Recording Sax orchestra live
… is what I’ll be doing on Sunday. My first recording for about 15 years and agreed with the group it’s for my education.
So this group contains everything from Sopranino to Contrabass saxes. The latter goes down to the third Db below middle C, which is around 36Hz, if I’m reading it right.
I’ve been toying with the idea of popping my mid/sides cherry on this job but having checked that bottom frequency I’m thinking I’ll do better with my NT55s as omnis, possibly with an x/y or ORTF pair for definition and mix down options.
The group will be in some sort of semicircle; there won’t be enough of them for 2 full rows or more, so I want to use my middle size stand, boom less, to give 2-2.2 metres height depending on exactly how I put the mikes up. I think the height will be enough to get the players balanced, but I’m not sure about capturing the church acoustic as well as I could with my biggest stand at 10-12’ high. That stand has a huge tripod base which will spoil the view, and I’ve pretty much committed myself to a single stand with the legs at floor level.
Or should I go for mid/sides (with or without omni pair as well) and use an omni NT55 as the mid? I’ll have 4 channels available, on an Audient ID14ii plus dbx386 into the optical input via co-ax to toslink converter.
I can get 3 Oktava 012 omnis together for a Decca “twig”, but that feels a bit messy for a live concert. Is there an obvious point I’ve missed that will help make this decision for me? I’ve generally stuck to an omni pair for good bass in church, but at greater height …
Re: Recording Sax orchestra live
Bear on mind that while the fundamental of that low Db might be 36Hz most of the sound will be harmonics.
Forum Aficionado - Posts: 22907 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
True, but other than organ pedals and string basses that go to low C, there’s not much right down there anyway in acoustic instruments I ever come across. I guess I just want to reach the parts iPhones can’t reach …
I need to pop out, but I'll return with more thoughts later... In the meantime, I've several recordings of The Fairer Sax saxophone quartet made with an XY pair of hypercardioid C414s, and they sound excellent... so I wouldn't worry about a lack of LF content on your directional mics in an MS array!
Most directional mics are pretty flat to around 45-40Hz, so I wouldn't worry about needing the LF extension of an omni -- not like you would if the fundamentals were down around 20Hz.
I’ve been toying with the idea of popping my mid/sides cherry on this job...
Good idea! But you could always supplement the MS array mounted at the centre of a stereo bar with a pair of omni outriggers to cover all options. I often use this technique to give the imaging and central source tonal accuracy of the MS array with post-prod versatility, combined with the spaciousness, room acoustic and LF extension of the omnis (30-50cm spacing depending on distance from the source).
Sounds plausible. The majority of sound will be from 3-5 feet above the ground, so the height should be sufficient.
You may well be able to achieve the required acoustic balance by pulling the mic stand back and using a smaller stereo recording angle from the MS array.
Or should I ... use an omni NT55 as the mid?
Nooooooooooooo!
The only time that configuration is useful is for recording ambient sound effects on location in a field! When decoded the MS array with an Omni mid equates to a pair of back-to-back cardioids.... and sounds correspondingly hopeless in terms of its imaging for an on-stage ensemble!
I'd go with a hypercardioid or cardioid Mid mic, depending on distance from the ensemble. The trick is to listen just to the Mid mic when rigging to make sure everyone is within the mic's coverage area and the acoustic balance is acceptable. If you need wetter, pull the stand back and consider a hypercardioid. If you need drier, move the stand closer and use a cardioid to keep everyone near the edges of the semicircle sounding sweet.
And as mentioned earlier, a pair of spaced omni outriggers should cover all bases nicely when it comes to the mix.
I’ll understand how all this fits together eventually! Or at least, better than I do now. OK, mid/sides with, er, a side order of omnis sounds specially designed to keep me happy. I’ll rig that and see how it works on me and my bari sax. I can pop down to my own village church and have a trial setup, which will be good for everyone, except possibly casual visitors to the church! Never mind, as I heard Ella and the Inkspots declare yesterday, “into each life some rain must fall” …
Better make a setup list.
I'm not sure what mics you have available for the MS array... I've used all sorts of different things, but one configuration that I come back to often for small ensembles is a pair of parallel-mounted (one above the other) Sennheiser MKH30/30 (fig-8 Mid), 30/40 (cardioid mid) or 30/50s (hypercarioid mid) as the MS array, mounted forwards of a wide spaced (40-60cm) pair of MKH20 omnis to create a pseudo Decca Tree with an MS centre.
It gives plenty of options in mixing and I've found it very versatile as well as sounding great in almost any mix blend!
For example, You can just use the omnis on their own, or the omnis plus a bit of the mid mic to solidify the centre Decca style. Or just the MS array on its own with any desired stereo acceptance angle. Or the MS array with some bottom end support from the omnis. Or the MS array with added spaciousness and room sound from the omnis.
