32 or 64 bit
32 or 64 bit
Pure academic question, is there any advantage apart from the 4gb RAM limit on 32 bit, quality wise, to recording (Cubase 8.5 Pro) using 64 bit version?
Capitalisation is the difference between helping your uncle jack off a horse & helping your Uncle Jack off a horse.
Re: 32 or 64 bit
No. It's all about addressing more memory. You may get better performance in 64-bit mode as you can pull twice as much data in per clock pulse, but only if the code is optimised to do so (not all is). But more RAM these days normally is a huge advantage in running a DAW, especially with large sample libraries. However the sound quality remains the same.
Re: 32 or 64 bit
Thanks for that, you confirmed what I thought it might be. Only other problem I find is most of my lovely 32b plugs wont play ball with any kind of Bridge.
But not a major issue.
Re: 32 or 64 bit
Exactly.
In later versions (I’m not sure if it includes 8.5) Cubase added the ability to run the audio engine at 64 bit precision. That probably made no difference either in practice!
Re: 32 or 64 bit
In theory 32 bit floating point isn't quite precise enough for audio processing. That's why most audio processing engines use 64 bit floats or older hardware will use 48-56 bit integers.
Posts: 16942 Joined: Mon Sep 10, 2001 12:00 am
Re: 32 or 64 bit
As James says, there is a small theoretical benefit to 64 bit float which is basically to do with rounding errors. I doubt anyone would notice with real-world recorded audio, though, and all computers are 64-bit now anyway.
Posts: 43639 Joined: Fri Jul 25, 2003 12:00 am
Re: 32 or 64 bit
That’s true - but many plugins that need that precision already convert incoming 32 bit signals to 64 bit for internal processing.
Re: 32 or 64 bit
I'm intrigued by this comment, as I've had no problems running any of my now comparatively rare 32-bit plug-ins within Reaper using its own integral bridging.
Can you give a couple of examples of specific plug-ins that won't run within Cubase 8.5 Pro?
Posts: 22552 Joined: Wed Jan 13, 2010 8:44 am
Re: 32 or 64 bit
Reaper does seem to handle 32-bit plugins better than some (most?) other DAWs.
Posts: 29651 Joined: Sun Jul 05, 2015 12:00 am
Re: 32 or 64 bit
Even thouigh I have Amplitube 5, I like some of the sims in Amplitube 3, that wont load, neither do any Lexicon native reverbs, eTap2, or EMI TG 12412/12414 etc.
Re: 32 or 64 bit
I gave up running 32-bit plug-ins in Cubase ages ago, but also in Reaper, as they sat in a separate Window that was handled differently from the rest, and that got really annoying! Dunno if that's changes since then, as I've not looked back...
- Matt Houghton
Frequent Poster - Posts: 1600 Joined: Wed Aug 08, 2007 12:00 am
SOS Reviews Editor
Re: 32 or 64 bit
I still use jBridge occasionally and always found it reliable; you could try the demo.
Re: 32 or 64 bit
Matt Houghton wrote: ↑Thu Jan 26, 2023 4:30 pm
It still launches in a separate window but doesn't seem to have any other different handling that I've noticed.
Re: 32 or 64 bit
Matt Houghton wrote: ↑Thu Jan 26, 2023 4:30 pm I gave up running 32-bit plug-ins in Cubase ages ago, but also in Reaper, as they sat in a separate Window that was handled differently from the rest, and that got really annoying! Dunno if that's changes since then, as I've not looked back...
With Reaper it depends on how you like to work. I often open plug-ins from the mixer so every plug-in opens in its own window and 32 bit plug-ins are no different. If you access plug-ins from the dialog box that opens when you click the FX button in the track control panel then you will notice a difference because 32 bit plug-ins still open in their own window and I can't see any way to change this in the preferences.
Re: 32 or 64 bit
Cakewalk has/had bitbridge which for me was seamless [mag review~2010 suggests it was limited in the number of instantiations].
Stuff still works, so I guess its all still going on in the background.
I wish they would have a similar wrapper that could take 44.1/48K VSTs up to 96k, just for convienience.
Re: 32 or 64 bit
Martin Walker wrote: ↑Wed Jan 25, 2023 7:46 pm
Had a good look at my Cubase install and it seemed after a few years I had a few bits missing (not me my brain) so a repair of Cubase 8.5 re-installed the missing bridge and things seem to be stable at moment thanks for all help/comments.
Re: 32 or 64 bit
I think you can guess what I'm going to say...
Try Reaper. They added this feature a few months ago. It can now resample up to 16X the original sample rate (though I've never felt the need to go higher than 2X).
Re: 32 or 64 bit
James Perrett wrote: ↑Fri Jan 27, 2023 10:23 pm
Like you, I'm using Reaper's x2 for most of the plug-ins that benefit from oversampling, but I do have two or three preamp/saturation plug-ins that ideally need x4 to minimise artefacts.
