Shocks from mic
Shocks from mic
Post by ian2 »
On Sunday my wife reported feeling a tingling electric shock when her lips touched the mic into which she was singing at church.
The setup was somewhat different from usual. Rather than me playing electric guitar and being led by our usual worship leader, with his vocals and all-singing keys (which can provide drum sounds and bass sounds) he was absent and I was leading on electro-acoustic guitar and vocals.
We (sadly) don't usually have any foldback whatsoever. However, on Sunday I took my wedge monitor, which was fed with a mix of my electro-acoustic guitar, my mic and my wife's mic:
Code: Select all
Mic1 ==> DI_1 ==> Snake ==> FOH
	||==> Ch1 of on-stage mixer
	||			||==>Sole wedge monitor
	||==> Ch2 of on-stage mixer
Mic2 ==> DI_2 ==> Snake ==> FOH
Electro-acoustic ==> DI_3 ==> Snake ==> FOH
			||========> Ch3 of on-stage mixer ==> Sole wedge monitor
So, the non-usual equipment that we were using were essentially the on-stage mixer - my Phonic MM1002 - and my wedge monitor, a Laney CP12. I should also mention that, in order to split the mic signals on-stage, to feed both FOH and foldback, there was the unusual configuration of having DI boxes between the mics and the snake.
For info, the FOH mixer is a Peavey 18 channel thing, and would have had phantom power enabled, in order to power the DI boxes, which are Behringer DI-100. The mics are Sennheiser dynamics.
Although I've consequently purchased an RCD, and resolved always to put it between my 4-gang power adapter and the wall socket, there is surely still an electrical fault somewhere. I haven't yet assimilated all of the mic shocks sticky post found within this section of the forum, but our church minister has been informed of the issue.
This evening I tested for continuity between the chassis of my mixer and the earth pin of its main plug. No continuity. The manual states "This product is equipped with a 3-wire grounding type plug; this is a necessary practice to prevent electric shock hazards to the operator, the microphone user, and the musicians who are wired to this unit." Nonetheless, taking the mains plug apart I found only two wires; one connected to live, one to neutral and nothing connected to earth. Further inspection yielded the double insulated symbol on the Phonic power supply that came with the mixer. Presumably that part of the manual is incorrect, perhaps having been copied from the manual of an older model.
I'd appreciate your thoughts on the above, and your wisdom in identifying next steps in the investigation. I can think of several, but don't have the expertise to know how to prioritise them (and I'm sure there will be additional steps to take):
  • Testing for a good connection from the wedge monitor to earth. However, I don't know what exposed part of the wedge, if any, ought to be at earth potential.
  • Testing the earth connections of the other components.
  • Another church member has a device which can be used to test the room's mains sockets.
  • Testing my 4-gang power adapter's earth.
ian2
Posts: 78 Joined: Sat Oct 09, 2004 12:00 am Location: Oxfordshire, U.K.
Re: Shocks from mic
There are two types of 'shock' in situations like this.
The first, and benign form, is a short, non-continuing zap caused by discharging static electricity. This is most usually generated by clothes/shoes and discharged by touching a grounded mic. You get repeat shocks if you stop touching the mic, move around to create more static, and then touch the mic again.
The second — and much more worrying form — is a continuing 'tingle'. This is much worse in Europe than in the USA because it's normally caused by the system's metalwork rising to half mains voltage due to a missing safety earth connection. So the mic body becomes 'half-live' and effectively discharges to ground continuously through the user when they touch it.
Normally, this is unpleasant rather than lethal as the impedances are quite high... but the missing safety ground means that a second fault or failure could make the whole system a real killer! So it is vital to find and fix the problem.
An RCD is always a good idea — I never plug anything into a wall socket at a gig without one — but it may not trip in situations like this.
In your case, I suspect the DI boxes have isolated the mics and your gear completely from the FOH system (which I presume is properly grounded).
But the ungrounded Phonic mixer is connected directly to the mics, allowing their bodies to rise to half mains voltage.
As the hub of most audio systems, mixers are usually grounded. But it seems that's not the case here. Often a double insulated mixer like yours will get grounded through other connected equipment, such as a powered wedge monitor, so you might want to check the grounding of all your equipment.
