Do you think the vocals fit over this track?
Post by redturtle1997 »
Feedback about the mix in general and the arrangement as well would be appreciated!
https://voca.ro/1oO6Dg0LWdcb
redturtle1997
Posts: 24 Joined: Tue Apr 25, 2023 2:06 am
Re: Do you think the vocals fit over this track?
Just had a quick listen and not my genre so take this with a pinch of salt, to me the vocals are lacking bite. Obviously that heavily processed effect means they sit back in the mix a bit but a bit more top end will help with intelligibility and help them cut through.
If that's the plan.
Posts: 28843 Joined: Sun Jul 05, 2015 12:00 am Location: York
I already noticed this but I wanted to give it that muffled sound like it's underwater, also there seems to be a lot of unwanted sounds in the high frequency area of the acapella, here's one without being high filtered, https://voca.ro/1oSGXMpxSdYl, which one do you think is better?
redturtle1997
Drew Stephenson wrote: Sat Jul 08, 2023 3:27 pm Just had a quick listen and not my genre so take this with a pinch of salt, to me the vocals are lacking bite. Obviously that heavily processed effect means they sit back in the mix a bit but a bit more top end will help with intelligibility and help them cut through.
If that's the plan.
redturtle1997
Personally I prefer the second one, the vocal are much more present and feel like they're leading the track but I think you've retained that underwater effect.
If you're concerned about unwanted noises in the HF area you can still low-pass it but just give it a boost in the presence area as well (or just below your low-pass corner).
