Nearfields Monitors: Kali vs Adam vs Focal
Re: Nearfields Monitors: Kali vs Adam vs Focal
Post by tea for two »
ef37a wrote: Fri Jun 02, 2023 9:42 am Can I inject a question and perhaps a note of caution here Tea for Two?
I am saying Tea, you should not be annoying folk, at least not at civilized times and you 'might' be running cans at damaging levels?
Appreciated E.
I started mixing just after 7am lol.
It's cause I'm currently working on an EDM album with some heavy beatz low Bass. It's the only EDM album I've made.
Most of my other stuff I can mix at low volume which I tend to do.
My ears are slightly damaged over years of abuse, more so my left ear. Even though I can hear 20Hz I have to increase to +3dB on a Sine Wave Test Tone in Logic Oscillator to properly hear 20Hz.
tea for two
tea for two wrote: Fri Jun 02, 2023 10:44 am
Appreciated E.
WHY on earth are you struggling to hear 20Hz Tea?!! There is nothing remotely musical going on down there and only the very biggest speakers in a huge room could reproduce it.
T42 is currently immersed in an EDM-fest which involves a deep rumbly bass. It's intended for playback on big club and festival PAs which can generate 20Hz.
Although while we can, technically, hear 20Hz, in practice we feel it which obviously isn't something that can be done over headphones.
Posts: 43708 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
I have lost meself to EDM for my sins :lol::beamup:
tea for two
Post by muzines »
Anyone mixing bangin' beats at 7am* gets my sympathy**..! :lol:
* (after getting up, not staying out all night)
** As do their neighbours...
muzines
Post by ore_terra »
After reading this post and others I was nearly decided to get a pair of the new kh120, but this add came up with a “VAT-less day” in a local store… and I just pulled the trigger for a pair of A7V’s for 1050€ 🤷‍♂️
ore_terra
Posts: 1090 Joined: Fri Dec 02, 2016 12:56 pm Location: Seville - Spain
casmoestudio.com
muzines wrote: Sat Jun 03, 2023 12:27 am Anyone mixing bangin' beats at 7am* gets my sympathy**..! :lol:
Sounds dope Bro.
Posts: 21966 Joined: Sat Jul 12, 2003 12:00 am
What could possibly be handy is if there was a software where we could draw our room including windows doors ceiling floor, with measurements angles, alongside what the room is constructed of.
Have it with and without Virtual acoustic treatment.
Thereafter have various Virtual Monitors virtually placed in different parts of our virtual room to hear them.
Similar in principle in a way to drum software where we can change the drums size, skin, mic positioning, types or mics.
Similar in principle in a way to amp cab modelling simulating software.
Similar in principle in a way to software that attempts to emulate simulate sound of different studios.
tea for two
tea for two wrote: Sun Jun 04, 2023 10:04 am What could possibly be handy is if there was a software where we could draw our room including windows doors ceiling floor, with measurements angles, alongside what the room is constructed of.
A friend went round a few top London studios and made recordings in the control room of each one using a binaural head with two B&K 4006 mic's in it.
That was an "interesting" "experiment" :) ?
He also recorded my hi-fi in my living room, a pair of Celestion Dutton 15 speakers, surprisingly, my recording sounded better, than some of the studios, maybe better isn’t a good word, but let’s say it held up well.
Not sure about virtual room software? could be a whole can of worms there.
Post by ore_terra »
Well, in theory you can. In the end it’s “just” wave physics.
The only tiny little problem is the huge amount of variables you have. Materials, thicknesses, surface finishes, geometry, openings… 😂
But the same way structural design softwares exist (thinking of similar multi-variable scenarios based in physics and statistical calculations), I dont see why this software could not exist.
ore_terra
casmoestudio.com
Post by ConcertinaChap »
ore_terra wrote: Sat Jun 03, 2023 11:00 pm After reading this post and others I was nearly decided to get a pair of the new kh120, but this add came up with a “VAT-less day” in a local store… and I just pulled the trigger for a pair of A7V’s for 1050€ 🤷‍♂️
Hope you enjoy them as much as I'm enjoying my new KH120 II's.
ConcertinaChap
Posts: 15249 Joined: Wed Jul 20, 2005 12:00 am Location: Bradford on Avon
Making music: Eagle Alley
Post by RichardT »
ConcertinaChap wrote: Sun Jun 04, 2023 11:02 am
How much better are they than the original KH120s, CC?
RichardT
Posts: 6034 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Post by ore_terra »
I kind of suspect I’d have enjoyed the KH120II’s a bit more… so please be quiet 😂😂😂
ore_terra
casmoestudio.com
ore_terra wrote: Sun Jun 04, 2023 10:41 am
Sounds like a job for some kind of AI...
No, seriously, it's this kind of stuff that AI could be really good at. Not just for studios and music rooms, but for modelling the effects of sounds in public spaces, transmission through structures, performance of absorbers and reflectors etc. etc. etc.
Posts: 29727 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by ore_terra »
That would be an interesting exercise, yes.
ore_terra
casmoestudio.com
Saw this just today. Ultra Near Field Kali Audio IN‑UNF.
https://www.soundonsound.com/reviews/kali-audio-in-unf
Paul's review.
"Developed specifically for desktop monitoring, the design takes into account desktop reflections and also incorporates adjustable EQ to compensate for the boundary effect of working close to walls."