It must also be said that a real oddity here is the use of DI boxes as mic splitters! Thats definitely NOT what they're intended for. They will typically knock 20dB off your mic level to FOH and add significant noise. You'll also have an unbalanced feed to your local mixer which might result in unwanted interference.
You'd be much better off using proper mic splitter boxes (with the FOH using the Direct connection).
Alternatively, connect the mics direct to the FOH console, and setup prefade aux sends from the mic channels to provide line level monitor feeds back to your local mixer.
But definitely check for missing mains safety grounds on all mains cables, plugboards, IEC leads (etc) and equipment. And then check your audio cables have intact screens too.
Posts: 43708 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Re: Shocks from mic
Hi Ian, you must of course get the whole system checked out for safety possibly to the extent of getting in an electrician to check earth impedance of the mains supply. ANY case of any kind of shock, however mild must be investigated.
However, I think the sources of the "tingles" your wife felt can be explained by the fact that the Phonic mixer supply is class 2, double insulated. This sort of gear can 'float' at about 1/2 mains potential and a very mild shock or tingle can often be felt. Common on the metal parts of certain laptops for example.
The source resistance of this voltage is very high, capacitive in fact and so could probably be eliminated by tying the screens of the mic XLRs to a good earth with a few k Ohms.
You could just bond the chassis of the mixer solidly to earth but that is likely to throw up ground loop hum problems.
More and more audio equipment is going 'earth free', monitors e.g. and I can see more posts coming about people getting mild shocks and hum problems.
I am sure Hugh and other better men than I will comment very shortly.
Begger me! You're quick HR!
Posts: 19149 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Re: Shocks from mic
Post by shufflebeat »
It's my understanding (happy to be corrected) that an RCD is only effective if everything is going through it, i.e., on the first distribution point of a star system or on every socket if several are being used. Any socket (outlet) without one negates the whole process.
No?
shufflebeat
Posts: 10113 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Re: Shocks from mic
Yes.
An RCD checks that the current on the Line (Live) exactly matches that on the Neutral from the wall socket.
If it doesn't, it can only be because current is going to ground 'illegally' — possibly via an unfortunate person — due to a fault.
So, if that imbalance condition is detected the RCD trips its mains output power very quickly and hopefully before the 'unfortunate person' gets fried.
Ideally, everything should be powered through a single RCD trip, but in more complex rigs each device (or group of devices) can have its/their own RCD(s).
But if some devices are powered via RCDs and some aren't, the whole system safety is severely compromised since in the event of a major fault some gear will remain powered even if the RCDs trip out, potentially resulting in personal frying...
Re: Shocks from mic
Post by Mike Stranks »
I have met Ian a few times in connection with my previous church-sound work, although haven't seen him for several years now. As his post indicates, I know him as a meticulous and careful person who knows his stuff and wouldn't be cavalier about anything.
But - and not a pop at Ian - his post indicates that there is still a great deal of uncertainty and awareness of the differences between, and uses of:
* DI Boxes
* Iso-transformers
* Splitters - esp mic splitters
I think we've had several Hugh-written tutorials in the Forum about the differences and uses and, I think, something at some point in the Technical Q&A in the magazine.
Time for more of a feature in the mag about the important little boxes you might need on the road and the differences and uses?
(I now await one of m'learned friends quoting chapter and verse of an article that's already in the archives! :lol: )
[I always used mic splitters when doing location recordings for local radio - the venue had the transformer-side for FOH if they wanted it. FOH and recording systems completely isolated from each other following a couple of pre-recording nasties (quickly sorted) in my early days of doing this.]
Re: Shocks from mic
Add re-ampers to that list as well I think Mike.
I've seen some 'interesting' attempts to press them into unconventional service.
Posts: 29727 Joined: Sun Jul 05, 2015 12:00 am Location: York
Re: Shocks from mic
blinddrew wrote: Wed Jun 29, 2022 10:55 am I've seen some 'interesting' attempts to press them into unconventional service.
Ooh! Pray tell... ;)
Re: Shocks from mic
Using them back to front with a hodge-podge of adaptors to try and make up for a lack of suitable inputs on a mixer being the one that springs to mind. :)
Re: Shocks from mic
Post by ian2 »
Thanks for everyone's inputs so far.
