If you do this, hire an experienced engineer too!
Audio interface and mic for male vocals
Re: Audio interface and mic for male vocals
- Exalted Wombat
Longtime Poster - Posts: 5846 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
Oh definitely. I'd just be wasting money hiring a studio without also hiring an experienced engineer who knows what he's doing!
Personally I'd be looking at the Neumann range. I've used the KH120s a few times and found them good. The smaller KH80s are supposed to be even better in many respects and are also supposed to work well with the Neumann sub if you need more bass.
Posts: 16929 Joined: Mon Sep 10, 2001 12:00 am
Focal Alpha range are very good.
- resistorman
Frequent Poster - Posts: 2976 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Two excellent suggestions. Also, if you have a particular pro studio in mind it could be worth visiting them to see what monitors they use?
They will probably be very expensive monsters (most probably more than one brand) but if say drool inducing Genelecs you could find a smaller version that will likely have the 'house sound'.
The studio might even have a very small but good pair that they use for location work...ask.
James Perrett wrote: ↑Sun Aug 07, 2022 3:40 pm Personally I'd be looking at the Neumann range. I've used the KH120s a few times and found them good. The smaller KH80s are supposed to be even better in many respects and are also supposed to work well with the Neumann sub if you need more bass.
Thanks, I'll check them out. The KH120s are a bit pricey at £1,200/pair but the KH80s are more affordable at £720/pair and as you say, I can always add a sub in future if I can properly utilise it in my space.
I actually added the Focal Alpha Evo 65 to my list recently after reading glowing reviews of them. At £520/pair they're £200 cheaper than the Neumann KH80s and the 6.5" woofer is bigger than the KH80s (4") and the KH120s (5.25"), but I don't mind paying the extra for the KH80s if they're noticeably better for my purposes.
It was also said that the Kali LP-6 or the JBL LSR305 are 90% as good as the Evo 65s at 20% of the cost, although that's not true anymore (if it ever was) as the LP-6s are £300/pair and the LSR305s are £240/pair.
ef37a wrote: ↑Sun Aug 07, 2022 5:21 pm Two excellent suggestions. Also, if you have a particular pro studio in mind it could be worth visiting them to see what monitors they use?
Thanks, that's a good idea.
When I auditioned a few things a couple of years ago the KH80 were, to my ears, the best in the price range.
Posts: 29638 Joined: Sun Jul 05, 2015 12:00 am
Doveman wrote: ↑Sun Aug 07, 2022 2:23 pm ……….. or spending thousands on excellent full-spectrum monitors and room treatment. It makes more sense to do what you suggest and then hire a studio with expensive speakers and room treatment to do the final mix.
Are there any particular monitors that you can recommend?
I’ve been following this thread and the above reply rang alarm bells for me.
If you’re recording vocals in an untreated room you’ll have a significant problem! Room treatment really needs to be near the top of your ‘purchase list’.
At the beginning of the thread you were also looking at a vocal microphone. I don’t know if it was covered earlier, but the quality of the interface pales into insignificance relative to microphone choice and room treatment. Did you buy the Aston?
Regarding interface I’ve never had a problem with latency and it’s a good idea not to commit any effects on your (self-recorded) vocals on the way in - so probably all you need is some comfort reverb for tracking and I’d have thought most interfaces would offer that with minimal penalty.
Regarding interfaces, I’m a UAD Apollo user and, as said above, I only use reverb for monitoring. No problems there, but I do have a range of vocal mics and professionally designed room treatment. I also happily use an SSL 2 or MixPre 10 as an interface. If I was buying new I’d consider RME based on the very good comments around here, but I doubt anyone listening to my projects would notice the difference as to which interface I used! The point regarding UAD plugs-ins is worthy of repeating. I enjoy them very much, but there are now many good alternatives.
Regarding monitors I swapped out my PMC Result6 monitors for Neumann KH80s and couldn’t be happier - but of course having a treated room helps.
- Bob Bickerton
Longtime Poster -
Posts: 5611 Joined: Fri Dec 20, 2002 12:00 am
Just emphasising Bob's point, I was involved last night in a regular livestream discussion on things audio, where someone posed the question about 'what's the best thing you can buy to improve your sound?'
As expected, there were multiple opinions on this kit, or that kit, or this software, that software, but until I opined, no-one mentioned room treatment. IME getting some room treatment in place - even if not covering absolutely all the bases - is by far the best thing I've done to improve the quality of my sound.
It can be done for much less than some of the figures being discussed here and can be the base on which you then decide whether/not you need to upgrade. Buying kit (more interesting and exciting though it be) without sorting the acoustics is a recipe for wasting money - or at least potentially spending it unnecessarily
- Mike Stranks
There is of course a 'chicken and egg' situation here. You cannot know how good or bad* your room is until you produce some 'quality' sound in it, that is why I suggest the purchase of some really good speakers should be very high on the agenda.
I also suggest early on buying or making some proper stands for the speakers. The temptation is to balance them on a desk, always meaning to do a proper job that never gets done! I am fortunate to have two CD cabinets (in pine effect chipboard) that are 0.84mtr high, have 5, 170mm 'holes' in them for CDs and have a board about 250mm sq top and bottom. These hold my Tannoy 5As at just about ear high for the tweeters. I am sure such cabinets are still around?
