is not happening when listening thorugh headphones.
Buzz sound is coming from both speakers.
task manager seems to be OK.
Could it perheps be a socket without grounding?
razmab
How — exactly — is the whole system connected?
Posts: 42816 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Hugh Robjohns wrote: Sun Jul 03, 2022 8:35 pm How — exactly — is the whole system connected?
And where are the headphones connected when things are working?
Posts: 16381 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by razmab »
aux jack directly to the PC (not through audio driver.)
razmab
We're going to need a bit more detail I'm afraid! :)
Is everything plugged into the same wall socket? Are you connecting your monitors and interface with balanced cables? What else is plugged into the interface?
I'm trying to judge from your response to James' question - are you plugging your headphones into the PC soundcard not the audio interface?
If so, what happens when you use the interface?
Post by RichardT »
razmab wrote: Mon Jul 04, 2022 7:47 pm aux jack directly to the PC (not through audio driver.)
Ok, that possibly suggests it’s not your PC or DAW.
Try the phones through the Scarlett.
Try different speakers with the Scarlett.
RichardT
RichardT wrote: Mon Jul 04, 2022 9:54 pm
Yes then, IF you get the buzz on the headphones pull the speaker plugs out of the back of the 2i2. If that stops the noise then we can be pretty sure you have a ground loop.
