Beware the wall rat
Beware the wall rat
Or in this case the line lump. For many years I have butchered the LT leads on these things when I needed certain volts/amps but the plug was the wrong size or indeed wanted to splice it directly into a circuit.
I always found that the cable was screened, I assumed to contain much of the residual 'hash' that such supplies put out. Today I stripped one back to find a single red and single black wire. No screen.
The supply was a R.S brand (NOT to be confused with RS Components) and rated at 22V 1A. So, if any of you find an odd noise in your systems, especially one that has come about after purchasing a bit of rat powered kit, an unscreened power lead could be the cause?
Dave. (that's R dot S)
Posts: 18530 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Re: Beware the wall rat
Post by resistorman »
In my repurposing and chopping of rats, lumps and warts I’ve rarely seen one that WAS screened.
resistorman
Posts: 2932 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
resistorman wrote: Wed Nov 23, 2022 8:47 pm In my repurposing and chopping of rats, lumps and warts I’ve rarely seen one that WAS screened.
I don't mean the cheaper 5V things you get for powering phones and small devices like S/PDIF switches. I mean 12V at an amp and up.
ef37a wrote: Thu Nov 24, 2022 8:26 am
Me too :D And since almost none of them are actually grounded, I don’t know what a shield would do? :think:
resistorman
resistorman wrote: Thu Nov 24, 2022 3:03 pm
Thought of that too, they would find earth at their destination much of the time e.g. an AI via either USB or audio connections.
Of course, gear is increasingly becoming earth free...
Dave
The screening suggestion doesn't hold much water for the reasons above. I suspect they use coax cable just because it's easier to terminate with a coaxial DC plug.
Posts: 42816 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Hugh Robjohns wrote: Thu Nov 24, 2022 9:42 pm The screening suggestion doesn't hold much water for the reasons above. I suspect they use coax cable just because it's easier to terminate with a coaxial DC plug.
This two wire PSU HAD a co ax plug! Jeez! I can do without all this negativity...Jus' sayin!
ef37a wrote: Thu Nov 24, 2022 9:46 pm
Exactly. I remember those coax DC leads - much easier to secure with a simple gland. Oh, and (of course) the figure of eight cables STILL feed a coax plug.
And another thing. I'm pretty sure that in their original transformer and fat caps form, in the UK at least, they were not floating, but earthed.
Posts: 20316 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Folderol wrote: Thu Nov 24, 2022 10:13 pm
THANK you Will! I don't even mean the fig 8 jobs. The one I stripped had a round, quite stiff cable...THAT is why I was surprised at the lack of a screen.
(I know I am getting on but I'm not quite THAT daft...yet.)
