Re-install of W10 created Widows.Old file that I cant delete!
Post by Baldo »
So how do I delete this file from my C drive. its about 12GB.
When I try to delete it, I Am told that I need admin rights. I do have admin rights.
There is also another file from a previous reinstal of W10 and that is about 2GB. I have tried various widows utilities to try and get rid of this folder but nothing seems to work.
The best way seems to be to boot the system via Linux or take the SDD drive out and connect it to my laptop and then try and delete the file from there.
Any ideas?
Baldo
Posts: 287 Joined: Thu Dec 12, 2002 12:00 am Location: Germany
"Never put a recording studio in your home, it is a black hole into which you can pour unlimited amounts of money" Pete Waterman.
Re: Re-install of W10 created Widows.Old file that I cant delete!
Post by Baldo »
And when I try to use rmdir in dos I just get access denied.
Baldo
Post by Exalted Wombat »
Run Windows Tools/Disk Clean up 'as Administrator'. Make sure Windows Update Clean-up is selected.
Exalted Wombat
Posts: 5831 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
You don't have to write songs. The world doesn't want you to write songs. It would probably prefer it if you didn't. So write songs if you want to. Otherwise, dont bore us with beefing about it. Go fishing instead.
Been there, done that. You can only remove it with a tool. IIRC Glary Utilities can remove it - there's a free version.
Posts: 20926 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
If you go to settings > storage you should see an option there.
Guide here: https://www.bing.com/search?q=how%20to% ... 7613963963
Posts: 27698 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by Watchmaker »
The Bing walk through is incorrect for build 19042...Settings>System>Storage>Temporary Files..
Watchmaker
Posts: 1245 Joined: Wed Apr 13, 2016 12:00 am Location: Upstate NY, USA
Where does sound exist?
Post by Baldo »
I downloaded the glary utility but I get the error
Windows cannot access C:\.......gup5setup.exe
I even tried to run it as Admin.
I get the error code 0x80070043
Baldo
I've been using Glary for a long time. That file looks like the initial installation file, so I wonder if the install hasn't worked/completed for some reason. I would uninstall and re-install.
Post by Baldo »
There was no installation. I clicked on the file that I downloaded and got that error. It wont even allow me to install it.
Baldo
That file you're referring to above is the installation file. But your system is saying that it is no longer where that link says it is.
Go download it again and run it.
Failing that - here is the latest version: https://www.dropbox.com/s/spcgt6rz27g0o ... 0.exe?dl=0
Post by Baldo »
Great. Thanks.
Done,
mangaged to install it now.
Did a disk cleanup.
How do I force it to delete a specific folder?
Baldo
As long as you let it do its full clean up hopefully you should be fixed - at least that's how I clean mine up after a big upgrade.
Post by Baldo »
I did a ful clean up but those folders are STILL there.
There MUST be a way to get rid of them.
Baldo
Heck. Well, at that point I'll bow out. Glary removed it for me.
You could try this :https://support.microsoft.com/en-us/win ... 67d69dbb74
Baldo wrote: Mon Jul 25, 2022 12:24 pm I did a ful clean up but those folders are STILL there.
Have you tried going through the settings > storage option? I worked exactly as it should for me a couple of months ago.
Post by Baldo »
I tried going through the settings>storage options.
I always get the error that those files require me to have admin access. I AM logged in as an Admin. So I can't understand why it will not allow me the access to delete those files.
Baldo
Hmm. Vexing.
Have you tried microsoft support? If you get them on the web-chat they can be quite useful.
As above. This is not sounding like an issue with deleting the files, per se, but more like a permissions problem.
I could say I've used a utility called 'Take Ownership' to fix these kinds of problems in the past, but at this stage I believe a chat with Microsoft would be the wise move.
Post by Baldo »
I had a chat with MS before. Infact, when they told me to reinstall the OS, that is when the problem first appeared.
Certainly sounds like a permissions issue.
My inclination is to install a Linux disto on my machine and then boot into that and from there delete these damn files.
I should have had a linux distro on the machine anyway. I use to have one on the machine just in case windows decided to do funn things.
I also have had the issue of the machine shutting down at random. Still dont know what caused that and am in the process of flashing the BIOS (that's what MS said may be the issue!!!)
Baldo
Post by merlyn »
Baldo wrote: Mon Jul 25, 2022 8:01 pm ... I AM logged in as an Admin. So I can't understand why it will not allow me the access to delete those files.
If I remember correctly even if the account you are using is an admin account, that still doesn't give the user all permissions. It's required to open applications 'as administrator'. I remember right-clicking and choosing 'open as administrator' or 'run as administrator', something like that, as an option.
merlyn
Posts: 1498 Joined: Thu Nov 07, 2019 2:15 am
Post by Baldo »
Yea, I did that Merlyn. I opend CMD as admin and still get access denied.
I think Linux may be the way to go.
Baldo
There are ways to run an OS, including Linux, from a USB stick. That might provide a solution.
