Any options?
Any options?
Post by SudsMaker »
So I'm not sure if this is the right forum or not.
I have a Blue Yeti microphone that I use during gaming. I was hoping to stream with it but my house situation seems to cause some background noise. I am using OBS Studio to stream but I can't get the filters Noise Gate, Noise Suppression, etc. to block out the noise in the room without blocking out my voice.
This may not be fixable with the audio equipment but just thought I'd ask.
So my wife sits in the same room as I do watching the television. The sound is rather loud on the TV and I can't seem to filter it out with any filters so far.
Is this just a situation where I need to somehow get the TV or my desk to another area? The TV is like 15' away from me but we don't have much in the room to catch the sound like carpet or something.
SudsMaker
Posts: 1 Joined: Thu Feb 02, 2023 2:27 am
Re: Any options?
Yep, short answer is that this is room problem not a mic/filter/gate problem.
Our ears are really good at filtering out background noise to concentrate on speech - a microphone doesn't do that, it captures everything.
Playing around with gate thresholds and release times may give you some small benefit, but you'll still be fighting with the TV every time you speak.
Posts: 28197 Joined: Sun Jul 05, 2015 12:00 am Location: York
Re: Any options?
The mic has a choice of four pickup pattern. Do you know which one of them you are using?
Cardioid is the most directional pattern, and should reject most of the sound coming from behind it. So if you can rotate your seating position so the back of the mic is facing the TV, you'll minimise the direct sound that's picked up.
You'll still get reflected sound being picked up, but it might now be at a level where there's enough differential between background noise and your voice that a noise gate might work.
But if you don't want to have any background noise, then moving to a different room is the only real answer.
Posts: 18383 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Re: Any options?
Post by resistorman »
Get your wife some nice comfy headphones for the TV?
resistorman
Posts: 2892 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Re: Any options?
Post by AlecSp »
Maybe think about having a more useful thread title...
AlecSp
Posts: 766 Joined: Tue Nov 16, 2004 12:00 am Location: Herts, UK
Re: Any options?
Post by Rene Asologuitar »
SudsMaker wrote: Thu Feb 02, 2023 2:39 am So I'm not sure if this is the right forum or not.
Wireless headphones for the wife.
Rene Asologuitar
Posts: 76 Joined: Sun Mar 06, 2022 5:06 am
Re: Any options?
It would be worth trying a headset mic instead of the Yeti. When you need to separate direct and ambient sounds, mic proximity to the wanted source makes a very big difference. Some headset mics are noise cancelling too.
Posts: 42301 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Re: Any options?
Post by Exalted Wombat »
You can improve things by getting a mic closer to your mouth, maybe (as suggested) a headset mic. But the real answer - sorry if it's too obvious - is to NOT be in the same room as a loud TV.
Exalted Wombat
Posts: 5839 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
