Following advice on the forum
Now to test. Start with basic playback over Apple Music. With TotalMix fired up there's a signal showing in Software Playback at the meters for ADAT 1/2. Similarly, in Hardware Outputs there's signal on the meter for PH. Hardware Outputs ADAT 1/2 assigned to Main Out in Control Room also shows signal. All as expected. However . . . while I get audio out of the headphone output of the Digiface, there's nothing from my monitors.
Mmmm. First thought was there's something going on with Software Playback. But . . . Test signal (DI bass) shows on the meters in Hardware Inputs and Main Out, but again nothing audible.
I've double checked cabling, power, etc. and the monitors are fine with audio from my CD player so it doesn't appear to be hardware. I anticipate it's a routing problem between the Saffire and Digiface, but I cannot fathom what I'm doing wrong. There are only two cables and signals are showing on meters as expected in TotalMix.
Any thoughts?
