Project Guinjo
Re: Project Guinjo
ManFromGlass wrote: Fri Feb 18, 2022 2:24 pm Beats me.
Btw - the next one will have to be a 12 string attached to the first . . . .
Somewhat amazingly, they do exist: https://www.google.com/search?q=twin+ne ... =873&dpr=1
Posts: 29047 Joined: Sun Jul 05, 2015 12:00 am Location: York
Re: Project Guinjo
It will soon be duelling guinjos, and canoe trips down the River Ouse will become far more dangerous. The air will be filled with the sound of people squealing like pigs (which will at least cover up the sound of the guinjos).
Posts: 18823 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Re: Project Guinjo
Post by shufflebeat »
Wonks wrote: Fri Feb 18, 2022 3:28 pm ...guinjos.
I propose "guinjeax".
shufflebeat
Posts: 9911 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Re: Project Guinjo
Post by ManFromGlass »
blinddrew wrote: Fri Feb 18, 2022 3:17 pm
Right. Doesn’t the guitarist in Led Zepjo play one?…. :smirk:
Posts: 7747 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
Re: Project Guinjo
Post by MarkOne »
Next one needs to be a triple neck banjo-lute-fretless 12 string :lol::lol::lol:
MarkOne
Posts: 3009 Joined: Thu Feb 15, 2007 12:00 am Location: Bristol, England, Earth, Perseus Gap, Milky Way
My Music on Apple Music
My Music on Spotify
Re: Project Guinjo
MarkOne wrote: Sat Feb 19, 2022 9:51 am Next one needs to be a triple neck banjo-lute-fretless 12 string :lol::lol::lol:
You've been listening to Steve Vai again, haven't you? ;)
Posts: 22231 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Re: Project Guinjo
Praying for audience to bear with him because one of the G strings is out and it will take a half hour to find and tune it?
Re: Project Guinjo
Interesting semi-fretted bass there.
Re: Project Guinjo
blinddrew wrote: Sun Feb 20, 2022 1:57 pm Interesting semi-fretted bass there.
If you're interested, here's Steve Vai talking about the Hydra's design concepts:
https://www.youtube.com/watch?v=eN9r0jlhUpU
Re: Project Guinjo
Thanks Martin :thumbup:
Re: Project Guinjo
ManFromGlass wrote: Tue Jan 04, 2022 3:41 am You might consider some padding on that metal rim as it might not be too comfortable to rest an arm over, unless you’re into that sort of thing……
Not judging at. . . . . .
:smirk:
Quick update a year on, I have added a little bit of aluminium tube to act as a forearm rest (which helps a bit) and swapped the out drum head out for a bit of calfskin.
This has significantly tamed some of the less pleasant overtones that I was previously damping with a bit of foam.
Re: Project Guinjo
Post by BJG145 »
Very nice. :thumbup:
Posts: 7951 Joined: Sat Aug 06, 2005 12:00 am Location: UK
Re: Project Guinjo
Post by tea for two »
Drew Stephenson wrote: Mon Sep 18, 2023 10:04 pm Quick update a year on, I have added a little bit of aluminium tube to act as a forearm rest (which helps a bit) and swapped the out drum head out for a bit of calfskin.
I've just seen this thread. Read skimmed thru most of the posts. My Kora is covered in cowhide. If I had seen this thread year half earlier I would suggested cowhide.
tea for two
Re: Project Guinjo
I’d have gone with asbestos. You need to make those things as fireproof as possible if you plan to play them in public.
Re: Project Guinjo
tea for two wrote: Mon Sep 18, 2023 11:37 pm I've just seen this thread. Read skimmed thru most of the posts. My Kora is covered in cowhide. If I had seen this thread year half earlier I would suggested cowhide.
I was just using the original drum head initially because, a) I didn't know any better, and b) it was really just a proof of concept.
But I'd been wondering about changing the skin for a while. Now I've got all the parts recorded for the latest album I decided to give it a go.
Wonks wrote: Tue Sep 19, 2023 7:58 am I’d have gone with asbestos. You need to make those things as fireproof as possible if you plan to play them in public.
But then if it catches the fumes would be toxic and...
Oh wait, I see your game.
Re: Project Guinjo
Re: Project Guinjo
Ouchies :thumbdown:
Posts: 13178 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Is it about a bicycle?
Re: Project Guinjo
In retrospect, the design flaw is obvious. If I'd loaded the drum onto the spine from the bottom then a) the string tension would be pulling the tail joint together and b) the complete part of the hoop would be under tension with the cutouts in compression against the spine.
Not something that can be changed retroactively.
So the question is whether I can add a hoop of sufficiently high tensile wire at the base to cramp everything back together. A quick dabble in the garage suggests the principle is valid but that copper cable is not strong enough.
Re: Project Guinjo
Not long 'till Nov 5th. ;)
Re: Project Guinjo
Can you take a couple more photos? I'm not exactly sure just what's happened there apart from something coming apart.
Re: Project Guinjo
Wonks wrote: Sat Oct 11, 2025 3:57 pm Can you take a couple more photos? I'm not exactly sure just what's happened there apart from something coming apart.
Well, it's in pieces in the garage now so not really...
The photo is of the underside of the body with the neck at the top of the picture and the tail at the bottom. The splits (top and bottom) are where the hoop is being pulled away from the spine.
What's happened is that the skin had stretched a bit over time, so I'd popped the head off, tightened up the skin a tad, put the head back on and was working round the tuner lugs tightening it up properly.
At which point it made a horrendous creaking noise...
Basically the tension on the skin is opposed by a tension in the bottom of the hoop. The skin pulls in the top of the hoop forcing the bottom of the hoop outwards (as if it's trying to turn the hoop inside out).
However because I loaded the hoop onto the spine from the top (thinking this would be better for countering the string tension), it meant cutting two lugs out of the bottom of the hoop. At it's at those stress concentration points that it's failed.
I'm not sure that my wire-in-tension round the bottom of the hoop is going to work so I'm currently considering two threaded rods in tension in an x-brace across the bottom of the hoop to squeeze it back in place.
Re: Project Guinjo
You should have checked with a drummer first -
You would have heard that calfskin is much more than a head choice. It’s a lifestyle. Timpanists, snare drummers and others who have gone over to the calf skin side don’t realize what they are getting into at first!
Re: Project Guinjo
I've got skin heads on all my drums too, but they're not giving me any grief. It's literally just because I didn't think through the design implications when I built this - I was focused on the string tension and didn't consider the skin tension.
Re: Project Guinjo
Have you tried moisturiser?
Re: Project Guinjo
I'm sorry to see the sorry state of your Guinjo Drew - hope your mods sort out the problem.
