I’m looking for a small mixer to do the following when performing live:
- inputs 1 and 2: my guitar and my vocals straight from a Neural Quad Cortex (sort of Helix, Kemper, etc). XLR
- input 3 monitor feed (wich will now be a mix of everything but my guitar and vocals)
- inputs 1 and 2 need to be able to run through the mixer, out to FOH. Either panned hard L and R via the main outs, either with direct outs.
- in parallel I should be able to make my own mix with all the 3 inputs and take it out to my headphones.
So far I’ve seen these small mackies, which have also the advantage to set main outs as XLR mic level, so the sound guy can’t complaint of me sending him or her weird levels or any other blablabla
Mackie 1202 VLZ4 and the smaller 802 with 3 XLR inputs and only one Aux.
The way I’ve thought to work it around:
- ins 1 and 2 hard panned as I said and sent to main out. All at unity.
- patch main out parallel TRS outs to 2 spare channels. Let’s say 4 and 5.
- send channels 3, 4 and 5 to alt outs 3-4
- set headphone out to listen alt 3-4
- enjoy with my own mix, even having chance to EQ it
The same could be done with Aux 1 and 2 in the 1202. 802 has only 1 aux. I could also patch TS cables in the insert in only half way, having direct outs. But I dont quite like this option for live context (half way in cables, use of adaptors… entrophy)
I have also the chance of getting a 2nd hand Onyx 820i, reviewed by SOS in 2009 https://www.soundonsound.com/reviews/mackie-onyx-820i
Are these any better than the new ones?
Any other suggestion? The mic/line level switch at main out really attracts me.
