My Eye Your Eye - Feedback welcome please
Post by amanise »
https://soundcloud.com/adrian-manise/my ... al_sharing
At least I'm doing this bit in the right area this time. I tried Drews last advisory gem and set the tracks up on this early using pink noise level balancing. I hope I muted the pink noise track before offering it to you for comment!! It's an amazing technique! Everyone - go get a pink noise generator now! I'm converted!
This may well be my first ever track without a face melting guitar solo. Hmm. Feels a bit like you're all getting off too lightly!
Thanks in advance
Adrian
amanise
Posts: 4252 Joined: Thu Jan 26, 2023 1:45 pm
Adrian Manise
A name to strike fear into the hearts of A&R people everywhere...
:headbang:
Re: My Eye Your Eye - Feedback welcome please
Firstly I must just leap in to give credit where it's due and say that the pink noise mixing tip comes originally from Zukan (I think), I just passed it on. :)
I've just had a quick listen to this on the laptop but my initial thoughts are that the instrument separation seems better than a couple of the previous tracks you've shared, and I think the top end is better controlled as well. :thumbup:
I think the drums need to come up though and the bass down quite a bit. There could be a bit more rhythmic drive from the snare and the bass is overwhelming the kick to my ears.
I'm sure better ears than mine will be along in due course to correct me though.
Posts: 27687 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by RichardT »
Wow - that's totally unique! Some very interesting music. Very good...
My first thoughts are that the second time through the verse/ chorus, something different needs to happen.
Also when you get to the middle section, it would be very interesting if the whole track emerged from the 'listening through a tunnel filled with jelly' effect into something clearer (especially with more open high frequencies), and then went back in again for the last section.
RichardT
Posts: 4897 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Post by amanise »
Smashing - thanks for your time and ears Drew! I wondered if the drums were a bit low, but my ears needed a rest from it , and your comments are good confirmation. Thanks very much, I appreciate it.
Adrian.
amanise
Adrian Manise
:headbang:
Post by amanise »
RichardT wrote: Tue Jun 06, 2023 6:21 pm Wow - that's totally unique! Some very interesting music. Very good...
Tee Hee! Unique... I like that - I have no idea where it comes from. I find it impossible to fit it into any of the normal genres. Makes submission hard. It is what it is. Perhaps the second verse should have some slide guitar swooping in and out or something hmmm.
I think the jelly filled tunnel might be the flanger on the drums - or the phaser on the bass guitar - or both? Interesting idea going clean for that section. Doable with a few more tracks and busses I suspect. Hmm.
I don't know how they do that EDM thing with the whooshing sweeping EQ business that sounds like your emerging from a bucket of water. Did you mean that?
Thanks very much Richard!
amanise
Adrian Manise
:headbang:
Post by RichardT »
Yes, the tunnel effect is the result of the effects you're using.
I wasn't thinking of that EDM effect, but it might work. I don't know how to do it either but I suspect there are synth patches or sample libraries that can achieve it.
RichardT
Post by OneWorld »
Funnily enough, I have spent the morning re-visting a time (by way of YouTube) where I was smitten from day one, when I came across ISB - the Incredible String Band, and since then I don't think I have come across anything quite so unpretentious and quirky, until I listened to your piece 'My Eye, Your Eye' 3 cheers and hip hip hooray, to you, for a refreshing reminder that eccentricity is alive and well - tis a musical delight
OneWorld
Posts: 5178 Joined: Tue Apr 07, 2009 12:00 am
Post by jaminem »
Really not my thing so can't comment on the actual musical content but to me its very muffled. I'd want a lot more high mids in that mix, and a lot more top end.
The squelchy bass line is sometimes too loud usually when you're singing and then sorta disappears in the chorus.
As Drew says the drums need to come up, with a heavily syncopated drum beat like this you can lose the groove when they're this low.
The thing that stands out most for me though as the almost Total lack of transients, especially on the drums, that may go a long way to understanding why they don't cut through. Not sure the flanger is helping you here, is it across the whole drum bus? if so maybe just on the snare and fade in when there's not much else going on? That way you get the effect when there's space in the mix but a better groove otherwise
like the vocal effect tho
jaminem
Posts: 1476 Joined: Mon Mar 19, 2001 12:00 am
Post by amanise »
RichardT wrote: Wed Jun 07, 2023 9:48 am Yes, the tunnel effect is the result of the effects you're using.
I wonder if its the 'humanised' (love that effect!) guitar chopping away in there that's making your ears want to listen to something less mangled for a bit in the middle? The other stuff in that section is fairly straightforward in terms of modulation effects. Do you think your ears would get what they were looking for if I replaced the rhythm guitar as is with a clean acoustic guitar chopping away instead - just for that middle section? Then went back to the 'humanise' guitar for the last verse?
amanise
Adrian Manise
:headbang:
Post by amanise »
OneWorld wrote: Wed Jun 07, 2023 10:58 am Funnily enough, I have spent the morning re-visting a time (by way of YouTube) where I was smitten from day one, when I came across ISB - the Incredible String Band, and since then I don't think I have come across anything quite so unpretentious and quirky, until I listened to your piece 'My Eye, Your Eye' 3 cheers and hip hip hooray, to you, for a refreshing reminder that eccentricity is alive and well - tis a musical delight
Wow! I think that's one of the nicest compliments I've ever had!
Don't know what to say - except thanks very much! I'm going to print this one out and hang it on the wall next to my orchestral instrument frequency chart!
