Rough Slope wrote: ↑Sat Jul 15, 2023 5:10 pmI picked up an old STC capacitor microphone kit the other day - it is a very small 4126A model complete with power supply, dating from the mid-60s or so from what I can gather.
A rare mic I think... I've never come across one before. But I think it might be llate 60s or even early 1970s, judging purely by the model number. The 4126 wasn't listed on a 1963 price list I've seen and the highest model number then was 4108.
I also found an old advert from Wireless World which appears to give the mic pin connections (1, 5-signal and 3-earth).
Do you have a link (or date) for the WW advert? That would help track down any reviews in audio magazines of that era.
The pin-out you describe would be unusual wiring for a DIN connection. The middle pin (2) is the default pin for ground on all DIN usage I've seen. And signal is more typically either 1/3 (opposite outer pins) or 1/4 outer and inner pins on same side.
So, the safest option would be to have a look inside the power unit to see how the connectors are actually wired. It will be pretty obvious which pins carry signal and cable shield.
BEWARE: if it's a valve mic the PSU will be provide an HT Anode voltage of anywhere between 100-300Vdc, and that voltage could persist on smoothing capacitors for quite some time after being switched off, so be extremely careful if you're poking around inside the box.
Don't open the PSU box if you not competent to handle valve electronics!
Also, bear in mind that the output may not be balanced. It was common to provide unbalanced outputs with different source impedances in the 60s — at least with dynamic mics. Don't know if that was also common with capacitor mics.
I have a few questions but the main one I have though is on the 'line output' ...
Capacitor mics have a much higher output than dynamic mics, but I'd be surprised if that box provides line-level outputs.
...provide some guidance on how to replace the existing 5-pin DIN output with say a 3-pin XLR connector?
I wouldn't do that. It would ruin the authenticity of the power unit... and all you actually need is a bespoke DIN to XLR adapter cable.
The cable is multicore and all pins are currently connected to the plugs as follows. (1-red; 4-black; 2-sleeve; 5-green; 3-brown).
That will be a standard hi-fi DIN cable (as used by Quad, Naim, Revox, Philips and others). Typically, left/right record signals would be on pins 1/4 and replay on pins 3/5 with a shared ground on 2. Obviously, the pin usage will be different for the mic, but a standard cable would be convenient.
I'm also unsure as to why the 5-pin connections were used. Although not indicated from the on-line information perhaps an impedance selection consideration?
Two pins for a balanced output (or different impedances), if it has a valve impedance converter then two pins for HT and heater supplies, plus a common ground. That's 5 pins used....
If you're in the UK (or even if you're not), it would be worth contacting Stewart from Xaudia / Extinct Audio as he may have specific knowledge of the mic, but might be able to advise on getting it working. He specialises in ribbon mics and doesn't routinely deal with capacitor mics... but I know he has an interest in vintage gear and he can always say no....
