I have discovered that I have no knowledge in this area, never had to wire any up.
I would be obliged if Hugh or another top bod could give me the full SP for the wiring of an XLR3 to XLR3 cable with cable with say two Blue and Two White conductors.
Star Quad wiring
Re: Star Quad wiring
Here's a good place to start
https://www.soundonsound.com/sound-advi ... quad-cable
Basically you connect the opposite cores together - whether they are the same colour or not depends on the cable construction.
Posts: 16932 Joined: Mon Sep 10, 2001 12:00 am
The two whites are one leg (I put them on pin 2), and the two blues are the other (pin 3).
Posts: 43632 Joined: Fri Jul 25, 2003 12:00 am
Hugh Robjohns wrote: ↑Wed Aug 10, 2022 8:44 pmhttps://www.soundonsound.com/sound-advi ... quad-cable
That's what a chap on another forum said but the diagram I found (lost it!) showed alternate colours paired up.
I shall take your opinion as gospel Hugh!
There are two standards. Dual white/ blue is the most common. Eg. Van-damme starquad (scroll down to the section on Mechanical Spec, Colur Code).
https://www.van-damme.com/wp-content/up ... quad-1.pdf
Obviously, if in doubt check the cable manufacturer's website.... but strapping blue and white together makes no sense on any level!
Personally, I prefer the Beeb's standard of red/blue for +ve and green/white for -ve. Makes it much easier when wiring the cable for stereo applications!
Hugh Robjohns wrote: ↑Wed Aug 10, 2022 9:37 pm Personally, I prefer the Beeb's standard of red/blue for +ve and green/white for -ve. Makes it much easier when wiring the cable for stereo applications!
I take it that’s red/blue left, green/white right?
That would be the sensible option, yes.... unless you're in New Zealand!
Hugh Robjohns wrote: ↑Thu Aug 11, 2022 10:57 am That would be the sensible option, yes.... unless you're in New Zealand!
In which case they're all black...
Posts: 29642 Joined: Sun Jul 05, 2015 12:00 am
