How to Remove Mic Thread Adapter!
Re: How to Remove Mic Thread Adapter!
I think every combination of extraction method has been aired here except seeing your friendly car mechanic and asking if he has a suitably sized stud extractor. The left hand thread will bugger the adaptor but as said, cheap as.
Just an observation. I have handled mic accessories on and off for 60 years and we were always careful to fit the adaptors 'slot out'. It has only been in the last couple of years or so that I have noticed with some cheap mics the adaptors now have a slot cut both ends. WTF weren't they ALWAYS like that?
Posts: 19073 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Post by S2 »
What about a Dremel type affair to cut a new (crude) slot on the top/inside of the thread so you can use a (large) screwdriver to undo it. Don’t use WD40, it’s of limited use as a penetrating oil - Plus gas is far better.
S2
Posts: 4466 Joined: Sat Jun 18, 2005 12:00 am Location: Dorset
S2 wrote: Tue Dec 06, 2022 7:31 am What about a Dremel type affair to cut a new (crude) slot on the top/inside of the thread so you can use a (large) screwdriver to undo it. Don’t use WD40, it’s of limited use as a penetrating oil - Plus gas is far better.
I am fairly sure OP said the mic holder was plastic? In that case he has to be careful what kind of solvent he uses. I have never found WD-40 to attack anything.
WD-40 attacks silicone bath sealant!
Posts: 19190 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Wonks wrote: Tue Dec 06, 2022 11:00 am WD-40 attacks silicone bath sealant!
HOW would one EVER find that out?! Good job too, tricky stuff to clean off.
Post by Mike Stranks »
I have a few of these... inherited from eBay buys...
I just use a 5/8-3/8 adapter if one is needed.
Mike Stranks
Post by ManFromGlass »
Mike, I’m not sure we are looking for a simple and elegant solution here . . .
:D:D:idea:
(Whether the idea works or not this is one of the reasons I love these forums, somebody always has the right idea!)
Posts: 7838 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
Post by siderealxxx »
Breaking news people! It's out, I repeat it's out!
In the end it was simpler than I anticipated, but I think the WD40 (whilst maybe not the right thing) had helped overnight.
I basically jammed a large wide flat headed screwdriver in there as firmly as possible and applied pressure inwards whilst turning. Took a bit of oomph but it came out in the end.
Some pretty creative suggestions here though! Some easier than others.
I hear-by declare today a national holiday in celebration ;)
siderealxxx
Posts: 662 Joined: Sat Jan 24, 2009 12:00 am Location: Somerset
:thumbup::thumbup:
The Force was with you!
siderealxxx wrote: Tue Dec 06, 2022 1:21 pm Breaking news people! It's out, I repeat it's out!
Great! Now, put two blades in a 12" hacksaw and cut a slot in the other end of that adaptor!
Another thing I have noticed with the cheap mic adaptors is that many are now Aluminium. I dare say the subjectivist beardy tweaks will say Brass gives a 'denser' tone but I can live with that!
ef37a wrote: Tue Dec 06, 2022 1:29 pm
I've gone one step further and thrown away all the ones with one slot and only kept the ones with 2 slots. Never again!
siderealxxx
Post by S2 »
ef37a wrote: Tue Dec 06, 2022 10:02 am
All sorted now. But for reference Plus gas is similar (ish) to WD40 but much better. It’s not a solvent but penetrating oil.
S2
Post by shufflebeat »
Mmm, that sounds familiar. Didn't..., someone..., suggest doing just that with one jaw of the pliers two pages ago?
Anyway, sometimes the beauty is in the travelling as much as the arrival.
Well done.
shufflebeat
Posts: 10061 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
A quote from Microphone Farm: "Two slots good, one slot bad."
shufflebeat wrote: Tue Dec 06, 2022 2:19 pm
siderealxxx wrote: Tue Dec 06, 2022 1:21 pm I basically jammed a large wide flat headed screwdriver in there as firmly as possible and applied pressure inwards whilst turning.
Well done.
Granted and I did try, but I took you very literally and tried with my pliers which were in no way sized or shaped for the task. My simple brain didn't extend this idea any further!
Had you said 'the large flat red screwdriver in the bottom kitchen drawer' then then this thread wouldn't have run to, ahem, four pages! Impressive nonetheless.
siderealxxx
Wonks wrote: Tue Dec 06, 2022 2:23 pm A quote from Microphone Farm: "Two slots good, one slot bad."
:shocked:
siderealxxx
siderealxxx wrote: Tue Dec 06, 2022 2:38 pm Had you said 'the large flat red screwdriver in the bottom kitchen drawer' then then this thread wouldn't have run to, ahem, four pages! Impressive nonetheless.
Ah, I see where I went wrong. Well, I'll know for next time.
I like the sound of this, "Microphone Farm", very wise.
Also, "...some mics are more equalised than others".
shufflebeat
shufflebeat wrote: Tue Dec 06, 2022 3:45 pm Also, "...some mics are more equalised than others".
A classic from George Aural.
Post by resistorman »
Not many forums where you can get 4 pages out of removing a stuck screw! Well done :clap: !
resistorman
Posts: 2976 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Post by sonics »
Now I need to know if it was PlusGas Formula A, B, C, D or E? :lol:
I may be mad, but I'd find a book on the history of lubricants and penetrants rather interesting!
:crazy:
Fascinating range of products (here; Canadians love this stuff) from WD-40, 3-in-One, JIG-A-LOO, Liquid Wrench, Permatex, Honey Goo etc.
Or perhaps I don't want to know what's in the cans, and should stick to this formula?
Code: Select all
Start
Spray
Work?
If yes goto Stop
NewCan
Goto Spray
Stop
HaveBeer
End
sonics
Post by sonics »
Forgot to include this one:
B'laster Advanced Dry Lube "Work it Like a Pro"
:shifty:
sonics
Post by AlecSp »
ef37a wrote: Tue Dec 06, 2022 10:02 am In that case he has to be careful what kind of solvent he uses. I have never found WD-40 to attack anything.
It's the only thing I've found that will get "label goo" off things.
AlecSp
Posts: 822 Joined: Tue Nov 16, 2004 12:00 am Location: Herts, UK
Post by sonics »
AlecSp wrote: Tue Dec 06, 2022 10:04 pm
You mean to say that "Goo Gone" doesn't do what it says on the label?
sonics
Also removes cats.
shufflebeat
shufflebeat wrote: Tue Dec 06, 2022 10:49 pm Also removes cats.
Really? I was told by a pet shop owner that it repels mice.
