Strange studio power issues.
Re: Strange studio power issues.
Post by tea for two »
Preehaps for this Mission Impossible : Mad Max legendary Studio Support Gnome.
tea for two
Posts: 4015 Joined: Sun Mar 24, 2002 12:00 am
tea for two wrote: Sat Jan 28, 2023 10:00 am Preehaps for this Mission Impossible : Mad Max legendary Studio Support Gnome.
I don’t think Max could help, he’d lapse into a sudden coma if he saw this place.
Posts: 19426 Joined: Sat Jul 12, 2003 12:00 am
Post by ajay_m »
Tingling on exposed metalwork is common with double insulated non earthed PSUs as a result of internal capacitive leakage generally across transformers, which have a few hundred picofarads of parasitic capacitance. The current is very low but it can damage preamps if you hot plug audio leads with power on.
The strange PSU behaviour you mention may be associated with internal circuitry that remains charged after the power has been turned off.
Ideally your studio power feed is via one or more RCDs. These will trip if the differential line and neutral currents have more than a few milliamps difference and any kind of ground leakage issue will normally trip them.
If you have a damp issue you need to look at some pretty expensive climate control of the sort that is used to protect vintage wine cellars. This is going to require ducts and large holes to vent to the outside.
ajay_m
Posts: 1221 Joined: Mon Jan 16, 2017 7:08 pm
