One Synth Challenge #7- 2022 Edition
Re: One Synth Challenge #7- 2022 Edition
Post by MarkyC »
I always loved these but unfortunately I’ll be way most of that period.
Whenever we have done these before I always took it as a bit of fun to really try and push my knowledge, see what could be done rather than produce soothing stunning. And whilst I marvelled at what some of you guys can do, I always smiled most at the absurd tracks….
MarkyC
Posts: 206 Joined: Mon Dec 08, 2008 12:00 am Location: London
OneWorld wrote: Tue Aug 02, 2022 3:51 pm
fatbenelton wrote: Tue Aug 02, 2022 10:52 am You could do the ‘reveal’ at SynthFest and if you wanted a competition think in terms of Joe Public guessing the most correct instruments used rather than the pieces themselves.
That’s my point, it’s a presentation, not a prize
I think you may be underestimating the size of Synthfest and over-estimating our importance in it! :D
Post by nickle15 »
Thanks so much for reviving this great event! I'm in, this will be my second time around. :D
nickle15
Posts: 382 Joined: Mon Dec 16, 2019 4:29 pm
Mine is already underway! ;-)
Posts: 9977 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Post by Rich Hanson »
I haven’t started mine yet but I have an idea…
Rich Hanson
Posts: 3686 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
I have an idea too.
It's a ridiculous idea, but I'm going to give it a go.
Ridiculous ideas often turn out pretty good. Get to it, Stephenson!
Rich Hanson
Post by fruitcake »
I’ve missed the last couple. I may miss this one too. I’m a long way from home on a work project. But I do have a laptop, an audio interface, a city with pawn shops and an hour or two.
fruitcake
Posts: 323 Joined: Sun Apr 22, 2018 4:32 am Location: Beautiful Downtown Burbank
Here are some Unfinished Sounds.
Post by Atheen »
Might have a go at this using one of the Arturia soft synths. Need to have a listen to some previous entries first though, to get an idea of what you guys are up to.
Atheen
Posts: 4 Joined: Fri Sep 08, 2017 10:31 am
Post by OneWorld »
blinddrew wrote: Tue Aug 02, 2022 4:15 pm
I thought Sound on Sound created the whole thing?
OneWorld
Posts: 5959 Joined: Tue Apr 07, 2009 12:00 am
OneWorld wrote: Sat Aug 06, 2022 1:29 am
blinddrew wrote: Tue Aug 02, 2022 4:15 pm I think you may be underestimating the size of Synthfest and over-estimating our importance in it! :D
They did but the forum, while valued, is a mere fragment of the Sound On Sound universe ;-)
Rich Hanson wrote: Fri Aug 05, 2022 10:10 am Ridiculous ideas often turn out pretty good. Get to it, Stephenson!
Absolutely! My track is one I'd probably not find a use for in any other context. It's 'out there', great fun and it turns out one of my synths is perfect for it :D
I was thinking of having go at a version of 4’ 33”, but I don’t have a suitable synth.
Post by IAA »
My old Roland SH 09 would have done that no probs!! In fact it could do an album of similar. :bouncy:
IAA
Posts: 1621 Joined: Fri Dec 28, 2007 12:00 am Location: York
Having a bit of a struggle at the moment. I had one of two hardware synths in mind, but one is proving to be a pig to set up voices, and the other is showing it's age sound quality wise.
Definitely not going to try the SY35 again - the problems last time I'll regard as a warning :?
Posts: 20880 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Post by BJG145 »
I'm in. :thumbup:
Posts: 8087 Joined: Sat Aug 06, 2005 12:00 am Location: UK
Vexingly it would appear that the VCA on my synth is faulty and, in this case, renders the whole thing unusable for this task.
blinddrew wrote: Sat Aug 06, 2022 3:33 pm Vexingly it would appear that the VCA on my synth is faulty and, in this case, renders the whole thing unusable for this task.
As I'm not doing it now, you could have a go at 4'33" yourself.
It's an option.
I mean, technically, it is an option.
Post by adrian_k »
Wonks wrote: Sat Aug 06, 2022 5:07 pm
I was thinking of doing it myself, but with the added difficulty of playing it backwards. However, my post-Covid breathing is too noisy.
I’ll get back to my lurking now….
adrian_k
Posts: 3813 Joined: Thu Jan 30, 2003 12:00 am Location: Gloucestershire
Life is wealth. (John Ruskin)
Post by sonics »
I was going to ask about the rules, but then found the sticky thread. :headbang:
I have far too many soft-synths, but I have tried to produce at least a complete piece or two with each one just to find out what I like about them, if anything.
I could enter one of those tracks, but since I've just ordered my first new hardware synth in about twenty years, that should probably be my choice! :D
sonics
Its a bit early season for me but if I can find the time Ill put an entry in.
Can we have at least a few days after publication to listen to the tracks before the clue phase begins ? It all seemed over so quick last time.
Well, I was going to try the QS300, but it's not just the display backlight that's dud. I can't get anything out of the bottom octave and a half keys :(
This is weird. It will send MIDI out in that range from the keyboard, and will receive MIDI to it's internal banks. It could be some obscure setting, although I've never tried to do this. Also there is no official factory reset mentioned anywhere in the manual, and the two suggestions I've seen on the 'net seem to set a lot of stuff but make no difference to this.
Frankly I've run out of patience with it, so if anyone wants it let me know, you can have it for free.
Post by Aled Hughes »
I was going to, but unfortunately I found the power supply.
Aled Hughes
Posts: 2136 Joined: Tue Oct 24, 2006 12:00 am Location: Pwllheli, Cymru
What I thought I might do once all submissions have been received is to publish the music along with two lists - one of the contributors and the other of the synths used. I thought this might give people a fighting of chance of getting at least a couple right :D
Rich Hanson
