Phantom power and SM57/58's
Post by amanise »
Quicky about SM57 and SM58 mics when you have phantom power switched on for something like a Rode NT1.
My Mackie 802-VLZ3 phantom switch enables phantom power for mic input 1-3. If I used an NT1 on ch1 and, say, an SM57 on ch2 - would the SM57 be affected by the phantom power it would 'have available to it'?
(I have read the manual - apparently a ribbon mic would be upset!)
Cheers
Adrian
amanise
Posts: 5262 Joined: Thu Jan 26, 2023 1:45 pm
Adrian Manise
Faith in Absurdity :crazy:
A Hazelnut in every bite :wtf:
Re: Phantom power and SM57/58's
No, the SM57/58 wouldn't worry at all about phantom power. Neither would most properly designed ribbon mics. The only mics that you need to worry about are just a few ribbon mics designed with a centre tapped transformer which should mainly be old mics rather than current mics (though I wouldn't put it past some boutique manufacturer to use an old design for "authenticity"). If a modern mic can't take phantom power then it is poorly designed.
Post by amanise »
James Perrett wrote: Sat Jun 10, 2023 3:13 pm No, the SM57/58 wouldn't worry at all about phantom power. Neither would most properly designed ribbon mics. The only mics that you need to worry about are just a few ribbon mics designed with a centre tapped transformer which should mainly be old mics rather than current mics (though I wouldn't put it past some boutique manufacturer to use an old design for "authenticity"). If a modern mic can't take phantom power then it is poorly designed.
Wonderful - thanks very much James!
amanise
Adrian Manise
Post by MarkOne »
I did read that the tie-lines between studio floor and control rooms at the old television centre had 48v permanently enabled on the floor boxes.
MarkOne
My Music on Apple Music
My Music on Spotify
Yes, thats true... it was done that way to allow mic patching on a standard (PO316 B-guage) patchbay without having phantom across the sockets.
It also meant that ALL mic plugging/unplugging on the studio floor was 'hot plugging' with phantom permanently on the lines.
amanise wrote: Sat Jun 10, 2023 3:06 pm Quicky about SM57 and SM58 mics when you have phantom power switched on for something like a Rode NT1.
Not an issue. The two ends of the moving coil element in the SM57/58 are wired to XLR pins 2 and 3.
The body is wired to pin 1 (screen). Phantom puts 48V on both pins 2/3 returning to pin 1.
So as far as the moving coil mic is concerned, its got no voltage difference across the coil (48V at both ends) and no connection between the coil and pin 1, so no phantom current can flow.
Essentially, the SM57/58 has no idea phantom is present at all.
It would be a rubbish ribbon mic if it was... but there are some about (mostly very ancient ribbons) that genuinely don't like phantom. Not something I've ever worried about, thought and I happily use Coles and AEA ribbons with phantom on the lines.
Post by amanise »
amanise
Adrian Manise
Small point, do make sure XLR cables are in good order. A poorly soldered joint on the screen on pin one will introduce crackles and pops in ANY mic!
Post by amanise »
ef37a wrote: Mon Jun 12, 2023 6:31 am Small point, do make sure XLR cables are in good order. A poorly soldered joint on the screen on pin one will introduce crackles and pops in ANY mic!
amanise
Adrian Manise
