Too much delay
Too much delay
Post by mountain lion »
Hi
I m using delay on vocals and the feedback knob and mixwet knob . With just a little turn it becomes overbearing . What to do?
Thank you
mountain lion
Posts: 197 Joined: Sat Apr 11, 2015 12:00 am
Re: Too much delay
Sounds like you may have created a feedback loop. Check your routing.
Posts: 20929 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Re: Too much delay
Sounds like you have the feedback turned up too high and/or you have an external feedback loop from the delay's output back to its input via the mix console.
Try this:
Turn the delay and feedback knobs down and the dry-wet mix to the middle.
Turn up the delay until the timing is just right. If you're hearing more than one delay you probably have an external feedback loop going on. Sort that out first!
Then turn up the feedback knob a little to get the number/duration of repeats you want
And finally, adjust the dry-wet mix to get the level of delays right relative to the dry signal.
Posts: 41753 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Re: Too much delay
but there is no delay knob in replika xt?
mountain lion
Re: Too much delay
What are you talking about? It has mix and feedback knobs and knobs to adjust the delay time.
Posts: 17936 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Re: Too much delay
this is amazing. the big delay time knob has vanished. i don't have it.
mountain lion
Re: Too much delay
There are two delay knobs (one for each delay) if set to 'dual' mode (bottom left switch). If set to 'single', there will be just one.
