Cheap CD player to hook up to Yamaha MG16X 16-Channel Mixer and how?
Post by punkyfish »
Hi,
I want to hook up a CD player to our mixer but need help with:
1. A relatively cheap CD player that will do the job playing backing tracks
2. What cables I need to be able to do it
Am based in UK, thank you for any help
punkyfish
Posts: 61 Joined: Sat Mar 16, 2019 11:59 am
Re: Cheap CD player to hook up to Yamaha MG16X 16-Channel Mixer and how?
Any separates CD player with a set of RCA (also called phono) outputs, an RCA-RCA cable, plug into the RCA inputs on either of the last two channels on your mixer.
As to the actual player itself, you're almost certainly best looking second hand. Richer Sounds cheapest standalone CD player is £159. You'll get a perfectly good one from any of the main Japanese brands for about £30 from a second hand shop.
Posts: 29293 Joined: Sun Jul 05, 2015 12:00 am Location: York
All CD players have unbalanced outputs on RCA-phono sockets.
And your mixer has unbalanced stereo inputs on RCA-phono sockets on the last two stereo channels 13/14 and 15/16.
So all you need is a standard stereo RCA-phono lead. The CD player may come with one in the box. If not you can find them easily on Amazon or other outlets.
As for the CD player, again you'll find plenty to choose from on all the usual online retailers.
However, CDs are a bit clunky and bulky these days. I'd replay tracks stored* on a phone or mp3 player. You'd need a 3.5mm mini jack to dual RCA-phono plug lead to run from the player's headphone output to mixer input.
*Make sure they are downloaded and stored on the player, not streamed live over the Internet or 4G! Mr Sod will ensure that streaming will work during the soundcheck but not the gig!
Posts: 43290 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
It may be more convenient to have a battery powered (but maybe with a PSU) portable CD player. I’ve used one in the past.
In that instance you’ll probably only have the headphone output, so you’ll need a 3.5mm TRS to two RCA connector lead.
Do you need the facility to play certain tracks or loop back to the beginning?
Posts: 18926 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Post by punkyfish »
Hugh Robjohns wrote: Thu Feb 02, 2023 8:52 pm
Thank you, struggling to find a CD player online though with outputs, one that isn’t ridiculously expensive anyway. The MP3 idea sounds good, the only thing is all of our backing tracks are on CD
punkyfish
Post by punkyfish »
Thank you for your quick reply. It needs to be new as work are purchasing but I know they won’t pay that.
punkyfish
Post by punkyfish »
Wonks wrote: Thu Feb 02, 2023 9:01 pm It may be more convenient to have a battery powered (but maybe with a PSU) portable CD player. I’ve used one in the past.
If we could play back certain tracks and loop that would be good, I have seen lots on Amazon with a headphone socket but it states they are input only. Is that what you mean? Thank you for the reply.
punkyfish
punkyfish wrote: Thu Feb 02, 2023 9:37 pmThe MP3 idea sounds good, the only thing is all of our backing tracks are on CD
If you only have your audio on CD you risk the chance that a disc becomes damaged and your audio would be gone for good! Hopefully you have backup CDs.
CD was never an ideal backing medium - one slight knock on the player and all hell could break loose.
It's simple to rip the audio from CD and render to a file. I would actually rip to WAV files and use those, unless you are really struggling for space on whatever device you use for playback.
Ripping from CD is simple and can be done from any computer format (as long as it still has an optical drive - most don't now). I'm sure there are loads of YouTube videos that will guide you through it.
Posts: 21316 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by punkyfish »
Thank you for the reply. We do have backups. If I rip to a Wav file, what would I use to playback and what lead would I need? I have an iPod but to be honest I have never had success with it nor my iPhone. I have never been able to either get stuff off my phone or put stuff on it. Hence the CD idea
punkyfish
punkyfish wrote: Thu Feb 02, 2023 9:37 pm Thank you, struggling to find a CD player online though with outputs, one that isn’t ridiculously expensive anyway.
Try searching for rack mount CD players. You do get what you pay for, but much depends on what facilities you require.
It's trivially simple to rip the CD to audio files and load those files on a player or smart phone.
Post by Mike Stranks »
I stopped using CDs for live-work I guess in about 2010...
For a while I used a small laptop - 11" screen, but fairly quickly switched to a 7" Android tablet... using WAVs...
