Time to get up to date...
Got a Novation Mininova synth. Have rigged it up via midi to my full size piano so now I have full octave range. Also connected my laptop to the synths usb to laptop usb..
I do know that this synth wont transfer music directly over usb. Only Midi files, patches etc within the software library can be sent. I intend to get a DAW program so I can start recording...but havent a clue about hooking it up to laptop.
I currently have a small audio interface box with 1.4 " inputs and 1.4" jack outputs rigged to a studio monitor speaker.
The synth uses 2 inputs to the box. Other two spare for my guitar etc..
However, the interface box does not have a usb port...
It does have a 1.4" headphone socket plus two 1.4" mic inputs.
Do I need to buy a better interface box, with usb? I've seen those usb plug in ones with built in sound cards..would this work?
The laptop only has one small 3.5mm audio input hole. The rest are usb...this must be a 3.5mm headphone socket i presume..
What's best way to connect the audio interface to the laptop to then send what I'm playing to the laptop to record it?
Help greatly appreciated
