Coax to phono connector wanted
I have a set of CCTV cameras that I want to test out on a TV
The cameras have a strange kind of coax fitting on them similar but not the same as a TV coax. With no way of posting a photo of it hear, things are very hard to explain, so I will do my best and hear is the model number of the camera Indigovision 2amp box camera BX620-HD-FC Dahua DH-PLZ1040D 2.7-12mm F1.6 VF Lence
The fitting on the TV for it to work (The coax port will not work) is a typical phono port
Any thoughts please?
- Guest
Re: Coax to phono connector wanted
According to
http://www.multiplize.net/indigovision/ ... t-A4_2.pdf
it uses a 75 ohm BNC connector.
I've used this adaptor
https://cpc.farnell.com/pro-signal/psg0 ... csku=false
with some of these cables
https://cpc.farnell.com/pro-signal/psg0 ... t=psg00561
which have worked fine for both digital audio and video.
Posts: 16921 Joined: Mon Sep 10, 2001 12:00 am
There's info here about how to show an image on this site.
https://www.youtube.com/watch?v=s7vVDGTOHW0
https://davylamb.bandcamp.com/
James Perrett wrote: ↑Sun Oct 02, 2022 7:43 pm According to
Great Links!
But will this
Connect to this
I mean I need it to have a cable and not just port to port.
On the
What kind of port is on the other end, if its a femail phono port then it will fit this on you posted
Thanks
- Guest
Yes, the adaptor has a female phono on one end and a male BNC on the other. When you combine it with the cable I linked to it gives you a BNC to phono cable. You can also buy those cables in a variety of different lengths if you want something longer or shorter.
James Perrett wrote: ↑Sun Oct 02, 2022 8:46 pm Yes, the adaptor has a female phono on one end and a male BNC on the other. When you combine it with the cable I linked to it gives you a BNC to phono cable. You can also buy those cables in a variety of different lengths if you want something longer or shorter.
Yes I know about the cable, I have quite a few of them laying round hear gathering dust, my local pound shop in the high street stock a vast majority of them as well. It was just that fitting that I am short on
Thanks!
- Guest
What do you think about this one
https://cpc.farnell.com/pro-signal/rw1- ... dp/CN15992
For some reason its 10p cheaper then the gold coloured one
- Guest
That would probably work - I suggested the others because they are ones that I've actually used.
Hah!! I read a little more of it and it actually says that it is gold plated! so for 10p more you get a small piece of gold trading at around £1500 per oz on the markets. Not to mention gold is a very good conductor or electricity which in this case will mean a better connection and hence a better signal
But sadly I went though the process to order it and they wanted an extra fiver for handling charges
- Guest
Gold isn’t quite as good a conductor as many other metals, but it doesn’t corrode or oxidise in normal circumstances. So there’s a good case for using it where you have a permanent installation that will rarely be disturbed, and where your standard chrome-plated or even plain brass contacts will oxidise over time.
But gold is a soft metal, and will quite quickly wear away where you have connections that are constantly being made and broken. But this making and breaking action will normally remove corrosion through physical wear on chrome, steel, copper etc. contacts. Once the gold plating has worn away, it normally leaves a surface that's far more prone to corrosion/oxidation.
So, gold plating is not always the best choice for connectors, but it’s rarely a bad choice.
About 20-25 years ago, before HDMI came along, as a not-using-fully-pro-gear camera person and video-mixer, I used the adapters as highlighted by James P all the time when needing to interconnect bits of kit. Always reliable and never failed.
If you don't like CPC's handling charges, then you'll find similar on eBay and Amazon. But in many years dealing with CPC I've always found them good value and very customer-focussed on the very rare occasions that things go awry.
- Mike Stranks
I also find that CPC generally stock good quality
reliable components, where it's a bit more hit and miss on ebay and amazon.
Posts: 43616 Joined: Fri Jul 25, 2003 12:00 am
Organ Grinder wrote: ↑Mon Oct 03, 2022 1:51 am But sadly I went though the process to order it and they wanted an extra fiver for handling charges
I usually have a CPC shopping list on the go and send off an order as soon as it gets to the minimum for free postage (£17.50 I think). They sell so much useful stuff.
