Not on Adobe Audition, it seems. You have to click and drag. The last time I edited a project by selecting sections to delete by clicking and dragging, the RSI pain up my arm lasted for a week afterwards. Mac trackpad, regular mouse and "ergonomic" mouse: makes no difference.
Also in my edit, I might decide that a pause is too short between paragraphs and I want to copy and paste a longer pause from elsewhere. Not in Audition! I select the short pause, paste in the longer pause, and because the gap is smaller, the pasted audio overwrites the beginning of the next paragraph! I probably want ripple insert, but all I can find is a feature request for it.
I have Izotope RX7 and I thought perhaps it would be easier to do basic editing in there. Actually, this software has keyboard shortcuts for in and out points using square brackets [ ]. But you can only use these while the playhead is moving! So if I find my perfect in-point and stop, I can't select it. Unless there's another way?
I'm obviously doing this all wrong. It can't be possible that high quality professional editing software doesn't have the capacity to do basic editing. What should I be doing instead? I've asked on an Adobe forum, but the only suggestion I got was a complicated work around for in and out points.
I have a Loupedeck CT, which I was hoping would help, but not having a great deal of luck with that. I would need to programme shortcuts, but don't know what they are (as they don't exist?). I'm also still trying to get the controlwheel to scroll through/scrub through audio, which it doesn't seem to want to do.
I thought today, why don't I just get Reaper? Although my budget is already overspent and it might not be any better. Because, as I say, I must be doing it all wrong.
