Can someone please help with some DX Sys-Ex?
Re: Can someone please help with some DX Sys-Ex?
Post by MOF »
FM is all about snappy, twinkley, glassy, bell-ish tones. It does those fabulously. Not so hot for pads, strings and the like.
Cue other posts disagreeing with me in four... three... two... one...
I got the pads by putting DX7 string patches through a Dimension C footpedal, still necessary when I got the TX802 which in theory was eight DX7s which could all be separately micro detuned to each other.
MOF
MOF wrote: Sat Nov 26, 2022 7:06 pm
Me too! I still have my Dimension C chorus pedal, which I must dig out to try with the Nymphes.
Post by ajay_m »
The original sine only FM carriers on the dx series synths and lack of filters did limit the sonic palette. You could not create the spectrum of a true sawtooth and so strings were always just out of reach. Also the lack of filters meant that timbre changes over the duration of a note had to be accomplished by modulation depth changes which led to a characteristic "boingy" timbre due to the way Bessel functions work. But fm synths like the fs1r had other waveforms and filters and their sonic palette is huge, certainly strings and pads were well within reach
ajay_m
Posts: 1677 Joined: Mon Jan 16, 2017 7:08 pm
FM's also good for hard edged bass, wubs and wobbles.
Post by sonics »
MOF wrote: Sat Nov 26, 2022 7:06 pm I got the pads by putting DX7 string patches through a Dimension C footpedal, still necessary when I got the TX802 which in theory was eight DX7s which could all be separately micro detuned to each other.
CE-1 and Dimension D here... :tongue: plus an occasional altercation with the Electric Mistress. :lol:
sonics
Post by BigRedX »
We stuck ours through a distortion pedal...
You can get decent sustained pad sounds out of an original DX7, but it's hard work compared with how easy it is with even the most basic of analogue synths, so these days why even bother?
BigRedX
sonics wrote: Sun Nov 27, 2022 5:34 pm
Yup, I have Dim D and a couple of CE-1s here still too. Love 'em all!
TBH the Line 6 Helix, and a few plug-ins, emulate any of these to my satisfaction, but some things you just don't feel you can part with. :?:crazy:
Post by sonics »
The Elf wrote: Sun Nov 27, 2022 7:25 pm Yup, I have Dim D and a couple of CE-1s here still too. Love 'em all!
You're right. However, on my list of things to do are some A/B tests with some of my old gear. If software gets close enough, I'm selling it. I actually like the idea of that gear going to someone who really wants it, and will use it more than I do (hopefully). Just haven't got around to it yet...
sonics
Post by MOF »
I’ve replaced my Dimension C with UAD’s Dimension D, very good, as are the bulk of their plugins.
MOF
Post by bonefixer »
The Elf wrote: Sat Nov 26, 2022 5:53 pm Just download Dexed and click on some presets - there's no need to understand it to use it.
What about the Korg OPSIX? I don’t generally get on too well with soft synths, in terms of playing with them to figure out sounds. Dexed looks pretty complex. And I like to understand how stuff works 🙂
bonefixer
Posts: 84 Joined: Tue Jan 04, 2022 10:08 pm Location: Isle of Man
Gear: Loads of guitars, Line 6 Helix, Yamaha THR30 amp
Bechstein 1932 5’3” Grand Piano, Yamaha CP88, Yamaha YC61, Nord Wave2, Arturia Keystep Pro, Arturia KeyLab88, MacBook Pro, Mainstage, MAudio and Presonus interfaces, Behringer XAir mixer…
bonefixer wrote: Mon Nov 28, 2022 1:40 pm
Then FM isn't for you. I doubt more than a dozen people ever knew how FM worked! :lol:
I've never even seen a OPSIX.
Post by BillB »
sonics wrote: Thu Nov 24, 2022 11:11 pm The files look like MIDI files to me. I've converted them for you. PM contains the links for you to try.
So they were .MID files containing Sysex but named as .SYX files? Was that the issue?
BillB
Posts: 2469 Joined: Mon Apr 07, 2003 12:00 am Location: East Yorkshire
Post by sonics »
It was a MIDI file containing multiple (20, I think) tracks. The SysEx data was on the first track. The Elf might remember what created the original file.
sonics
sonics wrote: Tue Nov 29, 2022 9:05 pm It was a MIDI file containing multiple (20, I think) tracks. The SysEx data was on the first track. The Elf might remember what created the original file.
Clearly there's been some confusion somewhere along the way. There's no way these files should have been given a .syx suffix. But these files go back many years, so I'll never know what truly happened.
I suspect the files in question were actually Cubase MIDI file exports, despite me believing they were clean Sys-Ex dumps. I was using a hex editor to try to isolate the Sys-Ex, but couldn't see the wood for the trees.
Sonics found the data and saved the day! :thumbup::clap:
Post by bonefixer »
The Elf wrote: Mon Nov 28, 2022 4:05 pm
I got the Opsix. Only had it a day, but having watched tutorials and reviews, and reading about FM, I’m finding it fairly easy to use and am getting to grips with the concepts.
bonefixer