We were back to a more typical set-up for today's service. However, before we started:
  • I used a newly purchased T.I.S. 1005 socket tester (no-one in the UK seems to have stock of the Martindale's near equivalent EZ165, at present) to confirm that three green lights were indicated for each of the room's mains sockets that we would be using to power the PA and everything connected to it.
  • I inserted a Masterplug RCD into each of the mains sockets that we would be using to power the PA and everything connected to it.
I note the warning that RCD's may not trip in the scenario that we had last week, and understand that there are a lot more more checks that can be done, including:
  • (Quoting Hugh's post): "definitely check for missing mains safety grounds on all mains cables, plugboards, IEC leads (etc) and equipment. And then check your audio cables have intact screens too."
  • Use the T.I.S. socket tester to test that each RCD trips when it's supposed to.
I heard from our usual worship leader today that he has previously experienced shocks when he has touched his mic. He believes that the shocks that he experienced were static shocks. However, my wife believes that, rather than a "zap", what she experienced last week was a tingling which continued until she moved her lips away from the mic.
Some questions:
  1. Hugh, is it the case that your warning that RCDs may not trip in last week's scenario stems from the likely physical decoupling of electrical circuits brought about by the way that DI boxes (which I understand to contain transformers) were being used in the system?
  2. Hugh, you wrote: "the ungrounded Phonic mixer is connected directly to the mics, allowing their bodies to rise to half mains voltage". From a physical perspective, the Phonic mixer was connected indirectly to the mics, via the "LINK" socket of the Behringer DI100 DI boxes. But have you written "directly" because you either suspect or know it to be the case that the DI boxes' "LINK" outputs are directly physically connected to the XLR input socket? How can the bodies of the mics rise to half of mains voltage?
  3. Suppose it were known for certain that the shocks that my wife experienced were "only of the static variety"; would it nonetheless be the case that:
    1. The shocks were an indication of the lack of a good connection to earth somewhere in the system
    2. The lack of a good connection to earth somewhere in the system would have amounted to a system in which one further fault could make the system potentially lethal?
  4. https://service.shure.com/Service/s/art ... uage=en_US tells us that a possible reason for an electric shock from an SM58 (which is not the vocal mic that we use at church) is lack of a good connection between the grill and pin 1 of the XLR. Suppose the grill of such a mic has become partially unscrewed from the mic's shell, such that the threads mesh loosely and the connection between the grill and earth is poor; how many faults away from a potentially lethal state could that, by itself, be? One? Or none?
ian2
Re: Shocks from mic
In answer to a couple of questions...
The link sockets are connected directly to the input sockets on the DI. The input socket is not an XLR - that's the output socket which may (or may not in some cases) be isolated from the input.
If it were static, you would feel a quick sharp sensation and probably hear a click through the PA. If it is a tingle that lasts for more than a fraction of a second then it is leakage.
This leakage is normal in a double insulated system.
The worrying thing is that your Laney monitor is supposed to be grounded which should ground the rest of the system. I'd check that the metal surround on the input jack connector is actually connected to ground.
Posts: 16993 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Re: Shocks from mic
"The lack of a good connection to earth somewhere in the system would have amounted to a system in which one further fault could make the system potentially lethal?"
Definitely Ian. Our safe electrical system relies on layers of protection each one of which is a very unlikely failure scenario. Your microphones do not seem to be bonded to earth and so in the unlikely, but possible event of something going live to chassis, 'possibly' a fuse/trip will not operate.
The XLR pin one should read low resistance to mains earth (or, simply check with a DMM for mains voltage twixt p1 and earth. If those test show no continuity, make some.
That could of course result in the mother of all hum loops but if so you need to rethink and reconfigure the system.
If the XLR are bonded then the only conclusion I can come to is that the mains earth is missing or high resistance? However, if that was the case I would expect hum issues with such things as guitar amps.
Something has entered brain! Have you checked that the body of the microphone is actually bonded to pin 1? It is possible that the makers rely on the XLR shell being earthed and thus the body and grill can 'float'.
Re: Shocks from mic
Post by ajay_m »
Capacitive leakage from double insulated power supplies is very common. The design of the PSU is intended to ensure that it will remain electrically safe but the resulting leakage current can be quite perceptible.
