Line 6 M9 Power Supply
Post by GRAHAM99 »
Tidying up my pedal board on a cold and wet Sunday afternoon!
I want to get a proper power supply unit.I have individual adaptors at the moment on a multi board and it is not very elegant.
The only problem is the Line 6 M9 which apparently needs an ac supply of 9v with 2ma of current.
Are there any pedal board power supplies which would do this?
GRAHAM99
Posts: 297 Joined: Fri Nov 15, 2002 12:00 am
Re: Line 6 M9 Power Supply
Do you know (or can you find out) if it has a transformer inside?
If not, it may actually be possible to run it from a DC supply - unless it uses the seriously crap idea of using opposite phases to create split +- supplies.
Posts: 20317 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
I've definitely seen a few with AC outputs. Several offer 12Vac, but the only one that comes to mind with 9VAC is the Trutone 1Spot CS12 at around £200.
https://truetone.com/cs12/
It boasts 2x 18V DC outputs, 4x 9V DC outputs, 4x switchable 9V/12V DC outputs, 1x variable 4-9V DC output, and 1x 9v AC output.
There may well be other multi-output units with 9VAC....,
Posts: 42816 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by adrian_k »
Out of interest I did a search and found this discussion:
https://line6.com/support/topic/26598-m ... -ac-vs-dc/
Apparently there is a Voodoo labs supply that, with the right adapters, you can run the M9 on two dc outputs.
adrian_k
Posts: 3574 Joined: Thu Jan 30, 2003 12:00 am Location: Gloucestershire
Life energy is limited. The mind is insatiable. (Chuang Tzu)
CIOKS has the AC10 in their range which might be of use...
https://cioks.com/products/ac10/
Posts: 13121 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Is it about a bicycle?
Looking online, the AC current draw for the M9 is in the order of 1200mA. I expect the supplied PSU is rated at 2A (not 2mA). That would rule out the 800mA Truetone unit. The Cioks unit as well unless you used two outputs in parallel. Though that may not leave much current for your other pedals.
Posts: 18710 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Post by GRAHAM99 »
Sorry my mistake it was 2a!!
GRAHAM99
Post by sonics »
It looks like the M9 draws about 550mA maximum when powered from 12V DC - yes DC...
CIOKS video
sonics
That's pretty conclusive. Good find!
However, why on earth did they specify 9V AC for the M9. It will be losing about a volt on rectifiers!
Post by GRAHAM99 »
So I could use a suitable dc adaptor?
GRAHAM99
Post by GRAHAM99 »
Also the plug seems to be a different size to my other pedals?
GRAHAM99
CIOKS generally come with a healthy selection of different size connectors. And if not in the box they can supply others.
Post by sonics »
Folderol wrote: Sun Jan 08, 2023 5:32 pm That's pretty conclusive. Good find!
I have a POD HD500X and was wondering about the current draw some time ago and found that video.
Unfortunately this sort of thing has been part of the industry for decades. I've got 9, 12, 15 and 18V AC and DC devices here. Throw in the 2.1mm and 2.5mm pin diameter fiasco and it's too much!
I have just finished a support conversation with Focusrite. They didn't even know whether one of their older devices was AC or DC... :roll:
In the end it turns out it can work with both, but their standard supply has changed from AC to DC. Jeez...
...but they did send me a power supply FOC without me even asking, which is fantastic! :)
sonics
Post by GRAHAM99 »
Might just leave things as they are!
GRAHAM99
GRAHAM99 wrote: Sun Jan 08, 2023 8:09 pm Might just leave things as they are!
Where's your spirit of adventure? :tongue::lol:
