Hugh Robjohns wrote: ↑Fri Aug 05, 2022 1:08 pm
Don't think that's available any more. Studiospares do sell the Furman power sequencer, though for about £500... except it's currently on back order.
Hugh, in the September 2021 Q&As you mentioned an Energenie 8 way wireless strip.
I would guess that would last more than 2 years but even if not, half a bag buys a lot of backups!
Posts:5845Joined: Sat Feb 06, 2010 12:00 amLocation: London UK
Folderol wrote: ↑Thu Aug 04, 2022 5:23 pm
Absolutely DON'T do that
Why? It exactly emulates what we all think the problem is.
No it doesn't. The switch is designed to be able to handle arcing. The plug pins are not, and will develop pits and poor contact. I wouldn't attempt this once, even just 'to see if it's OK'. Also I have seen the result of this sort of damage. It was in a relatively safe environment. I wouldn't like to see the same in someone's home.
