Crackling at low latencies on M1 Mac, recording audio with no plugins
Wondering if anyone has suggestions for this bugaboo:
I'm getting intermittent pops and crackles at low latencies on a machine that should be able to handle a decent workload at low buffers.
I need the low buffers for live overdubbing without latency.
Worse, the crackles end up in the recording; it's not just a monitoring issue.
Equipment:
- M1 Max Macbook Pro, 64GB Ram
- Motu M4, latest driver / firmware
- Mac OS 12.4
- Reaper 6.59 (also happens in Logic, seemingly less)
Test case:
- In Reaper
- Recording two audio tracks: a mono vocal and stereo piano
- No plugins
- 44.1kHz
- no other CPU intensive processes running in the background
Result
- crackles occur below a buffer of 1024 samples
I've done everything I can think to do (updates, checking connection, restarting), and it's driving me crazy!
Any troubleshooting/diagnostic suggestions appreciated.
Equipment:
- Mac OS 12.4
Test case:
- In Reaper
- No plugins
- 44.1kHz
Result
Re: Crackling at low latencies on M1 Mac, recording audio with no plugins
This sounds like driver issues to me - does the M4 have an Apple silicon native driver?
Indeed it does: https://motu.com/en-us/news/motu-and-macos-big-sur/
Some drivers require disabling the new hardened runtime, but I don't believe this one does.
It just occurred to me that this could be an electrical problem, and that the buffer size issue could be a red herring.
If it were electrical, I would expect constant noise of some kind, though, right, whether hum or crackle?
I do occasionally get a kind of quiet "nyeaahh" noise (pitched around 400Hz if memory serves) that seems to pass through the system -- it's less frequent, and I assume unrelated. I haven't had the DAW recording during that one, so I'm not sure if it's just in the monitors or the interface.
Electrical connections: Wall outlet --> power line conditioner (3 prong) --> keyboard, speakers, monitor, mac (all 3 prong, except keyboard, which is 2).
Not intentionally trying to complicate things, just trying to check all possibilities...
Do you get the same issue with both speakers and headphones?
It might be worth starting with the simplest set up you can, i.e. Macbook on battery, M4, headphones, then adding components back in one at a time to see if something is triggering it - either a ground loop or a lack of a ground.
Posts: 29634 Joined: Sun Jul 05, 2015 12:00 am
The battery idea is excellent, thanks -- the keyboard can even run on batteries, so I may start completely unplugged! (Though I still suspect it's buffer- or driver-related.)
If it goes away when you set the buffer size above 1024 samples, then I really don't think it's electrical noise related.
On a Windows machine, I'd suspect some other program hogging the processor, but I have no idea if this can happen with a Mac.
Got any hardware monitoring programs to view processor % usage when you get the crackles? If you aren't hitting 100% (or very near it) then it's not classic processor overload dropouts.
OSX has an 'Activity Monitor' app built in which monitors the hardware in real time.
Forum Aficionado - Posts: 22845 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
There’s no way an M1 machine should struggle with a load like that. If it goes away with higher buffer sizes, then it can’t be electrical, radio interference or ground related.
I don’t know much about the technology of digital audio, but does the fact that the crackles get recorded suggest there is a problem with what’s coming into the Mac - ie are the crackles being output by the A to D converter? I don’t know though, maybe incoming signals enter some kind of buffer on the Mac before being recorded, in which case the above is completely wrong.
In any event, something is wrong. Do you have another audio interface you could use to see if it works?
Would totally agree. Have you got access to any other interface so you can test? I'd try changing the cable too because that's scuppered me a few times in the past.
- Dave Rowles
Posts: 1580 Joined: Thu Feb 28, 2008 12:00 am
To the OP, if you go onto the Motunation website, you'll find quite a number of people with similar issues when using Apple Silicon Macs and MOTU hardware. No definitve solution but some have successfully changed cables, even replaced the unit itself etc etc. Maybe worth a read?
An M1 Mac would eat that - so the problem will be to do with the interface or connection cables.
Have you switched out all the cabling? How’s the keyboard attached? Via line input or USB? If line input what levels are you recording at? If you’re recording keys and vocals at the same time, is the crackling on all tracks or just some?
