Can someone please help with some DX Sys-Ex?
I have two banks (of 32 patches each) of DX/TX 6-op sounds in Sys-Ex format (.syx), but no matter what I do I can't import them into Dexed or my K2700, both of which should speak DX. Dexed dissplays corrupted patch titles, and my K2700 just refuses to load them, saying they are not in the correct format.
I *think* (memory fails me) that these banks came from my old TX-802. Can anyone please offer to try to get these banks into a 6-op FM synth for me, see if they can be read, and maybe create new Sys-Ex files for me?
Posts: 21336 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Re: Can someone please help with some DX Sys-Ex?
Later tonight I can try them on a MODX and an SY77 if you mail them to me mate (I think you should have my address, PM me with a link to them if not).
Posts: 9873 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Thanks, mate. I'll drop you a PM.
Post by sonics »
Is software any good? I could see if FM8 reads them. I also may be able to find my old copy of MIDI Quest.
sonics
sonics wrote: Thu Nov 24, 2022 7:10 pm Is software any good? I could see if FM8 reads them. I also may be able to find my old copy of MIDI Quest.
Thanks. As long as I can get the sys-ex into a form I can use I don't mind what reads it! :lol:
My best guess is that my TX has created a difference to the older DX7 Sys-Ex. I need to get it into a vanilla DX7 format.
I'll drop you a PM also.
Eddy Deegan wrote: Thu Nov 24, 2022 6:34 pm Later tonight I can try them on a MODX....
I think you need to do a conversion first for that on YAMAHAs web converter
"The Yamaha FM Converter allows you to use contents from the DX7, DX7II, TX802 and TX216/816 on your new Montage/Modx"
if the convertor works its probably an indication that the files have some semblance of sanity.
Posts: 4783 Joined: Sun Aug 12, 2018 2:40 pm Location: British Isles
Thanks for that suggestion. However:
(File) does not contain any convertable data
I don't get this. These files definitely once worked!
In the meantime I've been looking at these files. They look very odd - clearly not standard DX sys-ex. Somehow I've managed to get these corrupted with something else.
So now I'm wondering if I can somehow get these out of FM8, where at some point I've successfully imported them, but FM8 has no export feature.
I'm now convinced that the .syx files I have are not DX native format. There's some spurious data in there that has nothing to do with DX. Clearly I've managed to save the wrong files at some point in the past few decades.
So I do have these two banks in FM7 and FM8 format, but seemingly no way to get them back out into the real world!
No luck here either I'm afraid :-(
Yep, I'm pretty much resigned to having lost them at this point. A couple of the patches (which I was hoping to use) didn't convert cleanly, so I was hoping to go back to the hardware sys-ex and try Dexed, but alas not. :cry:
It's not so long ago I still had my TX-802, but I sold it along with the cartridges of my banks.
I do appreciate you trying for me.
If you can see the data in a synth context you could "knife and fork" it with a manual transfer, but DX FMs arent strictly parameter compatible, eg the FM modulation intensities, so some tweaking might be required.
Patch transfer in the days of DX7.................
(do you have an apprentice that needs to do some detention ??)
Post by sonics »
The files look like MIDI files to me. I've converted them for you. PM contains the links for you to try.
sonics
Wow! Sonics has waved a magic wand over these files! :clap:
Now I have the sounds both in Dexed (which, as suspected, has done a better conversion job than FM8), and my K2700.
There is much rejoicing in the Toadstool.
Thanks to all of you who offered help and suggestions. It is much appreciated. :thumbup:
Now to back these up in a dozen places...
Hurrah! :clap:
The Elf wrote: Fri Nov 25, 2022 10:26 am Now I have the sounds both in Dexed (which, as suspected, has done a better conversion job than FM8), and my K2700.
That's an interesting observation Monsieur Elf - I have both FM8 and Dexed, so I should obviously spend some more time with Dexed.
Posts: 22424 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by muzines »
Glad you got this sorted - I didn't see it until after a solution was found, otherwise I'd have helped out.
And if you're into vintage DX7 stuff, Plogue currently have OPS7 for half price for BF - £26 and you can have arguably the best, bit-accurate DX7 software emulation, emulated to a crazy degree.
https://www.plogue.com/store.html
As I'm a sucker for having good emulations of classic synths, I picked it up as I'd been eyeing it for a while.
(I doubt I'm going to convert all 120,000+ Dexed Logic presets for it... not right now anyway, it took a few months to churn through the Dexed cartridge as it was...)
muzines
Martin Walker wrote: Fri Nov 25, 2022 5:35 pm
One example: There's a delayed vibrato on one patch - important, since it keeps the start of each note in tune. In FM8 the vibrato is there all the time, making it sound horribly out of tune. Dexed translates it perfectly.
muzines wrote: Fri Nov 25, 2022 6:02 pm Glad you got this sorted - I didn't see it until after a solution was found, otherwise I'd have helped out.
Tempting.
My world of FM sounds is really all about these two banks, collated (and some created) by myself way back in the 80s. I think Dexed is probably good enough.
One of the patches appeared on a very famous movie-related record of the 80s... :D;)
FM8 does read them, I loaded in all my DX7 sounds, seems to work fine.
I had them on Alesis Data Disc originally, they are useful things to have around, if only as Sysex playback devices.
Posts: 21408 Joined: Sat Jul 12, 2003 12:00 am
Arpangel wrote: Sat Nov 26, 2022 9:20 am
That wasn't the problem. The problem was that the files *I* had couldn't be read by FM8. And FM8 doesn't have an export function.
Post by bonefixer »
What a wholesome thread (like most on these boards, to be fair)
I wish I knew what you were all on about though. FM is a mystery to me (I’ve read about it, watched videos explaining it, and loopop reviews of FM things, but still…)
bonefixer
Posts: 84 Joined: Tue Jan 04, 2022 10:08 pm Location: Isle of Man
Gear: Loads of guitars, Line 6 Helix, Yamaha THR30 amp
Bechstein 1932 5’3” Grand Piano, Yamaha CP88, Yamaha YC61, Nord Wave2, Arturia Keystep Pro, Arturia KeyLab88, MacBook Pro, Mainstage, MAudio and Presonus interfaces, Behringer XAir mixer…
Just download Dexed and click on some presets - there's no need to understand it to use it.
FM is all about snappy, twinkley, glassy, bell-ish tones. It does those fabulously. Not so hot for pads, strings and the like.
Cue other posts disagreeing with me in four... three... two... one...
Post by muzines »
The Elf wrote: Sat Nov 26, 2022 5:53 pmCue other posts disagreeing with me in four... three... two... one...
I agree with you (which is quite common*, tbh) :lol:
The plucky, attack transientey, mallety, belly and plucky things is what classic Yamaha FM really excels at (and why eg David Gamson used the DX's for exactly that, layered with analog for depth and warmth and thickness).
* But not about the K1, sorry...
muzines
Post by sonics »
Layering FM attacks from a DX with the body of the sound from a Prophet was regular practice for me a few decades ago. I made excellent, fairly realistic brass sounds that way.
Great bells and mallets, too. You couldn't get those fast attacks elsewhere without using a sampler.
sonics
