The value of "lofting"
I "lofted" a few things, a few months ago, when I was feeling a bit "wobbly" I gave myself a set of restrictions, and instead of selling some items, I just put them in the loft and forgot about them, I was still able to make the music I make, with no detriment.
Now, I feel like I want to use them again, the good bit is that I’ve actually forgotten all about them, completely, so it’s going to be like opening new things, there’s a great reverb up there, a Moog, and a couple of Behringer synths, which I’m looking forward to reacquainting myself with.
I can recommend this process to anyone who thinks they may be becoming a bit jaded with their set-up, I think it works, some things you thought you would never use, or that didn’t work out first time around, may be given a second more successful lease of life.
Re: The value of "lofting"
Currently I dont have a loft for storage !
I upgraded my insulation wool this summer. 100mm between the joists, 200 mm on top.
There are options to put an elevated area above this but temperature wise, I would be better off putting the stuff in the shed.
My 19" rack on wheels seems to have come back into use recently. It makes a good "island" rather than under desk unit.
My loft was until this summer a platform above the car in the garage.
Now it's a storage unit about a mile away, and a bit of space under the bed.
As I went through a major downsizing operation when we moved there really isn't much to 'loft' now, my live rig stands and cables, live mics, some FX pedals
I don't have a loft either, since I live in a barn conversion
Posts: 22581 Joined: Wed Jan 13, 2010 8:44 am
Dare we say, "We told you so?"
Posts: 29727 Joined: Sun Jul 05, 2015 12:00 am
I had lofty ambitions, to turn it into a studio, everything in order and in place. I went to considerable expense having the loft converted but over time it has become a junk space and I can just about squeeze myself into a corner where I have a keyboard, controller and monitors.
The loft does have at least one redeeming feature though. Given the ever expanding urban landscape and houses now having been built where there used to be open fields, but because the house is near the top of a hill, the view from the loft gives me an unbroken view over the rooftops of the valley beyond. I might go the whole distance and like a neighbour, have a dormer window put in the roof space and make it into a sitting room, essentially the house becoming a 3 storey building - aim high as they say
I’ve stapled rolls of insulating blanket onto the roof beams and then screwed batons on top then stapled thin tongue and groove cladding onto them. You don’t have to do the cladding.
I could and might put music gear up there but the main objective was to have a storage room that wasn’t a freezer in winter and a furnace in summer. Hopefully it will help reduce energy bills too.
I've got insulation between the joists in the loft, and minimal areas of boarding. I've been thinking of stapling insulating blanket over the rafters which should help keep the loft (and top floor of the house) a more stable temperature and cooler on average.
I'd probably have to hire a staple gun - it wouldn't be worth buying one for just that job.
- Folderol
Forum Aficionado -
Posts: 20891 Joined: Sat Nov 15, 2008 12:00 am
I always thought the value of Lofting was a Dolittle.
Andy
Andy
I bought a Stanley heavy duty staple gun at Screwfix for £15.99 and 5000 12 by 10.6mm staples for £7.64. The major cost was the insulation rolls at £120@ each if I remember correctly.
MOF wrote: ↑Thu Sep 22, 2022 4:57 pmI'd probably have to hire a staple gun - it wouldn't be worth buying one for just that job.
Interesting. That's pretty cheap all considered.
What did you do about maintaining some air movement behind the insulation?
- Folderol
Forum Aficionado -
