Well, if I go with the Neumanns, they dont have a center specific speaker design, so presumably it needs to remain vertical.
Surround monitoring considerations
Re: Surround monitoring considerations
- Jez Corbett
Posts: 577 Joined: Fri Mar 21, 2003 12:00 am
Either version of the 310 can be used as a centre... and the 80 isn't much taller than the 310...
Posts: 43641 Joined: Fri Jul 25, 2003 12:00 am
FINALLY now getting the chance to audition some kh120s.
They sound very good, super clear, wide and precise in the highs but there seems to be a large hole in the low mids, comes back for a bit of sub, then vanishes.
Could be the very unideal room in a shop I'm listening to them in, but the bass is seriously lacking compared to my tb2s. Going to check they haven't done anything funny with dip switches but maybe I need the larger models.
They are also a lot smaller than I expected. Going to check they didn't accidently bring out the kh80s lol
- Jez Corbett
Jez Corbett wrote: ↑Wed Sep 21, 2022 3:23 pm ...but there seems to be a large hole in the low mids, comes back for a bit of sub, then vanishes.
Could be the very unideal room in a shop I'm listening to them in...
That does sound very much like room mode cancellation to me.
The KH80s are very small by the way, the frontal area is only a smidgen bigger than a sheet of A5 paper.
Posts: 29654 Joined: Sun Jul 05, 2015 12:00 am
Jez Corbett wrote: ↑Wed Sep 21, 2022 3:23 pm ....but there seems to be a large hole in the low mids, comes back for a bit of sub, then vanishes.
Sounds like a classic rear-wall reflection or small room standing wave problem to me – ie a room acoustics issue rather than a speaker problem. Every measurement and review I've seen – including my own – reveal an impressively uniform frequency response.
Both are more comparable in size to PMCs ancient DB1s than the (equally obsolete) fairly substantial TB2s.
Turns out the shop I tried them in has a very generous returns policy so I think I'll "rent" them for a couple of weeks and try them out in my studio next to my tb2s. They are also going to order in a pair of kh150s so I can have a listen to them. Shame they are 2x the price!
They've offered me a price of 2x 120s, 3x 80s and the 810 sub that perfectly lines up with the extra budget I've just gotten on the project i need them for so such a set up will be essentially "free", so i have scope to upgrade. Almost certainly going to push the 5.1 to 5.1.2 but those extra 2 are going to add a lot to the price in terms of extra hardware and installation issues.
- Jez Corbett
I dunno if you've tried this but you should give this a go:
https://professionalsupport.dolby.com/s ... uage=en_US
Jez Corbett wrote: ↑Wed Sep 21, 2022 3:23 pm They are also a lot smaller than I expected. Going to check they didn't accidently bring out the kh80s lol
From the front they are almost exactly the same size as the BBC LS3/5a. I sometimes wonder if this was deliberate...
Whenever I've used them I've not noticed any deficiency in the low mids although they don't have the characteristic high bass hump that the LS3/5a has. The bass end is reasonably well extended too.
Posts: 16948 Joined: Mon Sep 10, 2001 12:00 am
So I have a pair of KH120! Currently with an eye to either return after 2 weeks or upgrade to full surround set.
First thing - they have straight away made a huge difference to the 100-200Hz issues I've been having in my new (4.5m deep) workspace, and I am hearing stuff out of them I have never noticed in my TB2 pair. This was a good choice!
HOWEVER - I now have my next dilemma.
They do chuck out more bass than I expected based on my previous demo in a bad listening space, but not a huge amount.
When I order the surround set up, should I rely on the sub to extend the low end, or consider upgrading the front pair to KH150s or even KH310s to get full range at the front?
Originally my budget was €10k, a 5.1 setup with 2x 120, 3x 80 and 1x 810 will cost me €5k. A 7.1.4 setup with 2x 310, 2x 120, 7x 80s and the 810 may well still fit that €10k budget, although I realise I need to factor in audio hardware with more outs and anything else I might need to do atmos and other 3D audio content, which could be a LOT more ... but that's maybe a different question.
