Yamaha CK series?
Yamaha CK series?
These could be the answer to my keyboard decision, looks a bit like a full size version of the mini/CS series, also look easy to understand, definitely going to check these out.
https://www.gak.co.uk/en/yamaha-ck88-s ... gLuNfD_BwE
Posts: 21952 Joined: Sat Jul 12, 2003 12:00 am
Re: Yamaha CK series?
I listened to the Yamaha video for it and it sounded like pure cheese. 90s ROMpler demo track stuff. Hopefully it sounds better in reality.
Wonks wrote: Wed Mar 15, 2023 8:17 am I listened to the Yamaha video for it and it sounded like pure cheese. 90s ROMpler demo track stuff. Hopefully it sounds better in reality.
Apparently got the electric piano sounds from the CP etc etc, that’s got to be good.
Also, I’m after standard strings brass, samples etc, I’m not averse to a bit of cheese served up on an 88 note keyboard.
Post by IAA »
I had a CP5 some years ago. The sounds were ok, no better or worse than it’s competitors but it was the action that sold it. Not sure if the CK 88 is the same keybed. Well worth trying.
IAA
Posts: 1622 Joined: Fri Dec 28, 2007 12:00 am Location: York
IAA wrote: Wed Mar 15, 2023 8:35 am I had a CP5 some years ago. The sounds were ok, no better or worse than it’s competitors but it was the action that sold it. Not sure if the CK 88 is the same keybed. Well worth trying.
Yes, I’m almost on the edge of pre-ordering this, on spec, because, it looks, very straightforward, seems to have all the sounds I need, plus the 88 keyboard, for a very reasonable price, if it works, it could be stiff competition for the current expensive stage keyboards, obviously it’s no Montage, they wouldn’t want that anyway, but then again, I don’t need that complexity either.
OMG!
It gets better, it’s even got BUILT IN SPEAKERS! and, it runs on batteries, even the 88!
Post by resistorman »
This pretty much ticks all your request sheet boxes :bouncy:
I'm sure you saw this, but a nice demo:
https://www.youtube.com/watch?v=k-2XBBEvpPI
resistorman
Posts: 2987 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
The "Analogue piano pad" is just like my Triton used to be, that’s a clincher.
Post by sonics »
Arpangel wrote: Wed Mar 15, 2023 8:25 am Apparently got the electric piano sounds from the CP etc etc, that’s got to be good.
I watched a few videos (it was released only two days ago, so there are lots of them - isn't YT wonderful ;) ) since I may be looking for a new stage piano fairly soon. The horrible organs made it a no for me. I'm not sure if the EP sounds are the same as the YC which I liked, but I'd be very careful. Play before buying (as usual).
sonics
Post by bonefixer »
resistorman wrote: Thu Mar 16, 2023 7:43 pm This pretty much ticks all your request sheet boxes :bouncy:
Nice demo indeed. But he did switch from the 88 to the 61 for the organ demos. Which in my mind summarises the fundamental issue of having an all-in-one board - you sometimes want a weighted piano, you sometimes want an organ/synth feel. I went away from one board for this very reason, and now have a YC61 on top of a CP88.
bonefixer
Posts: 84 Joined: Tue Jan 04, 2022 10:08 pm Location: Isle of Man
Gear: Loads of guitars, Line 6 Helix, Yamaha THR30 amp
Bechstein 1932 5’3” Grand Piano, Yamaha CP88, Yamaha YC61, Nord Wave2, Arturia Keystep Pro, Arturia KeyLab88, MacBook Pro, Mainstage, MAudio and Presonus interfaces, Behringer XAir mixer…
bonefixer wrote: Sat Mar 18, 2023 12:07 am
I’m not sure about this CK, also I tried a YC61 and the build on that I thought was awful, the keys were sloppy, and it just felt cheap, but you just don’t get much for your money these days "in terms of build quality" compared with years ago.