- Bob Bickerton
Longtime Poster -
Posts: 5610 Joined: Fri Dec 20, 2002 12:00 am
Thanks to all for the suggestions and confirmation that this shouldn't be happening.
Lots of permutations to try, so I'm going to take a beat and work on those.
If I meet with success, I'll report back what worked!
Just thought I'd update this with results, in case anyone comes to this with a similar issues, and to say thanks for suggestions.
I did switch the M4's USB cable, and things seem to have improved.
I had been using a USB-C to C cable, and now, surprisingly, I'm using a USB-C to A-with-adapter-back-to-C (because it's all I had available).
I'm at a buffer size of 32 samples now, getting almost no clicks (every ~10 minutes instead of every 30 seconds) recording a couple of tracks of audio -- but still not none.
I wish I could understand *why* the USB cable would make a difference, so that I could remedy this completely -- but I'm also not 100% sure that all the clicks were the result of the cable.
Whenever I've heard one, I've tried to immediately open Activity Monitor, and the only thing I've noticed so far is that sometimes I have an automated backup running.
This should still consume only a fraction of the CPU I have available, so I'm not convinced that that's the cause, either.
The other thing I've done is unplug my Time Machine backups while recording.
So, hooray for progress, but too bad for remaining ambiguities. If the problem continues, I hope to get enough data for a definitive solution!
Thanks to all for troubleshooting with me.
It isn't so much down to CPU but more down to whether it locks out any other interrupts or prevents any system calls from happening. If a badly written low level routine prevents anything else from running for half a millisecond then you'll end up with an interruption to the audio stream. 32 samples is very low in my experience with Windows although I don't know if the Mac works differently. It would almost certainly be safer to use 64.
Posts: 16923 Joined: Mon Sep 10, 2001 12:00 am
It may well be that the USB C to C cable wasn't well made, or possibly damaged, and even though USB2 rather than USB3, some of the signals were getting corrupted and so rejected.
What you are left with are the odd dropouts due to the processor occasionally being too busy, as James says. You either need to spend time tracking down what process is occasionally holding things up, or else swap to a 64 sample buffer size.
What sample rate are you running at? Raising that will lower your latency.
Doing that will put more work on the processor. But if it's another program that very occasionally just holds an interrupt for too long, and the processor is otherwise coping with the audio, then you might get away with it.
Indeed, but I think we've established that the processor isn't particularly stressed. So the buffer could be raised and offset slightly by a sample rate rise if the OP is using 44.1 or 48.
Re: sample rates, I'm at 44.1 -- so good idea! Isn't it true that higher sample rates come with some side effects (besides file size)?
Mic dust crackles wouldn't manifest similarly to buffer-size crackles, would they? The mic wasn't in use for a number of months prior, and I didn't store it following best practices (now I do!).
Doubling from base to 88.2 or 96kHz is very unlikely to cause any kind of side-effects. I understand there might be some if you start going to 192 or beyond but I can't remember what they are. I'm sure a search of the site will find the answer that Hugh wrote about it a while back.
I don't think so, condensation on a mic (or the dust attracted by that) tends to sound different to dropped samples.
Your processor has to work harder at higher sample rates, so if you are using a lot of processor-hungry effects or instruments then you may need to keep an eye on your processor loading. But on a modern computer, that is generally going to be a lot of effects/instruments before it even breaks into a slight sweat.
And doubling the sample rate doubles the recording file sizes, but unless you are working with a nearly full drive, then that too shouldn’t be an issue these days with such large drives available.
I don't think the difference in latency between a buffer of 32 samples and one of 64 is going to be significant. The difference between the two is less than a millisecond. Try 64 samples and see if that fixes the problem.
Well, curiouser and curiouser!
I tried upping the sample rate to 96kHz at a buffer 64 samples, and immediately got my crackles back, in spades! (Also, just to be clear, the latency issue is secondary to the crackles, since I'm already below my tolerable threshold of about 10ms.)
Checking the activity monitor showed CPU usage around 50% from Reaper -- which seemed high to me, considering I'm doing a minimal test of audio-only recording -- but still not high enough to cause buffer issue. No significant competing processes appeared.
I have a new USB cable on the way, but given the direct correlation between the sample rate and crackles, I'm guess this is actually an issue with the Motu M4 driver or Reaper.
I'm going to fire up Logic with the same settings, to see if I can winnow it down.