- Jez Corbett
I would just ask, that if you're considering 310s and a sub, why you're going with a pair of 120s and why not 80s all round?
Jez Corbett wrote: ↑Tue Oct 25, 2022 2:22 pm When I order the surround set up, should I rely on the sub to extend the low end, or consider upgrading the front pair to KH150s or even KH310s to get full range at the front?
It depends how much bass you need, but the spl and extension will always be limited with 80s or 120s. I've not tried the 150s yet... but a sub will be needed if you want genuine full range and LFE capability.
The 310s are a different kettle of fish. The bass from a sealed cabinet has a different rate of roll-off, but again if you want high spl you'll need a sub. It just gets more complicated matching a sub with 310s and 80s or 120s...
Of course, whether or not you get a smooth bass response in room depends not on the speaker but on the room acoustics and, particularly, speaker positions and bass trapping.
In your situation, if dobley atmos is important, I'd prioritise matched speakers everywhere, so 11 KH80s and a sub, say.
I'll mostly be doing stereo, hence thinking not relying too much on the sub, especially as the stuff i do in surround / 3D will also want to be stereo compatible, I'd think i might want to be able to get a complete picture from the L & R.
I might be barking up the wrong tree though.
Studio is fairly extensively treated, but needs more work. I'll post some photos.
- Jez Corbett
- Jez Corbett
Looking at the pictures, I'm wondering if the lack of bass is down to reflections from the desk. Have you tried them in free space or mounted higher? While the KH120s don't have real deep bass, it would only be something that I would notice if I had some much bigger speakers to compare them with.
I should get stands. The tb2s were a lot higher.
- Jez Corbett
Meant to add, spl isn't too big a deal, i don't tend to monitor at high levels
- Jez Corbett
Maybe the smaller sub would have been fine
- Jez Corbett
I think I'd have gone with the smaller one...
Still, you won't run out of headroom, and will be able to keep the Seismology department amused at your local university....
Lets think of it of a good way to break the ice with the other residents of the studio complex.
- Jez Corbett
Ok, got it set up, done some test sweeps.
Doing some sweeps, it all sounds, from an initial casual listen, reasonably flat. However I'm getting a weird phenomenon where, at my listening position, the bass seems to pan left then right briefly around 120-130Hz or so.
I've got more treatment to do, but does this suggest anything I should specifically look into?
Also a bit concerned Im even hearing those frequencies as I've set the sub to cut below 120Hz but I guess the rolloff is quite long. From testing I can still hear stuff up to about 500Hz.
- Jez Corbett
Jez Corbett wrote: ↑Fri Dec 09, 2022 12:22 pm Doing some sweeps, it all sounds, from an initial casual listen, reasonably flat. However I'm getting a weird phenomenon where, at my listening position, the bass seems to pan left then right briefly around 120-130Hz or so.
Check the same sweep on headphones set to a mono output. Our ears don't have the same frequency response on each side so it might be an artefact of your hearing rather than the sub or room.
Jez Corbett wrote: ↑Fri Dec 09, 2022 12:22 pm However I'm getting a weird phenomenon where, at my listening position, the bass seems to pan left then right briefly around 120-130Hz or so.
Probably a nodal resonance issue in the room. More bass trapping, doctor!
The low-pass crossover slope is, I believe fourth order, so it should be 24dB down at 240Hz and 40dB or so down at 500Hz — quite audible in isolation, and perfectly normal.
Hugh Robjohns wrote: ↑Fri Dec 09, 2022 12:45 pmJez Corbett wrote: ↑Fri Dec 09, 2022 12:22 pm Also a bit concerned Im even hearing those frequencies as I've set the sub to cut below 120Hz but I guess the rolloff is quite long. From testing I can still hear stuff up to about 500Hz.
As the response will already be 3dB down at the selected filter frequency, then surely that's actually 27dB down at 240Hz and 43dB down at 480Hz?