The main risk is to sensitive mic preamps which can easily be damaged by plugging mics in with power on in this situation.
I have not tried the numerous low cost signal isolation transformers available on Amazon or eBay with mic level signals though they do work quite well at line level. They are extremely cheap and possibly worth trying although you'd need to make or buy XLR adaptor cables to the 3 pin headphone mini jack's they use.
Obviously this isn't a safety mitigation, just removes an annoyance.
ajay_m
Posts: 1683 Joined: Mon Jan 16, 2017 7:08 pm
Re: Shocks from mic
Post by ian2 »
James - Unlike the guitar-oriented GI100, the Behringer DI100 has two input sockets; a 1/4 inch jack AND an XLR. You can see them both here: https://mediadl.musictribe.com/media/PL ... er1_XL.png
I got out my multimeter at lunchtime. There was no continuity between the metal surround on my Laney CP12 wedge monitor's input jack socket and the ground pin of its mains power socket. Out of curiosity, I found that there was no continuity between the metal surround of the input jack connector and the similar connector for the wedge's LINK socket. (I figured there ought to be continuity?) I then found that there is continuity between the inner part of the wedge monitor's input jack socket and the ground pin of its mains power socket. Forgive my layman's tentative interpretation of this, but would it seem that the input jack socket's line and ground connections have been transposed?!! Is this the culprit?
ian2
Re: Shocks from mic
ian2 wrote: Mon Jul 04, 2022 11:21 pm James - Unlike the guitar-oriented GI100, the Behringer DI100 has two input sockets; a 1/4 inch jack AND an XLR. You can see them both here: https://mediadl.musictribe.com/media/PL ... er1_XL.png
That's weird - what is the point of an unbalanced XLR input? Weirder still, Behringer claim that it is balanced on their advertising which is obviously wrong if the markings on the DI box are to be believed.
ian2 wrote: Mon Jul 04, 2022 11:21 pm I got out my multimeter at lunchtime. There was no continuity between the metal surround on my Laney CP12 wedge monitor's input jack socket and the ground pin of its mains power socket. Out of curiosity, I found that there was no continuity between the metal surround of the input jack connector and the similar connector for the wedge's LINK socket. (I figured there ought to be continuity?) I then found that there is continuity between the inner part of the wedge monitor's input jack socket and the ground pin of its mains power socket. Forgive my layman's tentative interpretation of this, but would it seem that the input jack socket's line and ground connections have been transposed?!! Is this the culprit?
I've just checked the CP12 service manual and it certainly looks like the input should be grounded. However, one thought occurs to me - what sort of cables are you using between the mixer and the monitor? I wonder if Laney are using the tip of the input connector for the signal and the ring for ground instead of the sleeve?
If you were to use a standard unbalanced cable between the mixer and monitor with TS jack connectors the mixer would be grounded. If you use a balanced cable between the mixer and monitor the ground connection wouldn't be carried through to the mixer and you would end up with no ground in the system.
Re: Shocks from mic
On the DI100, the XLR input socket has pin 2 connected in parallel with the tip connections on the TRS input sockets, whilst pins 1 and 3 are connected together, as are the R and S of the TRS inputs, to the common input ground bus.
So you are losing the balanced signal aspect of the mic operation by using the Behringer DI100 between the mic and the DI box. The XLR output on the box does give a balanced output back to (in your case) the mixer. But as the XLR output signal is significantly reduced in level, your mic signal could end up very noisy indeed with the extra gain required and the initial unbalanced cabling picking up more noise than a balanced connection.
The ground lift switch (as expected) either connects or disconnects the ground bus connection of the output side of the DI box to the input side.
As the mixer doesn't provide a solid ground connection itself, you are then reliant on the power amp/active speakers the mixer outputs are connected to, to provide a reference ground. And it all depends on the power amp or active speakers as to whether the ground connection is connected to earth, or left disconnected in order to avoid a ground loop.
And if the ground lift button on the DI100 is operated, then there won't be any ground connection to the mixer side of things anyway.
So you are then reliant on the powered monitor providing a ground.
According to the schematic for the monitor, it should do.
