Storing PA gear in a garage
Hi,
I'm a newbie here who is just starting to get a collection of gear together after the band I was in parted ways. I inherited a Behringer 2442FX USB mixer from the band kitty. Since then I've been buying various cables, stands, and DI boxes, plus a pair of Yamaha DBR tops. This is all with a view to getting something going when work settles down. Anyway, with the weather starting to get colder, I've just moved the mixer and my guitar pedalboard into the house for the winter.
Conversely, my tops and a trolley case crammed full of XLRs, instrument cables, headphone amp cables and a couple of Mackie dynamic mics are still left in the garage. The garage is not detached but we know UK winters can be damp
How many of you leave your powered speakers in an unheated out-building, year round? I'm wondering whether to get a couple of the large vacuum bags that can be used to winterise clothes or bedding.as I gather that damp is.the main issue?
Re: Storing PA gear in a garage
At my old place I used to store gear in a garage attached to the house with no damp problems. There must have been enough heat coming through the wall from the house (and also from the boiler in a cupboard next to the garage) to keep things dry.
At my current place the garage is detached and I quickly found that I was getting damp problems in cold weather so, for now, I have a small heater in there with the thermostat set very low. Some people use a dehumidifier instead of a heater which might be more energy efficient.
Posts: 16593 Joined: Mon Sep 10, 2001 12:00 am
Putting gear in a sealed plastic bag could cause problems like mildew and mold.
- resistorman
Frequent Poster - Posts: 2948 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
In my experience the big risk is in the change of environment i.e. taking an electronic item from a cold environment into a warm room and powering it up straight away resulting in condensation. If I leave gear in my car overnight I always give it an hour in the house before powering up. It was a common problem at work with laptops, we’d lose a couple ever winter.
- Music Wolf
Posts: 2888 Joined: Fri Feb 17, 2006 12:00 am
No One There
https://starbelly.bandmule.com/
My garage has a pitched roof and I use the roof space for storage. Its typically much drier and warmer in the roof space than the main garage space.
In my garage I would want to put electronic stuff up there, but wouldn't much fancy lugging a PA up and down!
Stu.
Stu.
- Moroccomoose
Frequent Poster - Posts: 554 Joined: Tue Apr 12, 2011 12:00 am Location: Leicester
Cables definitely won't be a problem... I kept my crates of 'em in various garages for many years...
I'd be more wary of 'electronics' - including mics of any description... I've never risked it. I guess if you had sealed plastic boxes and also put some silica-gel sachets inside you'd probably be OK with the smaller stuff. I keep what remains of my lighting rig - including the DMX controller in the garage in sealed boxes and it's come through five or six garage winters now with no issues.
BTW I did keep all my PA gear - including monitors - in the loft for some years... kept me supple!
- Mike Stranks
Jedi Poster - Posts: 10586 Joined: Fri Jan 03, 2003 12:00 am
resistorman wrote: ↑Tue Nov 29, 2022 4:55 am Putting gear in a sealed plastic bag could cause problems like mildew and mold.
Agreed but I was thinking of the vacuum bags that you can attach the Hoover to, in order to draw out all of the air.
Moroccomoose wrote: ↑Tue Nov 29, 2022 8:50 am My garage has a pitched roof and I use the roof space for storage. Its typically much drier and warmer in the roof space than the main garage space.
Stu.
Ooh, mine has one too. It needs a bit of a clear out up there - my wife has a bit of a tendency to keep things for sentimental reasons. Maybe I can persuade her.
At the moment the speakers are DBR10s and we have a drop down ladder so it wouldn't be too much of a feat to move them up there.
Music Wolf wrote: ↑Tue Nov 29, 2022 7:09 am In my experience the big risk is in the change of environment i.e. taking an electronic item from a cold environment into a warm room and powering it up straight away resulting in condensation. If I leave gear in my car overnight I always give it an hour in the house before powering up. It was a common problem at work with laptops, we’d lose a couple ever winter.
When I got the mixer out last night I noticed that the surfaces had a very thin layer of condensation when I took it out of its case. Hence I waited a bit before switching it on. I should probably have left it in the case for a bit.
They say the same about nitrocellulose lacquer finished guitars and leaving them in their cases to bring them to temperature gradually and avoid finish checking...
Most of my rig lives in my detached garage though mixers, mics etc come into the house. No problems I can attribute to storing them out there after many years.
Forum Aficionado - Posts: 22487 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
This applies to any guitar regardless of finish, though nitro finished guitars do require more overall care with regards to temperature changes.
All my PA gear lives in the garage and I've not had any problems with damp or cold.
Posts: 29122 Joined: Sun Jul 05, 2015 12:00 am
PA gear in an unheated garage or shed is no problem
however
I find it best to elevate the gear. (I use 2x4's to) create an air space beneath speakers and such. You don't want your gear to "wick-up" and moisture from the floor.
If the gear gets frozen (stored in below-freezing temps), open up the case and allow to defrost (for at least an hour) prior to powering up to avoid condensation issues with the electronics.
however
- Mike Monte
Regular - Posts: 119 Joined: Sun Apr 03, 2016 12:00 am
We use vacuum bags to overwinter our touring caravan bedding. You should see what happens to a continental quilt when you remove all of the air with the Hoover....
So do we but bedding is compressible, your PA gear is not so you won't be able to remove as significant a proportion of the air from your PA gear. That said if you put them in the bags in a dry environment then they should reduce the risk of condensation when it gets cold.
Sam Spoons wrote: ↑Wed Nov 30, 2022 5:28 pm
My thinking was that the interior of the speaker isn't air tight so the air would still be removed as the vacuum crested in the bag draws it out. However, I guess there is a risk of removing it too quickly in case it damages the speaker. A low vacuum speed maybe? Too risky?
You won't remove anything like 'all the air' nor get anywhere near a vacuum so you will still have potentially moist air in the bags however there should be no risk to the speaker drivers as the cabs are ported not sealed.
Question for others more knowledgable than me, "would the reduced pressure present a risk to components like capacitors or other encapsulated devices?" My gut feeling says no, especially at the level of 'vacuum' a domestic vacuum cleaner could generate but just to be on the safe side, advicewise...
Sam Spoons wrote: ↑Wed Nov 30, 2022 6:55 pm Question for others more knowledgable than me, "would the reduced pressure present a risk to components like capacitors or other encapsulated devices?" My gut feeling says no, especially at the level of 'vacuum' a domestic vacuum cleaner could generate but just to be on the safe side, advicewise...
I've not been involved in designing any gear to go into a vacuum but for gear that is going to be used under high pressure you need to use devices with no voids and no liquid. So crystals and electrolytic capacitors are out. Electrolytics are replaced by tantalum capacitors or ceramic capacitors. Semiconductors and resistors are usually OK but you need to test thoroughly before approving a design for use at pressure.
I've had better results keeping things ventilated rather than sealed. You could use a fan on low to keep air moving, the cold is not going to hurt PA gear, wiring etc. The trouble with sealing is that even using a vacuum there is still moisture and spores in there.
- resistorman
Yes, good point
I store my powered speakers in their gig bags which are not airtight but do give some protection from the effect of big temperature and humidity changes.
Low temperatures were never a problem in my experience... 'twas always the damp...
... and for those not in the UK, you probably have no idea how damp 'damp' can be here! Just looking out of the window at the moment...
- Mike Stranks