Wonks wrote: ↑Mon Oct 03, 2022 5:03 am Gold isn’t quite as good a conductor as many other metals, but it doesn’t corrode or oxidise in normal circumstances. So there’s a good case for using it where you have a permanent installation that will rarely be disturbed, and where your standard chrome-plated or even plain brass contacts will oxidise over time.
This is only to test the cameras and line them up so will not be a permanent fixture. But on what you said I think the grey/ silver connect would suit best
- Guest
Mike Stranks wrote: ↑Mon Oct 03, 2022 9:28 am About 20-25 years ago, before HDMI came along, as a not-using-fully-pro-gear camera person and video-mixer, I used the adapters as highlighted by James P all the time when needing to interconnect bits of kit. Always reliable and never failed.
Hugh Robjohns wrote: ↑Mon Oct 03, 2022 9:56 am I also find that CPC generally stock good quality
The problem I have with ebay is a lot of the stuff is rubbish from China
But I have a TLC-direct catalog hear, but I dont know where to look in it for such a part
- Guest
I had a go making up the cable, soldering together a coax cable onto a phono cable. But with out being able to post an image of it hear it is very difficult for you to image what the soldering is like
I tried it on the TV and I now have a signal coming into the TV. But it is just a fuzz
- Guest
TV signals have a wide bandwidth and at the high frequency end the cable construction becomes critical... and welding two dissimilar cables together isn't going to help matters at all. Internal reflections, and weak signals are almost guaranteed.
75 Ohm BNC cables with BNC-phono adapter plugs is definitely the best solution.
https://www.tlc-direct.co.uk/Products/TSBN20.html
Organ Grinder wrote: ↑Mon Oct 03, 2022 8:27 pm But without being able to post an image of it here it is very difficult for you to image what the soldering is like
A link to a 'how to' video...
https://www.soundonsound.com/forum/view ... hp?t=75253
- Mike Stranks
Organ Grinder wrote: ↑Mon Oct 03, 2022 8:27 pm I had a go making up the cable, soldering together a coax cable onto a phono cable. But with out being able to post an image of it hear it is very difficult for you to image what the soldering is like
BNC plugs can be tricky to solder at the best of times, you have to get the screen and core lengths dead right. Much easier to buy a BNC-BNC cable, chop it and fit RCA or whatever to taste.
Hugh Robjohns wrote: ↑Mon Oct 03, 2022 11:01 pm TV signals have a wide bandwidth and at the high frequency end the cable construction becomes critical... and welding two dissimilar cables together isn't going to help matters at all. Internal reflections, and weak signals are almost guaranteed.
I used an old phono cable and a coax cable soldered together
So the higher frequency the better the connection needs to be right? opposed to 50hz DC and AC electric, where I have never had a problem joining wire together
I bit the bullet and spent the extra fiver. So when it arrives you think I should I will have a better signal?
- Guest
Mike Stranks wrote: ↑Mon Oct 03, 2022 11:03 pmOrgan Grinder wrote: ↑Mon Oct 03, 2022 8:27 pm But without being able to post an image of it here it is very difficult for you to image what the soldering is like
I watched your good video. It looks like a image hosting site but it looks like I need to set up an account. There are image hosting sites out there that you don't need an account to host, did you know?
But as the above poster has stated what I have done will likely not work, is there any point at this stage posting the image of what I have soldered?
- Guest
I did not solder onto any plug as I don't have the BNC plug at present
Are you saying this is a frequency thing, where you need to make the length of the wire in tune with the length of the frequency? Bit like cutting a CB aerial?
- Guest
Organ Grinder wrote: ↑Tue Oct 04, 2022 5:18 pm
No, it's not that fussy, just that there are about 4 or 5 parts to a BNC connector and you have to get the wire right or it won't go together or it will short.
- Guest
Organ Grinder wrote: ↑Tue Oct 04, 2022 7:13 pm
Well now I'm confused! I though you had live and earth (or ground)
Ha! Ha! viz...https://uk.rs-online.com/web/p/coaxial- ... rs/5464875
