How can I playback one channel of a stereo track centered on both speakers
Post by armans »
I have a stereo track with a reference mix and I like listening to the R and L channels seperately by using the balance panner but I would like to figure out how to listen to each channel seperately on BOTH speakers instead of just one. What is the easiest way to do this? When I use my balance panner in Cubase it just comes out of one speaker.
thank you
armans
Posts: 142 Joined: Sat Jan 11, 2020 2:36 pm
Re: How can I playback one channel of a stereo track centered on both speakers
Use two mono channels instead of one stereo channel.
In some DAWs you might need to split the stereo file into two mono files first.
Post by Mixedup »
Right-click on the panner in Cubase and it should give you more options. One is a single panner between left and right signals. Another treats them as two independent pan pots, one for each channel, so if you can mute one, you can place the other where you want.
Alternatively, mute one channel and hit the Mono preset button in Cubase's Control Room. This should route all signals (including the one now soloed on that track) equally through both speakers.
Or use a separate utility plug-in set to mute/fully attenuate one channel, while panning the other to the middle. Then just enable/bypass that plug-in to audition. Eg HOFA's free Meter, Fader & MS-Pan plug-in would enable you to work that way.
Lots of ways to do this...
Mixedup
Posts: 4557 Joined: Wed Sep 03, 2003 12:00 am Location: Cambridgeshire, UK
For completely free control of L/R, use Cubase's multi-to-mono split feature (if that is, indeed, the DAW you are using).
But, as said above, there are a number of ways to do this, and a stereo manipulation tool would be a useful asset if you really want to do this regularly (though I can't imagine why...). The free Voxengo MSED might have this facility, though my memory of it is hazy.
BX solo is a free plugin from Plugin Alliance that allows this at a button push.
Post by armans »
Mixedup wrote: Thu Dec 08, 2022 1:04 pm Right-click on the panner in Cubase and it should give you more options. One is a single panner between left and right signals. Another treats them as two independent pan pots, one for each channel, so if you can mute one, you can place the other where you want.
The other one is the "stereo combined panner" and it act as a stereo width control meaning that if you bring it closer to center it effectively sums the two together as hitting the mono button does. Moving only one side to the center effectively brings one channel to the center while still leaving the other one on the side. I don't see how this can help, can you please explain?
Mixedup wrote: Thu Dec 08, 2022 1:04 pmAlternatively, mute one channel and hit the Mono preset button in Cubase's Control Room. This should route all signals (including the one now soloed on that track) equally through both speakers.
Ok, do you know how to mute one channel on a stereo track? The way I have been doing this up until now is the balance fader, is this what you mean?
Mixedup wrote: Thu Dec 08, 2022 1:04 pmOr use a separate utility plug-in set to mute/fully attenuate one channel, while panning the other to the middle. Then just enable/bypass that plug-in to audition. Eg HOFA's free Meter, Fader & MS-Pan plug-in would enable you to work that way
ok will check them out,thanks
armans
Post by Mixedup »
armans wrote: Thu Dec 08, 2022 7:05 pm The other one is the "stereo combined panner" and it act as a stereo width control meaning that if you bring it closer to center it effectively sums the two together as hitting the mono button does. Moving only one side to the center effectively brings one channel to the center while still leaving the other one on the side. I don't see how this can help, can you please explain?
You missed the bit where I said "so if you can mute one..."
armans wrote: Thu Dec 08, 2022 7:05 pm Ok, do you know how to mute one channel on a stereo track? The way I have been doing this up until now is the balance fader, is this what you mean?
I'd use a plug-in, like the HOFA one. Or the Plug-in Alliance one. Or this TB ProAudio one. If you really wanted it all done in one click, there's probably a plug-in out there that will do it. Or you can use a wrapper plug-in like DDMF Metaplugin to create it. Eg a Left channel solo, followed by a stereo-to-mono mix (or Mid solo) should mute the right channel and put the left channel in both speakers. OR you might be able to do it with a Cubase Macro or generic control function or some such: basically to enable/bypass two plug-ins with one click.
Mixedup
Post by Kwackman »
blinddrew wrote: Thu Dec 08, 2022 2:51 pm BX solo is a free plugin from Plugin Alliance that allows this at a button push.
Easy solution.
Kwackman
Posts: 3687 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Post by armans »
thank you, downloading now
armans
