Yamaha 01v96 v2 channels 9-16 wont turn on
Post by drickner »
I just received my Yamaha mixer and it has the MY16-AT card in it. My problem is that I cannot turn on channels 9-16. The first 8 work fine, but these won't turn on. I have done a factory reset of the board, and looked through the manual some, but I'm at a loss how to use the onboard preamps for those last 8 channels.
I'm planning on using this on small live venues, so I don't need any of the outboard inputs. 16 channels is fine for my current usage situation.
drickner
Posts: 13 Joined: Tue Mar 14, 2023 10:22 pm
Re: Yamaha 01v96 v2 channels 9-16 wont turn on
Have you checked the input routing?
Posts: 43689 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by drickner »
yes I have. 1-8 have PAN selected and 'S' at the bottom, and 9-16 have the identical settings.
drickner
Post by Kwackman »
I think the page you need is accessed by pressing "Input Patch" button on the "Display Access" panel to the left side of the 02R display.
Scroll to the page "Input Ch1-48 Patch".
As you can see each channel has a box showing what's selected to each input.
Do the buttons for 9 to 16 show "AD9" to "AD16"?
If not, try changing them to be "AD9" to "AD16" to see if that helps?
I downloaded the manual and the page I'm referring to is on page 66 of the downloaded version I have.
Kwackman
Posts: 3686 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Post by OneWorld »
As already mentioned, check the patching. I had one of these mixers and the patching isn't intuitive, until you've become familiar with it of course and then it is easy peasy.
The thing is with this mixer, as i common with almost all digital mixers I would assume, you can patch any input to any channel.
One thing that does puzzle me is that when you say you don't get anything on channels 9-16, are you saying the analogue inputs on the desk itself are not working or just when you assign (or try to assign) the MY-16 ADAT card to 9-16?
When you are looking at the ADAT inputs, your default patching might be set to the 01v96 inbuilt ADAT i/o and would need to scroll to the card instead?
OneWorld
Posts: 5957 Joined: Tue Apr 07, 2009 12:00 am
drickner wrote: Tue Mar 14, 2023 11:52 pm yes I have. 1-8 have PAN selected and 'S' at the bottom, and 9-16 have the identical settings.
You're looking at the channel routing page (accessed by pressing the Display Access PAN/ROUTING button). The S button means the channel is routed to the stereo mix bus.
Instead, what you need to be looking at is the Input patching page (Display Access PATCH). On that page you will see the desk's 32 mono channels (and four stereo channels) shown with selection boxes indicating what's feeding each one. As explained above, to use the 16 mic preamps you need those boxes to read AD1 to AD16 across the first 16 channels.
It's shown and explained on page 122 of the V2 manual.
https://usa.yamaha.com/files/download/o ... _en_f0.pdf
Although compact, and a little antiquated by modern standards, the 01V96 is an immensely powerful and versatile desk with a great deal of configurability. You really will need to thoroughly read and digest the manual if you want to master the console and use it to its full capabilities.
Post by Kwackman »
OOPS, I thought it was a 02R96 desk, not 01V96.
Must have glasses on before responding next time!!
Apologies for any confusion.
Kwackman
Post by drickner »
thanks for all the replies. I have looked at the input patching and it is set so that channels 1-16 are patched to AD1 - AD16. This is not the first digital console I have used. Church uses the AH SQ6, so I'm familiar with how these things should work.
Any other ideas? I wish I could post pictures of the various screens and let you all see what I'm seeing.
drickner
drickner wrote: Wed Mar 15, 2023 1:27 pm Any other ideas? I wish I could post pictures of the various screens and let you all see what I'm seeing.
https://www.soundonsound.com/forum/view ... hp?t=75253
The link above should help you through the process of posting images. We don't host images on our servers, but you can use a number of 3rd party image hosting sites to upload your screen prints.
Posts: 13295 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Post by drickner »
thanks for the link. It may be a couple days before I can get things setup to post pictures, but I will get them posted.
drickner
Post by drickner »
trying to post images. we'll see if this works:
When I look at the routing / pan settings everything appears correct. I'm sure that I am missing something somewhere, but not sure where else to look. Also, I can only turn on channels 1-8 on layer 2. not sure if that has any bearing on this issue or not though.
edited to fix link - Andy :beamup:
drickner
The input patch page?
EDIT: Ah... it's turned up. Good, so the input routing is right, and so is the output routing.
Next step, check the analogue and digital inserts points... and check for channel mutes. Then the Gates and EQ attenuators.
Are the signal peak LEDs working on all 16 analogue inputs (if you crank up the gains)? That would prove the preamp and converter stages are working.
Post by Kwackman »
Hi,
Photos look good.
Apologies if you've already checked this, but to see how far signals are getting...
In the "Fader Mode" buttons panel - the "Home (meter)" button, keep pressing it until you get a window with "Meter" at the top LHS and "position" tab is at the bottom of the screen. Check that on the inputs "Pre EQ" or "Pre Fader" is selected.
Then keep pressing the same "Home (meter)" button again until the
"Ch1-32" tab is selected on the bottom LHS.
Is there audio showing on all the inputs, or only 1-8?
Not that it should make any difference, but are you using one source (mic?) in each channel in turn, or multi inputs at once?
These are nice desks, so hopefully you'll get it working properly soon!
EDIT TO ADD, before the link was changed, I clicked on it and there were 2 photos, including (I think) the input patch page.
Kwackman
Kwackman wrote: Sat Mar 18, 2023 4:05 pm EDIT TO ADD, before the link was changed, I clicked on it and there were 2 photos, including (I think) the input patch page.
