SOS Technical Glossary
Re: SOS Technical Glossary
Sone thoughts on potential entries:
Granular synthesis
Grain
EQ (some people may not know this means equaliser)
Automation
Fade in / out
Masking (psychoacoustic)
Pre-master
Clip gain
Normalise (as in adjust level of audio)
De-click
Quantisation noise
Array (microphone)
Source-destination edit
Three point edit
Four point edit
Rectifier
Comping
Null
Streaming
Destructive (editing)
Edit list
Mixdown
Floating point
Disk image
Distributor (as in cd-baby etc)
Royalty (streaming)
Granular synthesis
Grain
Automation
Fade in / out
Pre-master
Clip gain
De-click
Quantisation noise
Array (microphone)
Three point edit
Four point edit
Rectifier
Comping
Null
Streaming
Edit list
Mixdown
Floating point
Disk image
Royalty (streaming)
Tiz a never-ending challenge!
All good ideas. Thanks Richard. I'll try and work through them.
Posts: 41743 Joined: Fri Jul 25, 2003 12:00 am
There goes Hugh's weekend!
Posts: 27706 Joined: Sun Jul 05, 2015 12:00 am
Surely the destruction of banjos should be banjaxed?
Posts: 21477 Joined: Wed Jan 13, 2010 8:44 am
Plate Reverb
Spring Reverb
(Or do some kind of grouping under 'Reverb')
Multitap Delay
Head Block
Tension Arm
Capstan
Pinch Roller
De-Gauss
Magic Eye Valve/Tube
Main types/configurations of valves
Acoustic Camera (aka Sound Camera though for me that refers to a movie film camera that records sound onto film, either with picture or separately)
Infrasonic
Ultrasonic
Cycle(s) per second
Matrix/Mat Number (as found on vinyl)
Pre-echo/Post-echo (maybe link to Print-through)
DSD
DXD
SACD
Ravenna
AES67
Cans
Cassette / Compact Cassette / Musicassette
Elcaset
R128
Elliptic/Elliptical EQ/Filter
Phased-array (Clarification that it has bog all to do with mic techniques!)
Phase aligned (in speaker marketing!)
It rained a lot today!
Spring Reverb
Multitap Delay
Head Block
Tension Arm
Capstan
Pinch Roller
De-Gauss
Infrasonic
Ultrasonic
Cycle(s) per second
DSD
DXD
SACD
Ravenna
AES67
Cans
Elcaset
R128
- forumuser840717
Regular - Posts: 476 Joined: Thu Jun 16, 2016 5:20 pm
Well, that's November taken care of, then!
Thanks
Thanks
Maybe of more relevence to broadcasting than recording, but "Nicam"?
Good idea.
Although there are several variations of NICAM used in several different contexts.
And there's still a number of other items on my 'to add' list.
I didn't know that was still a thing. I kind of assumed it had died out with video tapes. I didn't realise it was still used in broadcast and video codecs.
What a marvellous modern world we live in.
I don't know if NICAM is still in use somewhere around the world, but modern digital networks have largely made it obsolete.
However, it was a very clever design that illustrates all four principles of data reduction very nicely, so its worth including in the glossary for the educational value.
Hugh Robjohns wrote: ↑Mon Jun 05, 2023 10:03 pm I don't know if NICAM is still in use somewhere around the world, but modern digital networks have largely made it obsolete.
Indonesia maybe? Though they're switching off it apparently. My quick browse of wikipedia skipped over the fact that it was mostly redundant now.
Also can I put in a request for inter-sample peak to be added please?
You can... and I will. But it won't be for a couple of weeks as No1 daughter gets married at the weekend and then I'm away on holiday.
Congratulations to N1D!
The following need defining please..
1. That's bangin' mate
2. Wos the Air Band mate?
3. Mate
3. Mate
Amen to that. Muchos congratulados.
- shufflebeat
Longtime Poster - Posts: 9640 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Particle velocity
Interaural level difference
Interaural time difference
Beat (https://en.m.wikipedia.org/wiki/Beat_(acoustics))
- PedroTheThird
Poster - Posts: 44 Joined: Tue Oct 22, 2024 10:56 pm