*There are no good, small domestic rooms but some are REALLY bad!
https://www.amazon.co.uk/HOMCOM-Adjusta ... 91&sr=8-12
That ^ sort of thing but you'd have to fit a top and bottom.
IME there are very, very few good (or even acceptable) domestic rooms without some form of treatment.
Sort out the chickens... then worry about the eggs!
- Mike Stranks
Mike Stranks wrote: ↑Mon Aug 08, 2022 11:25 am
You may have misunderstood me Mike? I am saying get some first class monitors and then you have a first class sound source with which to sort the room. I am sure there are many here who can suggest/donate suitable tracks.
I'm with Mike in the chicken/egg order.
Even a few duvets will help whether you have modest or amazing monitors.
Only an opinion- I am not a professional studio builder!
https://davylamb.bandcamp.com/
I'd say that basic room treatment and correct monitor positioning are going to make a huge difference. The first you can do before you buy anything else but the second probably needs at least some kind of monitors so that you can experiment with positioning. I've found that raising my monitors up to about 350mm above my desk has massively improved the sound - probably because the desk reflections play less of a part in the sound.
James Perrett wrote: ↑Mon Aug 08, 2022 2:04 pm I'd say that basic room treatment and correct monitor positioning are going to make a huge difference. The first you can do before you buy anything else but the second probably needs at least some kind of monitors so that you can experiment with positioning. I've found that raising my monitors up to about 350mm above my desk has massively improved the sound - probably because the desk reflections play less of a part in the sound.
Ah! I think you are closer to my wavelength James. OP will need an interface to drive the monitors but little else other than some well recorded tracks. He can then start to deal with poor imaging and lumpy bass.
Of course! He should spend several evenings on 'Studio SOS' back articles.
I'd still say that mirror point panels and corner bass traps can safely be built without any monitors as they're always needed. However, if you can mount them in such a way that you can still move them around it would help when fine tuning the treatment with the monitors.
With the greatest respect Doveman, unless you have great experience in such matters I would not bother. I am pretty sure the Top Chaps here. Hugh, Drew, Sam et al will agree with me when I say that monitors in that class are very similar and none are 'wrong' or 'right'.
My hearing is shot so if Hugh or Phil tells me "this monitor sounds great!" I believe them and would be sure I was getting a truly useful 'tool'.
Bob Bickerton wrote: ↑Sun Aug 07, 2022 9:55 pm I’ve been following this thread and the above reply rang alarm bells for me.
I was just agreeing with Dave that it probably makes more sense to get monitors that are excellent for vocal work, rather than getting ones that are better with the lower frequencies, which will either have poorer mids or be much more expensive, and then spending thousands trying to treat a domestic room to make it work OK with deep bass. I wasn't suggesting that the room won't need any treatment to be able to do vocal work, just that it will be a lot cheaper.
I haven't bought the Aston yet. I've also been looking at other mics like the Shure SM7B and the AKG C214 but I haven't decided yet.
Yeah, I wouldn't commit any effects but a bit of reverb, maybe some compression, helps and I think they need to be DSP effects to avoid any noticeable latency.
I was originally considering a UAD interface but I crossed them off when they abandoned the USB interface and went Firewire only. They have DSP effects of course, which the much cheaper SSL 2 doesn't. I'll probably just pre-order the Babyface Pro FS, as I've found somewhere that says it should have stock by August 19.
ef37a wrote: ↑Mon Aug 08, 2022 2:35 pm
I wouldn't necessarily agree with that Dave - different monitors will always have different strengths and weaknesses. Which one you prefer is a matter of taste. I like to have totally lucid stereo imaging which is something that other people may forgo in order to obtain a flatter frequency response.
And some people still think of NS10s as monitors which sound nothing like a typical uncoloured monitor.
Doveman wrote: ↑Mon Aug 08, 2022 2:38 pm I was originally considering a UAD interface but I crossed them off when they abandoned the USB interface and went Firewire only. They have DSP effects of course, which the much cheaper SSL 2 doesn't. I'll probably just pre-order the Babyface Pro FS, as I've found somewhere that says it should have stock by August 19.
Just a correction - UAD interfaces are currently USB or Thunderbolt - not FireWire. https://www.uaudio.com/audio-interfaces.html
The Apollo range have the built in DSP for low latency monitoring with plug-ins. The Apollo Solo is currently 400 quid in the UK.
- Bob Bickerton
Longtime Poster -
Bob Bickerton wrote: ↑Mon Aug 08, 2022 8:35 pm Just a correction - UAD interfaces are currently USB or Thunderbolt - not FireWire. https://www.uaudio.com/audio-interfaces.html
Sorry, I should have checked my own post on the first page! I meant Thunderbolt, not Firewire. All the newer Apollo models, (i.e. excluding the original Solo and Twin) are Thunderbolt, so even though UAD may still support the older models for now, there's a risk they may neglect the USB drivers going forward.
I ruled out the Apollo Solo because its DSP is too underpowered and with the RME at £650 that seems like a much better deal.
Doveman wrote: ↑Sat Aug 06, 2022 7:34 pm Just revisiting this topic as I haven't got round to buying the Babyface Pro yet as it's been out of stock every time I checked, and is still only available to pre-order for £680-700. So I was wondering if there's anything new that's as good (or better) and maybe cheaper or more readily
Studiocare have limited stock of the babyface right now if you’re still looking…