"Note that the bass unit needs to be located on a desktop"
"Not having to worry about the placement of a floor‑standing sub takes a lot of guesswork out of setting up reliable monitoring."
"The way the satellites rest in their cradles makes it easy to aim the tweeters towards your ears, and there are detailed instructions on the Kali website if you need to adjust the DIP switches to account for room placement"
"four‑inch midrange driver and one‑inch soft‑dome tweeter as Kali’s respected IN‑5 and IN‑8 monitors."
https://www.kaliaudio.com/in-unf
Seems right up my street from the various nearfield monitors reviewed by SoS.
https://www.soundonsound.com/search/all ... ld+monitor
Righty O time to start saving me pennies at 100pennies a day lol : 2025 JanFeb.
Any monitor named after a Hindu Goddess gets my devotion. :beamup:
Just a little segway.
Stumbled upon this utube interview uploaded 3days earlier.
Gentleman wrongly imprisoned 3Decades 30years whilst in his 20s.
His outlook is bloomin marvelous.
https://m.youtube.com/watch?v=1p8j_vGSAdw
tea for two
Assuming the car gets through its July MOT with minimal cost and 'things' either stay much the same or possibly improve, I can start considering some new monitors again in 2024(ish)
I might be wrong because speaker technology has advanced since my 5As were designed (C 2000?) but I do not want to go smaller than a 5" woofer. The Tannoys give remarkably good bass for their size and I would want even better and louder! (but in the way of headroom and not headbanging rock levels).
I keep flipping and flopping from the Result 6 and the wonderful things I hear about the KH120/150s but then someone pops up with a 'software' problem and I am back to the Sixes with their totally analogue technology.
If I had a pair of 'digi-techy' speakers and they went wrong I would lose my **** like the farmer in Shaun the Sheep!
RichardT wrote: Sun Jun 04, 2023 11:42 am How much better are they than the original KH120s, CC?
Not a great deal in it so far, but then I haven't pushed them or performed the MA1 magic spell yet. I've got the mic but due to other priorities intervening I won't be able to use it for a week or two. Will report back when I've done that.
ConcertinaChap
ef37a wrote: Mon Jun 05, 2023 10:53 am Assuming the car gets through its July MOT with minimal cost and 'things' either stay much the same or possibly improve, I can start considering some new monitors again in 2024(ish)
Dave, we are both of "a certain age" and I think our hearing is too!
Sounds like you love your Tannoys, the way you talk about them, I’d hold on to them in that case.
Also, I don’t think speaker technology hasn’t moved on to an extent where it’s made a huge difference in terms of what we’re hearing today, and, it’s all too easy to jump out of the frying pan into the fire with monitors, stick with what you know if it does the job.
Arpangel wrote: Tue Jun 06, 2023 7:27 am
I doubt you could "do your job" Tony if you had my hearing! I have virtually nothing past 2kHz, e.g. "Lark Asending" on the violin is mostly lost to me. The last octave of piano is just a series of 'clunks'. And, WTF is a "hihat"?
Yes, I quite like my 5As and think they give a very 'honest' reproduction but they ARE getting on and I have had to repair a couple of faults with them already. I don't mix on them (never did, son was the musician and track builder) and now have them in my living room as my 'hi fi' speakers* but I am some 2mtrs from them and although quite loud enough for string quartets and such I would like now and again to let rip with a Beethoven symphony or indeed a bit of Quo!
But, thank you for your thoughts mate!
*I have a rather contentious issue to raise about this but will start another thread which will produce a BIG sigh from Hugh!
Arpangel wrote: Sun Jun 04, 2023 10:32 am A friend went round a few top London studios and made recordings in the control room of each one using a binaural head with two B&K 4006 mic's in it.
Placed a bid on Celestion Ditton 15XR located in edgeware starting at £40. Willing to go to £70.
Although the last speakers you recommended I returned to shop the same day I got them.
These Celestion Ditton will hold up just fine I'm fairly sure as a replacement for my current hifi speakers.
I think I can crank out fairly loud volume upto max 7 minutes weekends midday without disturbing too much neighbouring flats.
tea for two
tea for two wrote: Tue Jun 06, 2023 8:25 am
The original Ditton 15 was an excellent speaker, the XR is a different thing.
The XR has got a different tweeter, crossover, it’s a bit brighter, not as good IMO. But, still worth I’d say up to around £100/150 a pair, if you get them for £70 you’ve done OK. They don’t take power though, be careful how you drive them.
The original 15 is a lovely speaker, such a sweet sound, you’d pay upwards of £200 a pair for those from a dealer.
Arpangel wrote: Tue Jun 06, 2023 8:46 am
Supposedly XR has more Bass extension than original 15.
Not a fan of over brightness hence my DT880 headphones which hurt my ears on Violins, Hihats went to another home.
tea for two
tea for two wrote: Tue Jun 06, 2023 8:55 am
Yes, the passive radiator on the XR is different, but the cabinet sizes are the same, but I’d doubt if there’s that much more bass on the XR.
Even though they don’t take much power, they do benefit from a nice big amp, that keeps them under control, you don’t want an amp with waffly bass.
I used to use a 100w per channel Onkyo amp with mine, sounded great.
ef37a wrote: Tue Jun 06, 2023 8:49 am Apologies for inserting in wrong place but it has just come to me that I have a pair of Mission 775s that I would like to sell. No idea of asking price and buyer collects.
That's what the free ads are for Dave. ;)