And it can all be supported from a single stand quite discreetly. I use a T-arrangement either of long K&M bars, or Manfrotto poles, with the stand attaching just forward of the T junction to keep the CofG above the stand.
Oh... and as you're using a tall stand to mount the mics above the instruments, whatever mics you're using for the MS array make sure to mount the Side mic above the Mid Mic so that direct sound from the players reaches the Mid mic fractionally before the Side mic. You'll get a much more stable stereo image that way!
Mods?
Following with interest (but a bit wary now).
Mods?
- shufflebeat
Jedi Poster - Posts: 10110 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
I think you're allowed to get bits out in the privacy of your own home.. That's what the nice young Policeman told me, anyway....
??? Is this pair at 90%, not parallel?
I don’t think parallel is the correct term here. Vertically stacked in-line, diaphragm end to diaphragm end, with the mid pointed at the noisy stuff and the fig-8 sides rotated 90°.
The mkh30 is a side-address fig-8 (incorrectly mounted at the bottom in this Google pic), while the 40 and 50 are end-fire conventional pencil mics (on the top in this rig image).
Consequently, MS arrays using 30/40 or 30/50 combinations are mounted parallel, as shown above, one mic above the other.
For a Blumlein MS array using a 30/30 combination, you can use the same basic hardware, but arranged to be vertical with the fig-8 Mid mic at the front facing front-back, and the Side mic behind it facing left right, but slipped down a bit to avoid shadowing the rear of the Mid mic.
The two mics are still parallel in this arrangement.
On a similar topic, we took delivery of one of these beauties a few weeks ago:
https://www.milabmic.com/pearl-ms-8cl/
Haven't yet had the chance to put it properly through its paces, but very much looking forward to doing so.
We have four MKH40 at the studio, and I've always fancied an MKH30 to go with them, but if the Pearl lives up to expectation I may be able to forget about the MKH30!
I also like the Beyerdynamic M160/M130 pair in M/S - I use a mounting system that seems almost identical to the one in Hugh's photo, although a single clip seems to work fine since the M130 are so small.
- Aled Hughes
Posts: 2136 Joined: Tue Oct 24, 2006 12:00 am
Thanks, that makes sense, I couldn't visualise it, but having them vertical and one effectively at 90 degrees to the other is what I was getting at.
Yes, I realised I’d unleashed a double entendre, but thought you gentlemen would politely pass over it.
What I meant, of course, was the bits that comprise my box full of stereo bars, extra mike clamps, booms and so on.
I’ve now got hold of another fig 8 mike; probably a bit low output as it’s a ribbon (Recording Tools MRP-01), but it’s a LOT easier to rig than the heavy NT2A. I did get the NT2A upside-down over the M5 mid mike last night, but it looks a mess and I rejigged it with the lighter MRP01 in about 10 minutes today, including swapping some of the screws in my 6-slot bar to different slots.
The omnis are 550mm apart and about 230mm back from the mid’s diaphragm. It LOOKS alright to me but I have no idea how it sounds until I get it to the church here to do some tests. Hope to do that by tomorrow lunchtime, although I might do a walk-round test at home tonight after my Covid booster, assuming I’m feeling OK. Should be too soon for side-effects (jab at 7:15 tonight).
There, no more mystery about my bits - total used, wide 6-way mike bar, I stereo bar (slotted) and one extra mike clamp on the stand pole. Hopefully won’t scare the horses, and I have 2060mm (81”) from the floor to the tiny gap between the top of the mid mike and the sides mike. And that’s not a double entendre!
Hugh Robjohns wrote: ↑Tue Oct 04, 2022 3:54 pm The only time that configuration is useful is for recording ambient sound effects on location in a field! When decoded the MS array with an Omni mid equates to a pair of back-to-back cardioids.... and sounds correspondingly hopeless in terms of its imaging for an on-stage ensemble!
Obviously I'm not going to disagree with the good doctor, but...
Actually I use this set-up quite often but with the mid signal considerably higher than the sides, so that the sides are really just providing a smidgeon of width to an otherwise-nearly mono signal.
Okay. To be fair, it can be a useful option in a really nice or very dead acoustic where the 360° pickup is either beneficial for the ambience pickup, or irrelevant as there is no sound at the back, and you need the LF extension or lack of proximity of the omni Mid.
But there aren't many situations where an (equivalent) array of back-to-back cardioids would be the preferred choice!
I will defend M-S with an omni mid for one particular context... sometimes you want to have the musicians arranged in a circle with the mic array in the middle of them, and in that case, you need something with a 360 degree acceptance angle. You can sometimes get omni M-S to work quite well in those circumstances.
- Sam Inglis
Moderator - Posts: 3228 Joined: Fri Dec 15, 2000 12:00 am