PS
All I want is a decent case, it has to be all metal construction, I don’t even care if it’s not painted, I don’t want fancy graphics, loads of lights, that aren’t necessary, OK, a bit of wood is nice, but no, not necessary, fancy knobs and designer switches, no no no, all this costs money don’t forget, and you are paying for it, it’s not doing you any favours, it’s all for the manufacturer, to lure you into the sweet shop.
And please, the best possible keyboard, sometimes I think they forget they are actually making what is primarily a "keyboard" instrument.
I’m all for the military aesthetic, nothing is there apart from what is needed to do the job, in the most efficient and cost effective way.
Post by sonics »
I'm not sure what you're after anymore :)
Was it weighted keyboard, full 88 notes, on-board sounds? Or something else?
It strikes me that there is so much choice in the market now that there must be something to suit you. I agree about the keyboard quality going down, however. Most keyboards used to be sold to keyboard players. Now they are sold to everyone who makes music using a keyboard, which is quite another thing.
sonics
sonics wrote: Sat Mar 18, 2023 5:09 pm I'm not sure what you're after anymore :)
Well.... original spec was...
My thought is to replace the Berry with a compact synth keyboard, that can also act as a controller for the computer, it needs to transmit knob data, I don’t have a dedicated full size hardware keyboard that has sounds on board, and I really miss it, I like to work that way if possible.
So I’m trying to combine a hardware synth, 5 octaves, but hopefully fairly compact, with a controller source, I’ve thought of a couple of things, I need basics like Rhodes, samples etc, and some sort of synthesis ability.
I don’t want to spend too much
Years ago I used my DX7 as a master keyboard, as did a lot of people, because of its excellent feeling keyboard, it was also my main sound source, and I had a little Korg Nano Control for Midi stuff, all perfect.
I’m looking for a similar set-up, but with a controller included on the keyboard, but, thinking about it, that’s not essential, I could use a separate box.
Post by MarkOne »
In that case…
Here’s the very thing for you :thumbup:
(FWIW, I agree about the DX7 keybed, it was ‘just right’ That and the D50 put pretty much everything on the market today to shame)
MarkOne
My Music on Apple Music
My Music on Spotify
MarkOne wrote: Sun Mar 19, 2023 11:05 am In that case…
He’s fibbing, or it’s a genuine mistake who knows, but it’s not a DX7, it’s a DX21, completely different thing.
I don’t want another DX7, I tried that, they are getting old now, parts etc, I had terrible trouble with my last one.
There’s always a catch, I’d like that Roland Jupiter X, but it’s way too big, and too complicated, the MO-DX is sort of close, but the build puts me off, I’ll get something, just have to take my time.
Post by sonics »
Arturia KeyLab 61 MkII would probably fit the bill.
sonics
I'm going to say 'Kurzweil' then walk away from this thread... :beamup:
Wonks wrote: Wed Mar 15, 2023 8:17 am90s ROMpler demo track stuff. Hopefully it sounds better in reality.
Not to divert or derail but I have a lot of time for 90s romplers as instruments. The demos were often undeniably cheesy though :-)
There were exceptions. I consider a Korg Trinity demo by Stephen Kay (in 1995) called The Sorcerer to be one of the best factory demos of all time.
Posts: 9985 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
The Elf wrote: Sun Mar 19, 2023 8:06 pm I'm going to say 'Kurzweil' then walk away from this thread... :beamup:
I'd be completely on board with you when it comes to the capability but when it comes to the usability I think they need to work on that aspect.
I love the sounds in my K2700 but I'd struggle to recommend it to anyone wanting a workstation because the user interface is terrible... to the point I've written its sequencer off altogether. I speak as a fan of workstation sequencers :lol:
Well, I’m looking at the PC3-K6 right now, it’s on my short list.
Your short list seems to be getting longer by the day... :lol,:
Hugh Robjohns wrote: Mon Mar 20, 2023 9:22 am Your short list seems to be getting longer by the day... :lol,:
It’s a toilet roll.