What I think you have measured ground from on the CP12 is the chromed plastic socket on the TS input and link jacks which have no connection to ground, they are just there to look pretty!
But there should be a connection from the S connection of the socket to ground, so I'd stick a TS (or TRS) jack cable in the socket and measure from the S on the unused end of the TS (TRS) cable to the earth pin of the mains plug.
What I can't tell from the CP12 schematic is whether the mains earth connection only goes to the speaker chassis, or whether this is also connected to the signal ground. It does look like there may only be a virtual ground via a central tap on the secondary side of the mains transformer (presumably in an effort to avoid the monitor being the source of a ground loop).
It may well be the Laney that's providing the floating voltage on the mic, rather than the mixer if you don't get the tingling when only using the mixer.
Posts: 19211 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Re: Shocks from mic
James Perrett wrote: Tue Jul 05, 2022 12:54 amThat's weird - what is the point of an unbalanced XLR input?
It's there because they've been 'heavily influenced' in their design by the BSS AR113 (and previous generation DI BSS boxes). BSS provided the XLR input for easy connection to pro line level sources... but the reasons for it being unbalanced seem lost in the musts of time! The XLR is definitely wired unbalanced in both cases, with pin 3 tied to pin 1 (gnd).
It all depends what you mean by 'the inner part' of the socket. It's not unusual to have jack sockets where the securing nut is electrically isolated from the grounded sleeve terminal.
Re: Shocks from mic
I'm not sure if we know just what mics you are using, apart from it's not an SM58.
If they are budget SM58-alike types, I've bought a few to see what they are like and have found some weird and wonderful wiring schemes. A lot seem designed to work with an unbalanced TS jack connection (sometimes supplied with the mic and sometimes not).
I notice in Hugh's quote of yours above that I missed your reference to the S connection of the Laney input jack being connected to earth, so in theory the mic should have a good ground reference. I'd be tempted to try and measure the resistance from the mic grille to the Laney power plug earth pin with the system set up as you first described. There should be a good path to ground. If not, unplug the mic and check pin 1 on the mic-end XLR to the Laney mains ground pin.
If that is fine, then there's a bad ground connection in the mic. Though if it's a painted grille, then you might not register anything.
Re: Shocks from mic
Post by ian2 »
Last night, I found that with either a TS or TRS cable plugged into the wedge monitor's LINE input (thanks for that great tip, Wonks!), I found that there is continuity between the S (sleeve) and the wedge's mains socket's earth pin. (Please therefore disregard my now apparently obviously incorrect attempt on Monday to establish that.)
There was the question of what type of cables were being used to connect my on-stage Phonic MM1002 mixer to the Behringer DI100 DI boxes. The answer is regular TS guitar cables, i.e. unbalanced.
@Wonks: FYI the mics are Sennheiser dynamics. If Mike Stranks has the memory of an elephant he will know the model number, but it was about 11 or 12 years ago that he helped our church upgrade its PA equipment so, in my case, I'd have to boot up an old PC to stand any chance of finding an email with that info. (My previous PC has been kept because it has lots of unfinished recording projects on it, which I'd imagine may remain unfinished indefinitely...!) The mics have a black grill and I'd imagine that it's metal that's been painted. If the model of mic is one that's still made it looks like it would be e835 or e845. All of the church's PA gear is behind three locked doors 24/7 except for the Sunday morning service, which poses a real challenge to verifying that good earth connections are present where expected.
ian2
Re: Shocks from mic
Dumbo here... :lol:
I expect that the mics are Sennhesier e845s... they would have been my mic of choice/recommendation back then.
Re: Shocks from mic
No problem with the mic’s own XLR wiring then unless a wire’s come loose inside (which can happen).
Re: Shocks from mic
Post by DGL. »
Regarding capacitive current leakage my old laptop was terrible for that, the metallised top cover would become uncomfortable for touch if any of the ports were plugged into a grounded device, i.e. audio out to my mixer or connecting an external display.
I also have issues with my newer laptops that do have grounded supplies in that if I connect them without plugging in the PSU to my Panasonic radio at work it messes with the touchscreen and touchpad and makes the metal case feel weird.
DGL.
Posts: 2321 Joined: Fri Oct 28, 2011 12:00 am Location: Portland, Dorset