Adrian
amanise
Adrian Manise
:headbang:
Post by amanise »
jaminem wrote: Wed Jun 07, 2023 11:22 am Really not my thing so can't comment on the actual musical content but to me its very muffled. I'd want a lot more high mids in that mix, and a lot more top end.
OK - thanks for taking the time to hear it through - and great feedback! You chime with Drew - that there's too much bottom end and not enough of the drum track (which does have the flanger on the whole bus, but not below about 450Hz). Starting point for me, then, is to push the drum track closer to the limiter and see if the rhythm comes through more clearly from there. And lower the phased bass guitar in the right side. The wah'd synth bass in the left side (representing the keyboard players left hand) may come down if it then overpowers everything else. I'm very pleased you like the vocal effect - it helps me with my self perception of the sound of my own voice :-) - a bit of a protective force field. Is it wrong that it involves a bit of TC Helicon kit? :lol:
amanise
Adrian Manise
:headbang:
Post by jaminem »
I wouldn't push the drums into the limiter, I'd add some transients, compress them and raise the level a db or 2
Don't think you need to remove bass, just tighten it up a bit. but add high mids and highs. Air band is your friend here it will bring out the hats
jaminem
Post by jaminem »
Oh and remember, everyone hates their own voice, we won't perceive it anywhere near as bad as you do!
jaminem
Post by amanise »
jaminem wrote: Wed Jun 07, 2023 12:29 pm Oh and remember, everyone hates their own voice, we won't perceive it anywhere near as bad as you do!
Thanks again. Chiming with Drew once more. From inside my head - that's easier said than done :) Melodyne usually has surprisingly little work to do though, thankfully. So there's some support there for your kind thoughts.
Smashing! Now I just need to look up 'add transients'. :-)
I thought we were always trying to obliterate those with compressors. :bouncy:
amanise
Adrian Manise
:headbang:
Post by jaminem »
what DAW you got mate? there's probably a transient shaper in there. Cubase has one as std. Use with care tho, you can overdo it.
There are plenty of free transient shaper plugins around
jaminem
Post by amanise »
jaminem wrote: Wed Jun 07, 2023 2:09 pm what DAW you got mate? there's probably a transient shaper in there. Cubase has one as std. Use with care tho, you can overdo it.
ACID Pro 10. I'll see what its got - ACID Music was the only DAW I could understand when I started all this back in about 2001. Tried CuBase - but what can I say? I'm a guitarist :-)
Cheers for your help! I've done a V2 and I think I've been able to catch most of the things people pointed out. Need to have a think now because I might lose the phaser on the bass guitar track. It might be a wobbler too far now I've had another listen on cheapish room monitors. :bouncy:
amanise
Adrian Manise
:headbang:
Post by Chet Leeway »
Sounds a bit like a male Cate le Bon with too many (is there such a thing?) effect pedals.
Chet Leeway
Posts: 152 Joined: Fri May 06, 2016 8:13 pm Location: Barcelona
Was going to give it a proper listen but I'll wait for v2 if you wanted to share that.
Post by amanise »
Chet Leeway wrote: Wed Jun 07, 2023 3:20 pm Sounds a bit like a male Cate le Bon with too many (is there such a thing?) effect pedals.
No such thing as too many pedals if you're a guitarist :-)
Had to look her up too :-)
https://www.newyorker.com/culture/perso ... urney-home
"The music of Cate Le Bon, the singer, songwriter, and multi-instrumentalist, has a rigorous, art-school weirdness that can be both entrancing and estranging. "
Happy to be compared with that - thanks!
amanise
Adrian Manise
:headbang:
Post by amanise »
Drew Stephenson wrote: Wed Jun 07, 2023 3:55 pm Was going to give it a proper listen but I'll wait for v2 if you wanted to share that.
Hi Drew - yes, I've tipped the upper mids curve up a bit and added in a few more strategically placed snare hits in the verses starting at verse 2 to hit both your point and Richards(?) one about something new should happen at verse 2. Extra drums! Toying with the idea of removing the phaser effect from the bass guitar on the right side (not the boingy wah synth bass on the left side). It might lessen the 'tube' effect. I like it - but it might be a pedal too far in respect of some of the other feedback. Might have found out why people don't phase bass much. I wonder if you might find it a bit toppy now though - we'll see tomorrow! :bouncy:
amanise
Adrian Manise
:headbang:
I may be wrong but to me this has a feeling of "I've got a hundred plug-ins and I'm going to use them". The only problem is that to me it feels over congested and muffled. I'm yearning for a bit of clarity to at least some of the sounds.
Posts: 15664 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by amanise »
James Perrett wrote: Wed Jun 07, 2023 6:20 pm I may be wrong but to me this has a feeling of "I've got a hundred plug-ins and I'm going to use them". The only problem is that to me it feels over congested and muffled. I'm yearning for a bit of clarity to at least some of the sounds.
Hi James - thanks very much for listening! That seals the fate for the phaser on the bass guitar. Seemed to work on headphones - but not on room monitors. I now have my work cut out for the evening :-)
amanise
Adrian Manise
:headbang:
Post by RichardT »
amanise wrote: Wed Jun 07, 2023 7:04 pm
I think it’s fine if you want that sound as a deliberate effect - but we do need a bit of relief (clarity, as James said) somewhere in the song.
If you want the track to sound clearer everywhere, then essentially you need to take off nearly all the effects.
RichardT
Post by amanise »
RichardT wrote: Wed Jun 07, 2023 7:32 pm
Yes - thanks very much Richard. I've worked my way through the list of things people fed back and I think I've got them all now. I hope I haven't made it all too toppy for Drew :-)
amanise
Adrian Manise
:headbang:
