Behringer Xenyx 1202 Power Supply
Re: Behringer Xenyx 1202 Power Supply
Post by ajay_m »
This should do the trick https://www.mouser.co.uk/ProductDetail/ ... %2FA%3D%3D
only £17 quid ex vat.
Only 1 in stock though, better hurry :)
ajay_m
Posts: 1612 Joined: Mon Jan 16, 2017 7:08 pm
ajay_m wrote: Fri Feb 03, 2023 10:50 am This should do the trick https://www.mouser.co.uk/ProductDetail/ ... %2FA%3D%3D
Well that transformer will 'do' but surely, if you have to buy a new one buy better specc? The mouser traff has a slightly lower VA rating than mine and nominally a volt more output and mine runs quite warm. A toroid will be more efficient, especially since it will be run constantly at close to VA limit. You are not subject to the cost restraints of production.
Posts: 18880 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
https://www.rapidonline.com/Transformers
CPC & Rapid have a reasonable selection of 18-0-18V transformers.
The Rapid site is a bit more searchable/filterable. They also do enclosures [some plug top style].
Extra care is required mounting torroidals to make sure the bolt through the middle doesnt become a 1 turn coil !
Posts: 4783 Joined: Sun Aug 12, 2018 2:40 pm Location: British Isles
Torroidal transformers also have the advantage of a much weaker radiated field.
Posts: 20645 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
N i g e l wrote: Fri Feb 03, 2023 12:12 pmExtra care is required mounting torroidals to make sure the bolt through the middle doesnt become a 1 turn coil !
Sorry, Nigel, for the ignorant amongst us, i.e. me, can you elaborate on that please?
Posts: 29431 Joined: Sun Jul 05, 2015 12:00 am Location: York
The fixing bolt passes through the centre of the toroid and needs to be insulated from forming a complete loop with the chassis, i.e. a secondary winding with one turn. If it does a very large current would flow through the bolt and the chassis. Have a look at those instructibles on making a spot welder with the transformer out of a broken microwave, the secondary is 3 turns and the current it can produce welds metal.
Posts: 22694 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Indeed! In fact it's quite common practice these days to secure torroids with plastic cable ties to eliminate this problem.
Ah, got you. Thanks. :thumbup:
The mounting bolt that goes through the middle of the torrid is subjected to the magnetic field and acts like a 1 turn seconday coil, with a potential at either end.
The bolt should only connect to a metal chassis at one end and be an "open circuit".
If both the top and bottom connect to the chassis, a circuit is formed and current will flow [possibly quite a lot ].
A torrodial transformer probably comes with a mounting kit, like this one [transformer shown mounted on top here rather than on a base]
Post by Steve Jupe »
I have one of these excellent mixers (Xenyx 1202 with Klack Teknik FX) but my power supply (MXUK5) has a broken DC connector plug. Any idea where I might be able to get a replacement plug that I could solder on? It looks like a quirky behringer design, with three metal pins and a black rectangular (plastic?) pin.
Steve Jupe
Posts: 1 Joined: Fri Aug 18, 2023 10:22 am
Steve Jupe wrote: Fri Aug 18, 2023 10:31 am I have one of these excellent mixers (Xenyx 1202 with Klack Teknik FX) but my power supply (MXUK5) has a broken DC connector plug. Any idea where I might be able to get a replacement plug that I could solder on? It looks like a quirky behringer design, with three metal pins and a black rectangular (plastic?) pin.
No Sir! Not a "DC" 3 pin supply but 17.5-0-17.5 volts AC. The connector is total crap. I bought two of those mixers and on both the power connector (loosely based on the old PS2 'puter conn') was prone to cause serious hum as it moved about.
I modded both mixers by going inside and removing the offending socket and fitting a short piece of balanced mic cable. The first mixer was fitted with a mini XLR 3 inline plug and socket (but mixer side cable tied to chassis). Very neat but those connectors are **AST***D fiddly to solder and assemble, at least for me, so the next one had a chunky standard XLR on it. The neat one went off to France to my son.
I am fairly sure those *&&^%$! plugs are moulded on so I doubt you will find a 'solderable' one. Best bet is the correct supply from Behringer or Ebay. You might even be lucky enough to find someone with a burned out traff who will sell you the cable? Bit o solder, bit o heat shrink..Bob's yer whatsit.
Steve! I rarely throw anything 'lectrical away and so I have found one o f the 3 pin plugs with about 50mm of cable attached. There is red, green and black so you would have to work out what goes where but, being AC you just need to establish common which is chassis and the other two don't matter.
PM me with an address (UK ish I assume?) and I will post it off PDQ.
Post by ajay_m »
A truly Frankenstein setup could also be cobbled together from two 18vac adapters (about £12 each on amazon). Plug them both in to a two socket adapter block and glue them in so one can't come out. Then just connect the two outputs in the right phase to make 18-0-18. This is electrically perfectly safe just rather Heath Robinson. I would wire a pair of 1.5A fuses on the outer power rails perhaps just to assuage my conscience here.
ajay_m
ajay_m wrote: Fri Aug 18, 2023 5:07 pm A truly Frankenstein setup could also be cobbled together from two 18vac adapters (about £12 each on amazon). Plug them both in to a two socket adapter block and glue them in so one can't come out. Then just connect the two outputs in the right phase to make 18-0-18. This is electrically perfectly safe just rather Heath Robinson. I would wire a pair of 1.5A fuses on the outer power rails perhaps just to assuage my conscience here.
It's just the connector that's broken here, not the PSU, which is still providing power.
Posts: 19031 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
There could be a problem with using a nominally 18-18 volt transformer? That would put an extra half volt across each regulator, not a lot I grant you but Behringer are not known for rugged 'worse case' engineering!
Also. a transformer with a higher VA rating will deliver even more than nominal 18V. In the general case of an 'alien' transformer it is wise to fit a resistor in each 'leg'. Start at say 4R7 and see how the voltages come out.
He doesn't need a transformer... he needs the plug!!!!!
Posts: 43426 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Hugh Robjohns wrote: Sat Aug 19, 2023 11:50 am He doesn't need a transformer... he needs the plug!!!!!
I was commenting on the idea of using an ad hoc transformer generally Hugh. I assume that is allowed?
I HAVE a plug for him...All I need is an address to send it to!
It's confusing for the question asker. Better to start a new thread if you want to Ad Hoc away.
Wonks wrote: Sat Aug 19, 2023 1:22 pm It's confusing for the question asker. Better to start a new thread if you want to Ad Hoc away.
The whole THREAD is about transformers Wonks. Are you and Hugh going to have a pop at Will?
Dave
