Audient ID 4 No volume problem (fixed)
Post by shane536 »
Hi, I just joined this forum to post a fix to a problem in the hopes that it will save someone else from going completely insane. :headbang:
I have an Audient iD4 as my DAW interface (Windows 10) and have been having problems with the signal path entering the Audient, either as an input or output signal, and dying inside there. A signal will leave my Kemper, go into the Audient and the LED indicators will show a signal being received, yet nothing arrives at my PC. Or I'll attempt playback from my PC, my DAW indicators will show gain, the Audient interface will show gain, yet I hear nothing in my Headphones etc.
Basically, despite everything visually working as it's meant to, there is no sound.
I am not sure what causes this problem, but the solution is that you have to go into the Audient interface on your PC, and jiggle all the sliders slightly. No, not the physical knobs on the box, they do nothing, you have to move them on the PC. Like, literally just wiggle the sliders on the screen up and down. Then it will suddenly work.
I know, I don't get it either, but it's as if they get "stuck" somehow and by moving them, suddenly the gain gets reset to the correct level.
Then it will work correctly for the rest of your session. Until next time you power up your computer and have to do it again. In fact it's the first thing I do when I turn on my computer, go into the ID4 interface, and jiggle all six sliders, Mic 1 and 2, DAW 1-4, otherwise, no sound.
Hopefully this saves someone some stress, it took me forever to find a fix. :madas: I have literally tried reinstalling DAWs, swapping out guitar cables, updating audio drivers etc etc while screaming and pulling out my hair.
Apart from this glitch, it works fine, and I have no idea what causes it.
shane536
Posts: 1 Joined: Mon Mar 27, 2023 4:12 am
Re: Audient ID 4 No volume problem (fixed)
Post by Mike Shand »
Interesting. My ID4 suffers from a similar problem that when the computer comes out of sleep mode it sometimes doesn't work as you describe. The fix I have used is to momentarily disconnect the USB cable. This "resets" it, but it is then necessary to turn up the volume knob on the ID4 since this defaults to zero.
This only happens perhaps one in 5 or 10 wakes from sleep. Rebooting the computer will also fix it.
I haven't tried your solution, but I will experiment with it.
This has been going on since I bought the ID4 several years ago, and I have tried updating the firmware, drivers, and going from win10 to win11. Nothing has helped.
Mike Shand
Posts: 59 Joined: Tue Jun 20, 2006 12:00 am Location: Cobham, Surrey, UK
It would be worthwhile passing this feedback — OS, situations, symptoms, solutions — to Audient. It sounds like a driver issue with something not being set correctly after coming out of sleep mode.
Posts: 41729 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
I did discuss this with audient a few years ago and they suggested a few things,including fiddling with the USB power modes, but nothing helped. I have since got a new computer and that still has the issue. Since it only happens now and then, and the fix is easy, I just live with it.
Mike Shand
