Home Studio - Do I go audio interface or mixing console
Re: Home Studio - Do I go audio interface or mixing console
If any "quality" tests are so close, that a guess is required, then AFAIC I’d probably be happy with any of them, it seems a lot off folks these days are getting a bit too obsessed with things on a microscopic level, that don’t really matter in the real world.
Posts: 21824 Joined: Sat Jul 12, 2003 12:00 am
Post by tea for two »
Arpangel wrote: Sun Jan 29, 2023 8:21 am I’ll be honest, my budget is virtually unlimited
In which instance, just in case you haven't considered this already, haven't done this already :
purchasing music gear for deprived Schools in London.
There are so many deprived Schools in London they would be over the moon to receive just a few bits of music gear.
Also for deprived community centers in London.
In the approx 200 towns in London pretty much most of them have a community center with plenty of them deprived.
tea for two
Just about every audio interface can give you acceptable sound quality these days. The differences are down to:
1. Whether it can handle the inputs and outputs that you want to use. Some people need full professional level capability to connect to older gear but not many audio interfaces can output +24 or +28dBu. Another issue seems to be a lack of headroom in mic preamps with certain interfaces.
2. Whether the drivers are reliable and capable of low latency. Check things like is it easy to change sample rate or change clock source?
3. Is the manufacturer well established and are they quick at supporting new operating systems for their old interfaces? Many manufacturers rely on third parties to write the core of their drivers so don't have the expertise to support their products if that third party no longer wants to support them.
Posts: 16945 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
" Another issue seems to be a lack of headroom in mic preamps with certain interfaces."
I agree James and this is always going to be a bit of a problem with 'simple' AIs with a single mic gain control. The designer then has to strike a balance between enough clean gain for a dynamic mic or decent headroom.
Most seem to plump for higher gain on the basis I guess that many home bods will, initially at least, go for a dynamic mic. Should they aspire to a hot capacitor they can buy XLR pads.
FYI I checked my M4 and it has a max (min gain) input level of +10dBu or 2.5V rms for jazz. Pretty good methinks and it certainly has the low noise and gain for a '58.
Posts: 19097 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
ef37a wrote: Sun Jan 29, 2023 12:24 pm FYI I checked my M4 and it has a max (min gain) input level of +10dBu or 2.5V rms for jazz. Pretty good methinks and it certainly has the low noise and gain for a '58.
That seems very respectable - equivalent to around 143dBSPL from an AKG C451.
James Perrett wrote: Sun Jan 29, 2023 11:47 am Just about every audio interface can give you acceptable sound quality these days. The differences are down to:
I can put up with poor support, "if I have to" if sound quality is good.
What some people are "suggesting" is that that’s up for compromise, if driver stability and customer support are priorities.
In the heady world of pro recording, these issues occur all the time, how many times have we been told quality is unquestionable, it’s an "industry standard" bit of kit, industry standard? It’s rare you get something that ticks all the boxes, including the one that seems to be way down the priority list for some users, and that’s sound quality.
I’ve paid a lot for interfaces that have great driver support, great build quality, great compatibility etc etc, but they sound awful, I can’t sit there and listen to them for more than a couple minutes before I want to throw them through the window.
Of course, it is possible to have it all, and most of the interfaces that I like are plug and play, no drivers required, and they never break down, so a lot of these issues just don’t apply.
tea for two wrote: Sun Jan 29, 2023 10:46 am
I’ve given away more gear than I can remember, and if you can show me an individual, that has talent coming out of every orifice, and the only thing holding them back is money, I’ll be there.
But just like foreign aid, you can never be sure it gets to where it’s intended.
Arpangel wrote: Mon Jan 30, 2023 8:39 am I’ve paid a lot for interfaces that have great driver support, great build quality, great compatibility etc etc, but they sound awful, I can’t sit there and listen to them for more than a couple minutes before I want to throw them through the window.
Tony - I think what you are trying to say is that you disagree with everyone else here when it comes to RME.
What you seem to ignore is that RME interfaces have plenty of digital connections so no-one is forcing you to use their convertors although most people's reaction to their convertors is very different to yours. The only rational explanation that I can think of is that you heard the analogue output from one of the original Hammerfall cards which was intended to be used for convenience rather than quality.
The Elf wrote: Sun Jan 29, 2023 8:57 am Ahem... Some of us got pretty close... ;)
As I recall a few people did identify most preamps correctly, but it was only a few, and no one got them all right.
The results of the 'preferences' survey are here:
https://www.soundonsound.com/reviews/preamp-post-mortem
The really striking thing was just how widely spread and inconsistent the reported views actually were.
Posts: 43641 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
My main take from that article was that there were a host of other things I needed to get on top of before I started worrying about the pre-amps in my interface. ;)
Posts: 29653 Joined: Sun Jul 05, 2015 12:00 am Location: York
... is the correct answer! :D:thumbup:
blinddrew wrote: Mon Jan 30, 2023 3:39 pm My main take from that article was that there were a host of other things I needed to get on top of before I started worrying about the pre-amps in my interface. ;)
:clap::thumbup:
Posts: 21413 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
James Perrett wrote: Mon Jan 30, 2023 12:10 pmThe only rational explanation that I can think of...
I can think of lots of rational reasons. The bottom line is that none of us know the circumstances under which Tony used an RME interface. We don't know what interface it was, how it was set up, what the clocking arrangements were, we don't know what input levels it was dealing with and what I/O levels it was configured for, etc etc...
It's not hard to make something sound terrible by mis-using it and, with the very best will in the world, Tony does have an extensive track record of 'operational difficulties'.
