Audio Precision test rig?
I reckon it's ok for subjects to wander once the initial query has been answered, and I think Crunchnut had got what they were after.
Drew Stephenson wrote: ↑Thu May 25, 2023 9:14 pm
ef37a wrote: ↑Thu May 25, 2023 7:55 pm
There are two types of class B (Selfs) output stages. The emitter follower and the Complimentary Feedback Pair (CFP) The former needs a bias current of around 100 to 150mA which means a 50W per ch amp would still dissipate some 10W per channel. The CFP requires a tenth that current and so are much more efficient.
Wonks wrote: ↑Thu May 25, 2023 7:57 pm
However, just about all active monitors use class D amps these days.
Most but not all Wonks and AFAIK no one has every stuck one on an AP rig?
Nazard wrote: ↑Fri May 26, 2023 2:10 pmWonks wrote: ↑Thu May 25, 2023 7:57 pm
All ATC active monitors, HiFi and Pro, have 'grounded source A/B Mosfet amplifiers, including their subwoofers. Which makes sense, considering they have developed a range of excellent Mosfet A/B power amps for domestic and professional use over the years, plus other electronics.
At one time, to proudly splash "New High Power MOSFET OutputStage" had a certain cache' with parts of the audio world.
Fine though Brystons are they are expensive and I understand the output stage needs selected transistors?
Hugh Robjohns wrote: ↑Sat May 27, 2023 10:10 am
Yes, the famous Amcron DC300A.... pushing out 155 of the finest American Watts per channel...on a good day...
merlyn wrote: ↑Sat May 27, 2023 1:38 pm So if gm is constant it doesn't affect linearity. If gm varies with the amplitude of the signal, then that would introduce distortion.
For the record I don't think there is anything wrong with MOSFETs. The kind of linearity Mr. Self is after ... probably not necessary for a bass guitar amp.
