Can I use any USB-C cable for monitor?
Post by jellyjim »
Hi
I bought a new monitor for my 2020 Intel MBP. An LG 27UP850N-W. It's very nice.
It will live 4m away from my MBP, so I grabbed the longest 'display' cable I had. A USB-C to HDMI, as my MBP only has USB-C ports (nice one Jonny Ive, oh and thanks for the crappy Touchbar that's stuck flashing on and off in disco mode :roll: )
The cable worked but in display settings macOS Ventura complained about 'unknown display' so I was unable to change the monitor form 1080 to 4K. That's weird, I thought, it shouldn't need 'drivers'. So I checked the 'manual' and in big letters it says 'malfunction may occur if the supplied cables aren't used'.
Doubtful, I tried with the supplied USB-C to USB-C cable and bingo, my Mac recognised the monitor and it bloomed into it's full 4K glory. I stand corrected. I though any old combination of cables and adaptors that got me from A to B would work.
However, the supplied cable is a mere 1.5m and I need 4m. My question is, will any USB-C to USB-C cable work or do I need something specific to displays or 4K or whatever? Searching Amazon is minefield of confusing and conflicting specs!
Jim
jellyjim
Posts: 1696 Joined: Wed May 15, 2002 12:00 am Location: uk
Re: Can I use any USB-C cable for monitor?
I've fallen foul of differences in USB-C cables. There's some sort of difference between an OTG and 'normal' cable, for instance, that prevents my 3D headset working with anything but an OTG cable.
Sorry I can't be of any real help, but I just thought I'd let you know that it's a question worth asking.
For the record, this sort of nonsense really p&£^&es me off. As if it wasn't already complicated enough trying to find the right combination of USB connector without the cables now also being a variable. And people try to tell me it's a good thing that the EU has 'standardised' on USB-C. I'm willing to make a sizable bet how well it's going to work out for us all... :madas:
Posts: 20927 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by jellyjim »
The Elf wrote: Sat Mar 25, 2023 2:42 pm I've fallen foul of differences in USB-C cables. There's some sort of difference between an OTG and 'normal' cable, for instance, that prevents my 3D headset working with anything but an OTG cable.
Yup following further research it would seem the answer is 'no'! Down the rabbit hole I go :headbang:
jellyjim
Post by resistorman »
USB C cables are rated by power delivery and data rate, so you'll need to read their specs. 4 meters is pretty long.
resistorman
Posts: 2869 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Post by jellyjim »
resistorman wrote: Sat Mar 25, 2023 3:02 pm USB C cables are rated by power delivery and data rate, so you'll need to read their specs. 4 meters is pretty long.
Thanks, that makes sense now. Yeah the monitor's driven by a laptop that never really moves. The monitor is at a second workstation 4m away. I've found a suitable cable on Amazon (4.5m) but they only come in 2 packs!!! :headbang:
jellyjim
Post by DGL. »
Not long enough in your application but I find the IKEA ones to be the best value.
DGL.
Posts: 2157 Joined: Fri Oct 28, 2011 12:00 am Location: Portland, Dorset
