The Elf wrote: ↑Sat Jun 10, 2023 9:30 am
It's here. Ordered in March 2019, arrived yesterday morning:
Not sure what I make of it yet. More when I've formed an opinion...
"Ordered in March 2019, arrived yesterday morning:"
Reminds me of that joke Russians made in times of Soviet Russia, when a comrade needed a plumber to call and fix a leak and the plumber said "Yes comrade, we'll come around and see you on Wednesday, 20th March 2025"
The comrade asked "will that be morning or afternoon? I have an appointment at the hospital in the afternoon"
OneWorld wrote: ↑Sat Jun 10, 2023 5:32 pmReminds me of that joke Russians made in times of Soviet Russia, when a comrade needed a plumber to call and fix a leak and the plumber said "Yes comrade, we'll come around and see you on Wednesday, 20th March 2025"
Orchestral parts are very much in my sights, amongst other uses. I haven't the money to hire an orchestra and our listeners like the orchestral parts I create.
Anyway...
As ever, I miss that fifth octave. For lead parts a four-octave keyboard is ok, but as soon as I place my left hand I'm very aware of lacking that low end. It is what it is.
I bought the Osmose as a controller keyboard, rather than a synth. To this end I very much like the feel of the keyboard. I like the weight (or lack of it!), the matt finish, the travel, the wide squared-off key tops, the resistance to aftertouch... It really is quality. What I'm not so enamoured of is that to get enough finger grip to generate sideways movement I also get a spot of aftertouch; not a huge problem in reality, but has to be acknowledged. Worse is that in generating aftertouch it can be tough to avoid sideways movement. I have a feeling that familiarity will mitigate these points - already is, in fact. I can always filter out a control feature if it's a problem for a specific part.
The factory patches? Hit and miss. Mostly 'miss' for me. TBH I didn't buy the Osmose for the internal sounds (didn't even realise it had any at first), so anything useful is a bonus in my ears. There are a handful of nice wind patches, which are right up my street. Unfortunately there are also many patches with jarring repeating elements, which I abhore in most instruments. A few patches are nice enough, but quite pedestrian, and done better by other instruments; the last thing I need from the Osmose is an 'analogue' bass patch.
I tried pairing the Osmose with Equator 2, an instrument closely associated with the Roli Seaboard, and well versed in MPE. A little control re-mapping was necessary, but it worked OK. That said my Seaboards already do the job here, so I doubt this will be a use I'll return to very often.
I then paired the Osmose with my humble Audiothingies MicroMonsta 2. This is a match made in heaven! Those psuedo GR-500 guitar synth patches that I enjoy were instantly under my finger tips, and much easier to play than with my Rolis. Applying filter sweeps, vibrato, pitch bends... all gorgeously interactive and natural. I could almost wish the MM2's synth engine was on-board the Osmose, rather than the Haken.
While we're on the subject, I doubt this is a synth that I'm going to be editing any time soon. The software looks about as friendly as a jack russel guarding its bone, and I just don't feel motivated to install it. I'll probably have a moment of weakness some time and give it a try, but for now I'm leaving well alone.
And then it was off to Kontakt and a few orchestral patches. Yes, it kinda works, but... I don't feel it the way I do with my Seaboards.
I like that this is a 'keyboard', rather than a set of squidgy targets to 'aim' for like the Roli Seaboard. That said I haven't experienced the same 'duck to water' feeling with Osmose as I did with the Seaboard. I'm lucky in now having the choice. For solo parts I think I favour Osmose, at least when some speed is required - for chordal parts (especially orchestral) my heart is still with Seaboard, which feel more natural to me, and I feel more in control.
Sorry it's a bit of a mixed bag above. The most fun I've had have been the on-board wind patches and pairing Osmose with MicroMonsta 2. Given that these two uses represent important vertebrae in the backbone of my work I'm content.
The Elf wrote: ↑Sun Jun 11, 2023 2:04 pm
No worries Paul - your detailed analysis tells us a lot about its strengths and weaknesses
As I found when I developed my reaper plugin for the kmi qunexus and kboard devices (to turn them into what I thought I had paid for) the imagined experience of having polyphonic pressure and tilt (or sideways motion, which I was able to map as a third control axis) turns out to be quite different from what you need when you actually *play* these devices.
As a consequence I had to implement pressure envelopes and a bunch of other features to map my imagination to reality, and I imagine it's the same with the Osmose, with the underlying hardware giving you the control dimensions but requiring some quite sophisticated post processing to actually respond naturally.
Mine finally arrived today after a last minute hold up in Paris that prevented delivery before the weekend. Initial thoughts are similar. I like the keyboard, the onboard presets though did little to wow me.
I've also got a Rise 49 (version 1) which whilst I've always liked it I've always found it fatiguing to play , so have played it much less that I should have. My keyboard skills are on the wrong side of mediocre and I've never found my sausage fingers to be particularly adept at playing chords on the Roli. In part the purchase of the Osmose was about finding something with some of the expressivity of the Roli but easier to play. I suspect I'll end up keeping both though
RobinC wrote: ↑Mon Jun 12, 2023 7:40 pm
Those thoughts are familiar to me, and I've reached the same conclusion. Neither the Osmose, nor the Roli are all things to me, but between them I have the options I've been wanting.
I'm getting some expressive lead performances out of the Osmose. It's going to see a lot of use on the next album!
The Elf wrote: ↑Wed Jun 14, 2023 10:47 am
One quick mention...
Local Off is stored between power ups. That's how a pro synth should work. (You reading this, Novation?...)
And Nord!
Actually from what I’ve read, you can’t do local off with a Midi cc command either, so you can’t set up your live rig Cantible/MainStage etc to sort that out at the start of a set.
Could you further detail what remapping you did to connected E2 and Osmose? Through a DAW. I use Digital Performer. Thanks
The main thing was to re-map the two types of aftertouch of the Osmose to something Equator can make use of. I don't recall the details at the moment, since I still use my Roli with Equator and haven't been back to the Osmose for that particular use.