Sorry, I missed the second image. Thanks to the wonders of browser history I've gone back to the original link and copied the second image location link and pasted it into the post with the 1st image.
Thanks Andy.
Post by Kwackman »
zenguitar wrote: Sat Mar 18, 2023 4:11 pmThanks to the wonders of browser history I've gone back to the original link and copied the second image location link and pasted it into the post with the 1st image.
:thumbup: Thanks.
Kwackman
Post by drickner »
I get the signal lights to turn on and if I turn up the gain far enough, the peak light comes on too.
drickner
Post by drickner »
Did some more experimenting, and I'm playing bluetooth off my phone to a BT receiver and then 1/4" into the console. On channels 9-16 I can verify that the input signal on the "meters" page is showing a signal. Also, if i turn up the fader, I get sound coming out, but I'm unable to turn on the "on" buttons for each of those channels. I have not tried xlr input yet. don't have a mic right now. does this give anyone ideas?
Also, How did you guys link in those pictures like that? I couldn't figure that out. The video I watched didn't seem to have any sound on it.
drickner
Post by Kwackman »
drickner wrote: Sat Mar 18, 2023 5:26 pm On channels 9-16 I can verify that the input signal on the "meters" page is showing a signal. Also, if i turn up the fader, I get sound coming out , but I'm unable to turn on the "on" buttons for each of those channels.
You put a signal into i/p 9, fade up the fader for ch9 and you hear it OK?
But the channel "ON" button is off? Weird!
I assume if you fade ch9 down the audio goes silent?
You are on the "1-16" layer, not "Master"?
Kwackman
drickner wrote: Sat Mar 18, 2023 5:26 pm Also, How did you guys link in those pictures like that? I couldn't figure that out. The video I watched didn't seem to have any sound on it.
It is a silent video so nothing to worry about.
The link you used was for the page on your hosting site. The actual pictures have their own unique web addresses. There should be a tool on the host site to copy those addresses, but I used my browser to open the image in a new tab and then used the option to copy the image address.
drickner wrote: Sat Mar 18, 2023 5:26 pmOn channels 9-16 I can verify that the input signal on the "meters" page is showing a signal.
Okay... but the meters can be connected to three different points in the channel signal path. By changing the meter point you can see where/if the signal is being lost.
Clearly, that makes no sense.
The ON switches might be being controlled by a mute group, so check that out.
But if sound is coming out through a fader it's via a different route, so check fader linking too.
If you haven't already, it might be worth doing a full hardware reset:
Press and hold the [AUX 1] and [HOME] button in the Fader Mode section while turning on the power switch to commence the reset sequence. (All user data is lost).
Yes, the video is mute. To embed images you need a direct link to the image file (it should end .jpeg or .png) . Paste that link into the post here, with img (in square brackets at the front) and /img at the end (in square brackets also).
Post by AlecSp »
All of this reminds me of how relieved I was to replace my 01v96v2 with an XR18 a long time back. That interface was so confusing.
From what I remember , following a factory reset, then channels 1-16 will by default be fed by AD1-16, and you should have consistent performance across channels 1-16. While it's very easy to get in a pickle when you're trying messing about with patching, the default configuration should be simple across channels 1-16.
Forget all the advice to check channel linking, inserts - you've already said you've done a factory reset, so you're using default settings.
You could try some further debugging by patching channels 1-8 to be fed from AD9-16, and channels 9-16 to be fed from AD1-8. Does the problem follow the inputs or the channels. Not sure if the board has separate ribbon cables for 1-8 and 9-16 - it wasn't obvious from the service manual. If you're getting sound when you turn up the fader, even though the channel is showing as "off" (no LED lit), then it may be as simple as the LED is not working.
You could also set up the Studio Manager software on a PC/Mac, which will give a software view of the surface configuration. If the mixer's channel on button is working, but the LED isn't, you'll see the Channel On/Off status in the software.
The problem could be more involved than that, though. I returned my first 01v96 as channel 1 didn't work. It wasn't my responsibility to debug/fix a faulty channel in a 10-20 year old mixer sold as fully working.
I'd suggest that this mixer may best be returned for a refund as faulty.
You might also want to think about buying a slightly more contemporary and user-friendly mixer.
AlecSp
Post by drickner »
Thanks for all the help on this issue so far. I did another factory reset just to be sure. I put the LCD sceen into the view mode for channel 9. I am able to turn it on/off via the menu and enter button, but pressing the 'ON' button itself doesn't do anything. If this picture comes out, look how the LED in 9 is about half as bright as the one on channel 8. Do I have some sort of hardware issue? If that is the case, maybe I can just return this thing where I got it and get a different one.
Pressing the ON button doesn't do anything, however I can turn them on/off via the menu.
still not getting images quite right. Here is a link that should work
https://imgur.com/F8hRhmo
drickner
You’re still linking to the image page, not the image itself. If it doesn’t have .jpg or .png at the end of the link, it won’t display. The site won’t display .webp images either.
Post by Kwackman »
drickner wrote: Sat Mar 18, 2023 6:55 pmDo I have some sort of hardware issue?
From that photo, you might have.
I'd a couple of other ideas, but resetting the desk would have blown them away, and that half lit LED isn't something I've seen on any Yamaha desk I've worked on.
Hopefully Hugh might have an "Aha!" moment.
I still like the Yamaha 01V96 (I spent a lot of time on the original 02R, the later 02R96, the DM2000 and a 01V96- never got to use a DM1000 to complete the set!)
I hope you get sorted.
Kwackman