On the other hand, maybe he can hear unpleasant artefacts that no one else can... At the end of the day, you pays yer money and makes yer choice and his choice is for other than RME.
For balance, though, I'm a very happy long-term RME user.
Hugh Robjohns wrote: Mon Jan 30, 2023 3:49 pm For balance, though, I'm a very happy long-term RME user.
Same here :thumbup:
Posts: 22556 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by Chet Leeway »
blinddrew wrote: Sat Jan 28, 2023 5:41 pm So I'd probably look at something like an Audient EVO16 and then expand via their EVO SP8 (or similar).
Not a bad suggestion for a drummer. One of the selling points of the EVO range is SmartGain, which sets the levels for you automatically. Potentially a time (and ass) saver if you like to change drums and/or mics. Just swap gear as you wish, then sit down and play for a bit to let the interface set the levels.
Chet Leeway
Posts: 163 Joined: Fri May 06, 2016 8:13 pm Location: Barcelona
Post by sonics »
Hugh Robjohns wrote: Mon Jan 30, 2023 3:49 pm On the other hand, maybe he can hear unpleasant artefacts that no one else can... At the end of the day, you pays yer money and makes yer choice and his choice is for other than RME.
I've never heard "unpleasant artefacts" from any RME interface, and neither has any other pro I know that uses them. It must have been wired or configured incorrectly, or broken. Or perhaps it exposed the unpleasant qualities of the audio material because of it's accuracy. That happens! :)
There must have been an issue somewhere, and these experiences do colour our memories in indelible ways.
sonics
I think there's something to be said about having £Thousands disposable funds to spend on music gear, purchasing various gear, yet being satisfied with £50-£150 gear as ArpAngel has done
as this concurs with the experiment
Comments about API, Neve, Prism from the experiment made me chortle lol :
as spending upto £2k on outboard doesn't necessarily mean it's going to stomp far cheaper interfaces.
tea for two
I bought a UCX around 2013, I don’t know what converters that used, of course, I should imagine most users wanting a "main interface" would be looking to use the analogue outputs for monitoring.
So this isn’t a Hammerfall device.
I got the UCX as a few people recommended it, it was at a time when I could actually start considering more up market choices, regrading gear, and the first thing I bought was the UCX.
It had all I needed, connection wise, and I was expecting a lot after using an M-Audio Audiophile for a few years.
But it wasn’t to be, I so much wanted it to be a success, for me, but I just couldn’t get used to it, I’d give them another go, but I can’t think of any facilities, for me personally, that I can’t get anywhere else.
TotalMix... :lol:
Hugh Robjohns wrote: Wed Feb 01, 2023 5:33 pm TotalMix... :lol:
TotalMix. :clap::clap::clap::angel:
I never want to have to work without TotalMix.
RME make fabulous gear. I've never had any reason whatsoever to complain. They sound fabulous and they just work - day in, day out.
Post by Rene Asologuitar »
richermusic wrote: Sat Jan 28, 2023 10:57 am Hi everyone
I have really enjoyed being on this forum so far and have found the advice really helpful so thank you to all the members.
I am currently starting my own home studio for the purposes of recording drums and also producing recordings for some of the bands that my company manages (only covers etc - not signed artists).
Currently - I have a 6 meter by 6 meter space to work in. I was planning on having the computer / mixer etc all in one room.
My big question is what do people suggest in terms of audio interface over perhaps using something like a behringer X32 or Presonus Studio Live for instance.
There’s a lot of different routes I can see and even going down the Apollo universal audio route which scares me due to how much money it costs if you want anything with a decent amount of channels.
Does anyone have any advice? I am sure it will Chuck up more questions than answers but I wanted to start somewhere. Ideally I am looking for at least 16 channels as drums take up a lot.
Great question.
I am interested and will be following.
Rene Asologuitar
Posts: 76 Joined: Sun Mar 06, 2022 5:06 am
Post by richermusic »
omnamic wrote: Sat Jan 28, 2023 11:18 am What’s your DAW?
Audient preamps are great for drums, so if you haven’t got any preamps yet, I would suggest you try going with that: iD 44 interface plus 2 ASP 800 or 1 ASP 800 and 1 ASP 880. The iD 44 lets you integrate outbord. That with an additional DAW controller with 8 or more faders and you‘re good to go for live recording and mixing without blowing too much money. I would prefer this setup to a mixer these days.
This setup seems to be highly recommended in a lot of places.
My only question is, how do you give your musicians an individual aux send so that they can hear themselves whilst recording? Is that something the ID44 can do? This was something I was keen on the behringer x32 for as I know it has a lot of aux outputs.
With the audient setup, is that all you would need as well in order to get all your monitors etc all connected up?
richermusic
Posts: 12 Joined: Sat Jan 14, 2023 10:57 pm
richermusic wrote: Thu Feb 23, 2023 7:32 amMy only question is, how do you give your musicians an individual aux send so that they can hear themselves whilst recording? Is that something the ID44 can do?
You create however many aux sends as you need in the DAW and route them to the ADAT outputs which you then access via the line outputs of something like Behringers ADA8200.
There will be latency involved, and slightly more than with a digital console (or RME's Totalmix) because if the run into the computer and back, but it's not usually a problem.
Yes. I think Audient have some helpful setup videos on their site. And download the user manual as that includes setup suggestions too.
richermusic wrote: Thu Feb 23, 2023 7:32 am My only question is, how do you give your musicians an individual aux send so that they can hear themselves whilst recording?
As Hugh mentions above - this is why I choose RME interfaces. TotalMix makes setting up monitor feeds (any sub-mixes, in fact) a doddle. Latency becomes a non-issue.
edited to fix quotes - Andy :beamup:
