Voice distortion software
Post by Baldo »
I'm doing an interview with someone who needs to disguise their voice for legal reasons.
Any software apps that I can use for this purpose?
Many thanks
Baldo
Posts: 289 Joined: Thu Dec 12, 2002 12:00 am Location: Germany
"Never put a recording studio in your home, it is a black hole into which you can pour unlimited amounts of money" Pete Waterman.
Re: Voice distortion software
I'd have thought any pitch changing software with formant changing should do the job. Most DAWs have one as standard or something like Soundtoy's Little Alter Boy.
Adjust the pitch and formant setting and it will sound very different.
Posts: 19083 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Post by Baldo »
thanks for that. I assume that there is no way to reverse engineer the distorted voice. To prevent this I suppose we need some kind of random noise added so that it would be impossible to reverse engineer.
Am I right?
Baldo
Possibly.
Then there's the option of copying the vocal to say three tracks, doing a different amount of pitch and formant change to each one and recombining them. So it then wouldn't be easy to reverse engineer as any other pitch or formant change correctly applied for one voice part would still leave 2/3 of the voice very different sounding.
You could give it a go on your own voice and see what you think.
I'd be more concerned that anyone who knew the speaker would recognise any vocal mannerisms they had, any turns of speech they often used etc. Umms and ahhs.
I'd suggest the interview be scripted so you could change anything that might give them away or mentioning something unplanned.
It might be easier just to have the interview transcription voiced by an actor or text to speech synthesizer.
Posts: 4790 Joined: Sun Aug 12, 2018 2:40 pm Location: British Isles
That would probably be safest.
Here's a simplistic article but it does bring up a few other points of how voices can be recognised. https://kids.frontiersin.org/articles/1 ... 022.702664
There are AI programs that will analyse the way the words are spoken. If there is a small pool of possible people who could have made the interview and there are recordings of the possible interviewees voices that could be used as reference data, then you might easily pick the correct one by elimination of the others.
If it's a simple disagreement like a staff member at a school disagreeing with the headmaster's policies, then mangling the voice is probably fine. But a witness in a major crime case where there's a lot at stake, then I wouldn't use their voice at all.
And unless it's pertinent to the interview subject, then you could leave out all gender references. If there are 20 possible people who could have made the interview and only two of them are female and you tell them you are interviewing Mrs X, then it probably won't take much for whoever the interview affects to work out which of the two women it is.
Post by tea for two »
Preehaps a Toy Megaphone voice changer approx €10.
https://m.youtube.com/watch?v=tQIiyIx-isc
at 27seconds.
I thunk this would be harder to reverse engineer than software.
Baldo wrote: Sun Mar 26, 2023 1:36 pm no way to reverse engineer the distorted voice. To prevent this
Preehaps also feel comfortable for the person knowing hearing they are disguising distorting their voice using something they can hold as this Toy Megaphone, instead of software.
Baldo wrote: Sun Mar 26, 2023 1:05 pm I'm doing an interview with someone who needs to disguise their voice for legal reasons.
tea for two
The interview needs to be intelligible!
Wonks wrote: Sun Mar 26, 2023 3:35 pm The interview needs to be intelligible!
Hmmm. Is that a new, novel idea?
Posts: 20702 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Call me radical, but I think it's worth a go!
Lol ! There is that.
tea for two
Post by Kwackman »
N i g e l wrote: Sun Mar 26, 2023 2:14 pm It might be easier just to have the interview transcription voiced by an actor
This is the safest method, and used by broadcasters.
Voice distortion by whatever method usually sounds strange and distracting to listeners, and pitch shift won't disguise voice characteristics.
Someone else's voice avoids you being sued!
If it's for a video usually it's considered good practice to caption with "Actor's voice". If it's for audio only, there's normally a "his/her words are spoken by an actor" type of sentence before the interview is played.
Kwackman
Posts: 3649 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