Small, easily portable and utterly reliable IME.
Mike Stranks
Posts: 10586 Joined: Fri Jan 03, 2003 12:00 am
The issue with domestic CD players skipping if moved is a real one, even the slightest knock or floor bourn vibration can cause real problems* (I know this from personal experience :blush: ). The only sensible option is to use an .mp3/.wav device.
* A professional CD, rack mount or DJ type will have decent shock resistance but will cost many times more than a domestic CD player.
Posts: 22607 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by OneWorld »
I use the Alesis Masterlink 9600
They have phone and SPDIF i/o and you can also copy the contents of a CD to the internal hard disk.
You can have a maximum of 16 playlists on the HDD and each playlist can have a number of songs in it, I can't remember how many now but it is a significant number.
Alesis stopped making these eons ago, but they still turn up on the usual 'pre-loved' sites and at reasonable prices. Erm - I just checked on eeebHay, WOW the prices have shot up :thumbdown: Might be worth keep checking though
I have found mine to be very reliable (fingers crossed :roll: )
OneWorld
Posts: 5759 Joined: Tue Apr 07, 2009 12:00 am
Post by Rene Asologuitar »
punkyfish wrote: Thu Feb 02, 2023 8:20 pm Hi,
I have a Yamaha MG8x, and I use an RCA cable to hook the player to, and it works great!!!
Rene Asologuitar
Posts: 76 Joined: Sun Mar 06, 2022 5:06 am
Post by punkyfish »
If a CD player has a headphones input Jack, will that work with a cable to my mixer? Struggling to find a CD player
punkyfish
A headphone socket is an output rather than an input, but yes, it should. As Wonks said above, you'll need a lead with a 3.5mm jack at one end and two RCAs at the other.
Post by punkyfish »
Thank you very much
punkyfish
Post by sonics »
If you have a CD player, use the line outputs, NOT the headphone socket, please!
sonics
Post by punkyfish »
If the mo3 player has a usb-c input, will a usb-c to rca work as well? Thanks
punkyfish
USB is a digital connection and the headphone socket analogue. A USB C to dual phono lead must have a D/A converter built in. You are more likely to find a USB C to 3.5mm TRSF socket though.
* Unless, I suppose, it is SP/DIF I/O or a video format but I've never seen one of those.
Post by OneWorld »
punkyfish wrote: Fri Feb 03, 2023 7:39 pm Struggling to find a CD player
There are lots on eBay, from £20.00
CD Recorders too.
Might be worth checking out charity shops, the one local to myself has them in each week, though the majority tend to be those mini-bookshelf 'music centres' you could still detach the tuner and whatever and just use the cd player
OneWorld
OneWorld wrote: Mon Feb 06, 2023 12:48 am
CD Recorders too.
Yup!
This time last year I helped dispose of the gear of a late friend (Covid victim).
There were 4 or 5 CD-players/recorders... and good ones too!
I had no trouble disposing of them via eBay, even though I'm reasonably rural and it was 'Buyer Collects'.
(A word of caution on the mini-systems. Some of the ones I've seen that appear to be 'separates' use proprietary 'all in one' - mains and signal- interconnects between the units, so not easily used in standalone mode.)
Mike Stranks
As has been said, CD players are prone to vibration issues. You can live with the occasional glitch if just for interval music, but not during performance if it’s a backing track.
Which is why if you must go CD, I’d suggest a portable ‘Discman’ style one (normally round). These at least would be designed to cope with a certain level of vibration on the move and have a much larger internal read-ahead data buffer than a domestic hi-fi CD player so that they can play back from the buffer whilst the device tries to re-read any disc data lost due to the player being shaken.
But as has been said, a phone or tablet is a much better playback device for playing backing tracks and that’s what I’d use.
Post by BigRedX »
These days I would even think about considering a device with moveable parts for audio playback in a live situation.
BigRedX
Posts: 3035 Joined: Fri Sep 03, 2004 12:00 am
Post by OneWorld »
Wonks wrote: Mon Feb 06, 2023 8:24 am As has been said, CD players are prone to vibration issues. You can live with the occasional glitch if just for interval music, but not during performance if it’s a backing track.
Yep I have one of those. And it plays faithfully everytime I use it, and it's at least 20 years old
OneWorld
