Wonks wrote: ↑Sun Mar 26, 2023 1:56 pm
There are also two lots of mics used in shot, one pair silver, one pair black. So there is also the possibility that neither were used for the actual recording!
Forget all that. I was viewing on too small a screen and the mic clips were confusing me.
There is actually a second pair of mics visible in some shots, flown from directly above the lip of the stage.
The main mics look somewhat like Gefell M270 or M296, but we don't get a close-up that is clear enough to tell for sure.
Sam Inglis wrote: ↑Sun Mar 26, 2023 3:56 pm
There also seems to be another flown mic on a boom arm, even further back, visible on the upper right at 24s in or so. Though it's not that clear, so could be something to do with the wiring for the other flown mics.
There is always the possibility that the flown mics are part of the hall's permanent sound installation (you can see a flown speaker), and so may or may not be utilised for the recording.
I think a small room without proper treatment will be inherently boomy and muddy. Just a duvet behind the player will not be enough. Floor, walls, corners and ceiling will all need treatment to reduce the small room bass build up. The recordings of the lady are all done in bigger more open spaces. I bet also there is some EQ and verb added to the recordings
It sound's like it's pushing the levels to the limits and distorting in the loud bits. Whether that's the original recording or a decision made in mastering (or in the film transfer to digital format) I don't know.
Slight synch delay between the visuals and sound, much greater than the mic distance from the guitar.
Wonks wrote: ↑Sun Mar 26, 2023 5:50 pm
Given that it's turned down 7.6dB for Youtube it seems like someone has generally gone in overloud.
It does sound like there's quite a bit of compression on some of these YouTube classical guitar videos. On the Bach one posted earlier, the player's breathing and clothes rubbing against the instrument are quite annoying on headphones.
There is a story, probably apocryphal, that Crowded House used to rehearse in the nude until Neil Finn caught some of his, ahem, senstive hairs, in his guitar strings somehow.
After that underpants were considered a minimum standard.
Apparently.
