However, on having an hour's play with it on Monday night I found something I didn't like. When listening on headphones I found that the output from the VCF is very low in volume and the tone from the oscillators "leaks" past or through the VCF to a much greater degree than any analogue synth I've encountered before.
I think I've worked out what the problem is by studying the original Arp 2600 service manual - the VCF gain has not been adjusted correctly. The idea is to adjust this gain with the VCF fully open when VCO1 is patched in with its VCF input level full such that the VCF output is at the same level as VCO1 output i.e. the VCF provides unity gain.
I'm not too pleased with this and I haven't decided what to do about it.
I would return the 2600 if I knew I would receive a replacement within a short time - but I wouldn't, I'd have to wait months.
I am capable of making the adjustment myself and that's probably what I'll do - the photos of the 2600 PCB I've seen show legends next to the preset pots - there are a set of 3 for each filter type.
Any thoughts?
