Talkback units
Talkback units
My home built talkback box has just died, just wondering what some folks use here? I’ve got a talkback section on my mixer, but I’m not using that at the moment.
It would be handy to have a dedicated stand alone unit.
Posts: 21749 Joined: Sat Jul 12, 2003 12:00 am
Re: Talkback units
Post by MarkOne »
They’re mostly built into monitor controllers.
My Presonus Monitor Station has one, and it works well.
Looks like there’s this but it isn’t cheap!
MarkOne
Posts: 3045 Joined: Thu Feb 15, 2007 12:00 am Location: Bristol, England, Earth, Perseus Gap, Milky Way
My Music on Apple Music
My Music on Spotify
Re: Talkback units
Post by Bob Bickerton »
I use the Radial Studio-Q: https://www.radialeng.com/product/studio-q
Solid piece of kit, with a few extra options if you need them like external mic and producer circuit.
Bob Bickerton
Posts: 5610 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Re: Talkback units
Arpangel wrote: Sat Jun 10, 2023 8:24 am My home built talkback box has just died, just wondering what some folks use here?
It depends on how you use/route your talkback facility, but for myself I just allocate one input of my AI as a talkback mic input and route it accordingly. I use desktop PA/'Tannoy' mic's for talkback, with a built-in momentary/latching switch. These can usually be picked up secondhand for peanuts; I paid 4 quid for my last one.
Posts: 21406 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Re: Talkback units
Thanks all, these new units seem very expensive, not a viable proposition for me personally.
I was using my MixWiz 14-4-2 which has a good talkback section, in combination with an amp box that fed a 100 metre speaker drum.
But it’s a pain to set up, I’ve got a gooseneck mic plugged into the mixer TB socket, routed to an aux out, that feeds the amp box.
It’s all a bit messy, it would be good to have a self contained unit, that a speaker can be plugged into, I’m trying to think how this could be wireless, Bluetooth?
Re: Talkback units
Post by Aled Hughes »
I use the talkback (and listenback) facilities in RME Totalmix (with an ARC controller). Works very well.
Previously used the talkback built into the Amek desk we have. It was quite useful having the option to send the talkback to separate destinations, but the RME works better overall I think as it’s easier to route the TB mic into the DAW in case it needs recording etc.
Aled Hughes
Posts: 2126 Joined: Tue Oct 24, 2006 12:00 am Location: Pwllheli, Cymru
Re: Talkback units
Just to clarify what I was talking about above...
Re: Talkback units
https://www.gear4music.com/PA-DJ-and-Li ... ewQAvD_BwE
One of those ^ and bit of switching jiggery-pokerey, job's a good'un?
Posts: 19067 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Re: Talkback units
ef37a wrote: Sat Jun 10, 2023 2:03 pmhttps://www.gear4music.com/PA-DJ-and-Li ... ewQAvD_BwE
Good thinking, I could bypass my amp box, and the speaker reel, and just run one lead from the aux out. Although my speaker reel has a 100 metres of cable on it :-|
Re: Talkback units
Post by resistorman »
Nice looking little speaker... good for the workbench? Hmmm.
resistorman
Posts: 2976 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Re: Talkback units
Arpangel wrote: Sat Jun 10, 2023 10:41 pm
I was thinking more that you could just run a balance mic line from goosey-goosey?
Re: Talkback units
ef37a wrote: Sun Jun 11, 2023 7:35 am
The gooseneck doesn’t have a dedicated output on the MixWiz, you have to route via main out, subs, or aux.
Re: Talkback units
Arpangel wrote: Sun Jun 11, 2023 8:36 am
I see. OK just use a dirt cheap passive DI to send it?
Re: Talkback units
Are you there Dave? I know it’s a Sunday morning, and only us two are here.
:D:D
Re: Talkback units
Arpangel wrote: Sun Jun 11, 2023 9:33 am Are you there Dave? I know it’s a Sunday morning, and only us two are here.
:D:D
I might not be "all there" (some say) but yes, mostly with you. I cocked up that quote, often do in SoS. Did you see about DI?
Re: Talkback units
ef37a wrote: Sun Jun 11, 2023 9:45 am
:D:D
DI?
Hmmmmm?
Re: Talkback units
"DI?
Hmmmmm?"
Have I confused you sir? I mean that you seem to have a line'ish level source and that active speaker has mic XLRs so a floating, balanced signal from a traff could go a very long way. You might even find your unscreened speaker cable is good enough!
Re: Talkback units
ef37a wrote: Sun Jun 11, 2023 1:07 pm "DI?
Hmmmmm?"
I don’t think Arpangel saw your comment Dave, as it’s buried in another quite!
Aled Hughes
Re: Talkback units
I’m thinking that my iPad with the mic activated, via something like Garage Band for instance, could be used with my MiniRig speaker, instant talkback?
Re: Talkback units
All you need is a mic, a preamp, a mute switch, some cable, and an active speaker. Those elements can be found in a multitude of places. Its not rocket science. Its not even complicated audio engineering.
A dedicated TB unit, like those listed above, is convenient, but many consoles have suitable features, or you can use standalone hardware.
Posts: 43616 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Re: Talkback units
Hugh Robjohns wrote: Sun Jun 11, 2023 2:12 pm All you need is a mic, a preamp, a mute switch, some cable, and an active speaker. Those elements can be found in a multitude of places. Its not rocket science. Its not even complicated audio engineering.
I’ve got a box that was made to house a small talkback amp, with various speaker feeds on it, I have an old cable drum with a passive speaker screwed into the middle of it, I just plug that into the amp and unroll it and that’s that. The amp box has a line level input on it to take the output from the desk aux.
The amp has packed up, I could just replace that, but I wondered about an all in one solution.
Re: Talkback units
They exist but they cost money. You can make your own easily by plugging standard products together.
Or you can repair what you have.
All you need is a decision.
Re: Talkback units
Hugh Robjohns wrote: Sun Jun 11, 2023 2:25 pm They exist but they cost money. You can make your own easily by plugging standard products together.
I’ve found a bit of metal rolling about in the amp case, it’s a big "bolt" looking thing with an eyelet on the end covered in solder, but I can’t find any obvious place where it’s come from!
If the guy that made this had put a mic socket on it and a switch, it would be self contained, no need for the mixer and mic, but that’s irrelevant if it isn’t working.
