Doepfer Theramin modules
I said to a friend of mine recently “I’m going to buy two Doepfer Theremin modules, he said “ why two? they have X/Y outputs” I said “because two look on stage, and two aerials are better than one”
I’m at a dinner party right now, in the toilet topping up on Scotch, escaping, I’d rather be in my damp basement.
It’s not our friends fault, they are sweet, it’s just that I’ve reached the height of self awareness and I’m having rouble getting out of the toilet.
Posts: 21091 Joined: Sat Jul 12, 2003 12:00 am
Re: Doepfer Theramin modules
I've moved this into a topic of its own as it wasn't related to the topic in which you posted it Tony. I'm not sure how useful two Theramins would be to anyone with only two hands but one never knows.
Steady on the old scotch ;)
Posts: 9782 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
There’s a difference between the two aerial Moog style ones and the single aerial Doepfer, you need two hands on the Moog, one for pitch and one for amplitude but you only need one had for both on the Doepfer, so two can be played at the same time.
Post by BigRedX »
BigRedX
Posts: 2996 Joined: Fri Sep 03, 2004 12:00 am
I was all in until the first acronym. :D
Posts: 29047 Joined: Sun Jul 05, 2015 12:00 am Location: York
Nope, detected a gross odoriferous rodent pretty much immediately!
Posts: 20453 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Arpangel wrote: Tue Sep 19, 2023 8:14 am There’s a difference between the two aerial Moog style ones and the single aerial Doepfer, you need two hands on the Moog, one for pitch and one for amplitude but you only need one had for both on the Doepfer, so two can be played at the same time.
The A178 can generate a gate signal output when it detects a hand within range of the aerial. So you can kind of 'play' it one handed... but without any of the finesse and dynamic controllability of the classic two-aerial design.
Doepfer describe using two A178 modules to recreate the classic Theremin, one generating the pitch CV and one for the VCA CV.
Posts: 43047 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by BJG145 »
It takes years to play a theremin the way I do. There are no shortcuts.
Posts: 7951 Joined: Sat Aug 06, 2005 12:00 am Location: UK
Post by RichardT »
BigRedX wrote: Tue Sep 19, 2023 9:28 amWhat you need is a polyphonic Theremin
I think he needs help getting home!
RichardT
Posts: 5477 Joined: Fri Aug 13, 2004 12:00 am Location: UK
BJG145 wrote: Tue Sep 19, 2023 6:56 pm It takes years to play a theremin the way I do. There are no shortcuts.
I didn’t know Bob Dylan played Theremin?
Hugh Robjohns wrote: Tue Sep 19, 2023 4:28 pm
I was thinking along those lines too.
