ef37a wrote: ↑Fri May 26, 2023 10:33 pmNot sure what that means Hugh?
Just that BJT amps couldn't deliver the 500W and 1000W power levels PAs wanted cost effectively that MOSFETS could do in the 70s and early 80s. BJTs have improved since then...
Fine though Brystons are they are expensive and I understand the output stage needs selected transistors?
Expensive, yes, but built like outhouses, rated very conservatively, and warrantied for 20 years.
Who cares if they use selected transistors — I've no idea if they do or not because none of mine have ever failed.
My first 4B NRB amp was traded in at 22 years of age for a 4B SST2 about 5 years ago, and AFAIK that amp is still in daily use at PMCs service department, never having had its lid taken off!
The good Mr Self is a perplexing mix of common sense, production pragmatism, and bonkers perfectionism-just-because-he-can. I cite his 24 op-amp balanced stereo line input stage.
